ABS Pump Runs when Vehicle off! 2003 7.3 - Diesel Forum - TheDieselStop.com
Old 07-22-2009, 03:24 PM   #1 (permalink)
deminimis's Avatar
the other day, the ABS pump starts running non stop (if vehicle running or not). Had to pull the big fuse to get it to quit. There is a recall on the ABS module, and I'm guessing that will cure it, but the Ford shop states there is a hard fault for the pump too. I think the module (free because of the recall) will cure all ills, but it would be nice to know if anyone else here had this problem? If so, did the ABS module cure it? I read a couple of instances with Excursions that had the same issue and the ABS module took care of things. Worried about the pump fault, so that's why I'm ask'n. Thanks.
'03 E-350 7.3 PSD Sportsmobile 4x4 Conversion (4.5" lift, Dynatrac Pro Rock Front, Dynatrac 60 rear, Atlas II transfer case, electric penthouse, Aluminess Bumpers front and rear, and a whole lot of other goodies) -SOLD
deminimis is offline
Old 10-23-2009, 03:34 PM   #2 (permalink)
Send a message via AIM to mrmusic
Got the Same Problem Never went for recall been driveing 2 years with the fuse pulled I also pulled the liabs light. thats all i did so far. I only have 44,787 miles on the van.
chris
mrmusic is offline
Old 10-23-2009, 03:53 PM   #3 (permalink)
deminimis's Avatar
I've had zero problems since the stealership fixed it. Sicne it was a recall, cost me zero as well.
Old 10-24-2009, 07:32 AM   #4 (permalink)
anash13's Avatar
Interesting problem.
Just what is an ABS pump?
What should I be looking for?
Thanks Guys.
2003, E-350, XLT, Chateau, 7-Pass. Club Wagan, 7.3L PSD, 3:55 LS Rear, DP TUNER F-5, AMSOIL TS-126 Air Filter, Fleetguard LF-9027 Bypass Oil filter, Sirius Satellite Radio, Garmin GPS, SuperCrewzer, AutoMeter (Pyro. Trans. Boost)Gauges, 4" Diamond Eye Turbo Back Exhaust, Sonnax valve & Tricululator springs, PML Alum. Tran's Oil Pan, Tru-Cool 4739 Tran's Cooler, ScanGuage Monitor, DAHL 100 Fuel Filter, "Last of the 7.3's".
USMC-(Ret).
You Can't Always Get What You Want, But If You Try Some Times You Just Might Find, YOU GET WHAT YOU NEED.
anash13 is offline
