Old 12-12-2007, 01:43 AM   #1 (permalink)
Adding Cruise Control??
My church has a 2001 Ford 15 passenger van, and I was wondering if it is possible to add cruise control like you can for the f-series diesel's and such.
Is it just the clock spring and steering wheel w/ buttons, or is there more to do? It has a 5.4l in it I believe.
2001 Ford F-350 7.3 WHITE CC DRW, BONE STOCK, FULLY UNLOADED. HOPEFULLY THIS WILL ALL CHANGE SOON!
2002 CHEVY SUBURBAN LS 4X4 (WIFE'S)
2006 CARDINAL 362LE 40'8'' TIP TO TIP - ABOUT 12000 LBS DRY
2003 JOHN DEERE 790 4X4
1998 JOHN DEERE 325
white_nite is offline
Old 12-12-2007, 10:17 AM   #2 (permalink)
Re: Adding Cruise Control??
Yes you can get the kit from Ford. Since the gassers are not "drive by wire" there is more to it than just adding the steering wheel like the diesels.
You can also use an aftermarket kit, like I did for my International. Cost may be a little lower aftermarket.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 12-13-2007, 02:08 AM   #3 (permalink)
If Ford is like Dodge, all the wiring for cruise is there. I added cruise to my work truck and all I had to buy was the clock spring, steering wheel with buttons, and the cruise servo. Bolted it on, plugged it in and it was good to go.
Only thing I bought new was the clock spring, the rest came from the junkyard.
Later,
Joe
'00 (born 1/00) PSD X 4x4 Limited 285 Dayton Timberline ATs and Rancho 9000x's Prepump & in tank mods and HX Crossover installed 4.5" Magnaflow Stainless Exhaust w/downpipe
AFE Stage II Magnum Force Airbox
'95 F-350 XLT CC 4x4 DRW PSD 5-speed 4.10s Alcoas
Crash_AF is offline
Old 12-13-2007, 12:50 PM   #4 (permalink)
SuperbeastVan's Avatar
Yes I believe the Fords are set up the same way.
Ken Schwarz
Dayton, NJ
2000 E350 4x4 Dually
Clamshell Style Rear Doors, Gullwing Passenger Side! Hopefully soon to have Air Suspension and Tilt Nose.
SuperbeastVan is offline
Old 01-01-2008, 05:11 PM   #5 (permalink)
There are loads of kits on e-bay. I bought mine for my '01 7.3l Diesel for about $119.00. Try there first, the place I got mine had quite a few.
2001 E-350 SuperDuty. Extended Cargo, Energy Suspension Bushings, Power Stop Rotors(F), Wagner Rotors(R), 203 degree thermostat, K&N Filters, '99 speedo w/tach, cruise control, Monroe RV/Towing shocks in Rear. Yaesu FT-857D Ham Radio. Plan's: Air Bags, Calipers, Temp Rack on A-Pillar(Dif., Trans., Turbo).
wadelohse is offline
Old 01-01-2008, 07:49 PM   #6 (permalink)
I can get the cruise wheel off a gas burner.
Will that bolt to my PSD van and plug into the harness?
What is a "clock spring", and would I need one with this wheel?
I suppose since we 'drive by wire', if the wheel plugs in, there is no servo or anything else to worry with... Correct?
Thomas Jefferson:
"The democracy will cease to exist when
you take away from those who are willing to
work and give to those who would not."
ratio411 is offline
Old 01-02-2008, 03:13 AM   #7 (permalink)
The clock spring is the wiring in the column that makes the airbag and steering wheel controls work. Since airbags don't like the slider contacts like the older vans, there is an actual hardwired connection between the column and wheel. It is wound inside a case and looks like a clock spring, hence the name, to give it enough length to allow full motion of the steering wheel. I don't know if Ford used one for all, or different springs for cruise/non cruise. Mopar used a different one for each.
My guess is just install a wheel with buttons and a new clock spring and you're good to go.
Crash_AF is offline
Old 01-02-2008, 05:09 PM   #8 (permalink)
My Photos: (13)
For the diesel you also have to jump or install brake pressure switch. Its the backup to turn off the cruise in the event of primary switch (brake) failure.
The gas you also have to install the servo/amplifier assembly.
Bill
MADVAN is offline
Old 11-02-2009, 02:57 PM   #9 (permalink)
Question
I know this is an old thread, but I missed this post and need details.
Way back when this thread was young, I installed a cruise wheel and clockspring. It didn't work. Now I see this post and realize I missed a detail.
What do I need to do to a 95? Jump or install new switch?
What do you mean 'jump'?
Details?
Thanks!
Dave
Thomas Jefferson:
ratio411 is offline
