Old 08-06-2008, 10:57 AM   #1 (permalink)
rednexx's Avatar
My Photos: (17)
7.3idi Van versus Truck motor
Does anyone know the difference between the two? I have a truck motor ('89 7.3) that i'm trying to put into a 76-91 van body. I have the 7.3 engine crossmember pads from an '90 ambulance van and motor mounts. The problem I am having is that the oil pan hits the crossmember before the mounts touch.
Thanks.
Early 99 F-250 Superduty X/C SB, 6 speed, South Bend Con OFE clutch, 4" turbo back exhaust, Ebpv Brake Mod, DIY Tymar, Hutch Mod, 2" leveling kit, 315/75/16's, DP tuner (stock, 60tow, 80econo, 120race, 140extreme), Warn premium hubs, Autometer pyro, boost and fuel pressure gauges.
76' (updated) E series 24' Motorhome - in the process of 4x4, 7.3IDI turbo, ZF 5 speed conversion.
My Gallery
http://photos.thedieselstop.com/show...0/ppuser/80710
Next........MORE!!!
rednexx is offline
Old 08-06-2008, 05:21 PM   #2 (permalink)
i dont know about diesels but gas motors use a different oil pan and iol pump sump
2002 e350 power stroke former patty wagon egt boost tach gauges walkers btm diy intake 130k miles dp tuner f5 80e 100 140 extreme overboost annihilator 410 gears
e444 is offline
Old 08-07-2008, 01:08 AM   #3 (permalink)
I have never compared my van engine to my buddies pickup truck engine. It's possible the pan could be different.
Wait, are you saying this 7.3 IDI is from a truck (medium duty) or is it from a pickup???? If a medium duty truck, then there is a good chance that it is a different pan.
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
Kaliburz is offline
Old 08-07-2008, 10:32 AM   #4 (permalink)
rednexx's Avatar
My Photos: (17)
It's from an F350 pick-up truck.
My Gallery
Next........MORE!!!
rednexx is offline
Old 08-08-2008, 08:35 PM   #5 (permalink)
Oil pan, oil cooler, one exhaust manifold, two injector lines, fuel filter location.
That's just from memory of reading old posts, you may want to do a search to make sure.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 08-10-2008, 04:29 PM   #6 (permalink)
rednexx's Avatar
My Photos: (17)
I've add a few pics of my problem to my photos (Diesel crossmember). Everything I have searched shows the same part numbers for the oil pan and oil pump for the truck and van motors.
I'm hoping the wrecking yard I got the crossmember from still has the 7.3 that came out so I can see what the difference is. There's a piece of the puzzle missing.
My Gallery
Next........MORE!!!
rednexx is offline
Old 08-11-2008, 10:23 PM   #7 (permalink)
rednexx's Avatar
My Photos: (17)
Well, I got it figured out. There are three different mounting points, the motor plates on the crossmember, the motor mounts them selves, and the brackets that bolt to the block. The brackets that bolt on to motor are totally different. The drivers side is a deep cast piece about 4" longer with a different offset. The passengers is still a stamped piece, but a little deeper with a huge offset to the rear.
Now that I have the right combination of motor brackets, motor mounts and crossmember mounting plates.....Voila! it all bolts together and looks like it's in the right position. The oil pan is the same, and from what I've read, if you are doing a 4x4 swap, you need the drivers side exhaust manifold and oil cooler from a pick up anyway to clear the driveshaft. Hopefully I'll have it installed in the next week.
Thanks for all the replies and input.
My Gallery
Next........MORE!!!
rednexx is offline
