Re: 93E350 7.3 E code23 & eratic speedometer
You can run self test with an ohm meter, but I don't have the procedure to do it.
A code reader that will work on your truck is about $25 at most auto parts stores. You plug it into a connecter near the driver's side battery. The connector is in a cover that says "EEC TEST."
There are tow tests to run, a Key On Engine Off (KOEO) and Key On Engine Running (KOER). Turn the tester on and then turn the key on. Hold the accelerator pedal to the floor. The tester will start reproting codes in about a minute.
It will first report the codes of any fault that is prsent during the test, then will repeat the codes. After it repeats there will be a single beep. Then it will start reporting any code that has been stored in memory. Once it starts to repeat these codes you can turn off the key to erase all the codes.
Next you can run the KOER test. It runs without you pressing the accelerator and with the engine running. After this test it will report the codes of any problem it finds during test.
Mark
'01 F250 Crew Cab Shorty V10 5 Speed
Mark
