Old 12-02-2007, 09:09 PM   #1 (permalink)
Adding intercooler
Just to give you a little background.I Bought a 97 E-350 psd turbo a four months ago and last month my wife and i pulled the motor to rebuild as it wasn,t running when I bought it. It came from northern Ohio and every thing in this thing had more ruct than you would believe I guess they never wash any of the salt off nor did they pre-treat it.The oil pan has holes in it and is too far gone to reuse and the oil cooler looks way to rusty to be comfortable with and the turbo pedestal is leaking. Have a chance to buy a donor 2001 7.3 psd with a intercooler turbo and the other parts that I need. Has anyone ever done this kind of interchange? How much will i have to change or can it be done.What else will i have to change?
Copyman is offline
Old 12-02-2007, 09:25 PM   #2 (permalink)
My Photos: (13)
Re: Adding intercooler
97 maybe a flood van?
01 has an intercooler?
Must be an F-series motor.
Bill
97 E-350 Quigley Van Picts
Supporter/User of THE CURE E4OD/4R100 Transmission Control
WWW.FORDTRANSMISSIONCURE.COM
TO RENT THIS SPACE SEE YOUR ADMINISTRATOR
ads@thedieselstop.com.
MADVAN is offline
Old 12-02-2007, 09:31 PM   #3 (permalink)
No the 97 wasn,t flood veh just run in a lot of salt and chemical belong to cabinet shop haven,t gotten around to intercooler yet just trying to figure out what i will have to do to install this on the 97.
Copyman is offline
Old 12-04-2007, 08:58 PM   #4 (permalink)
My Photos: (6)
Start with a better truck! By the time you put in a motor, etc. You'll have more time & $$ in it than a nice one would cost. Good luck, Bart
01 CC SB 4x4, 4 bank DI chip, Garrett GTP38R, Gutted EBP valve, AFE Stage 2 intake, Pillar gauges, built trans w/billet converter,Hx crossover pipe, Shimmed fuel pressure reg. Bullydog propane injection, 4" side piped exhaust -due to interference with Fox res. shocks, cowl induction hood, Custom mesh grille, 03 lites, Line-X, 8" Donahoe lift with remote res. Fox shocks, ProComp Xtreme A/T 37's on 10" Centerline Vectors, XM, Retrax bed cover, A.R.T. rotors and Performance Friction pads on all 4 corners, Elf 15/40 full synthetic oil, AIH delete, Aluminum deep finned trans oil pan -full of Redline Synthetic ATF, Mag-hytec rear diff cover, Lighted heated TT mirrors, Sunroof with custom alcantera headliner, Custom leather wrapped steering wheel, roof dynamated, 4.56 gears-LSD front & Rear. Train horns.
FATURBO is offline
Old 12-05-2007, 02:42 AM   #5 (permalink)
My Photos: (14)
The motor itself should fit. If you intend to try and run the intercooler plumbing from the f-series, your in somewhat uncharted water. You can swap the intake stuff over from the van motor and run non -intercooled, that's how the vans are set up.Don't know if the wastegated turbo will fit from the F motor. Might need to reuse van turbo. Sorry can't be more help.
ddog
While I love diesels, I don't need one, and unfortunately, after much deliberation its a hobby I currently cannot afford.......... Gone but not forgotten:
1999.5 F250 CC SB XLT 4WD, 7.3 PSD, First F,2nd Diesel, nice but still liked the van better.
2003 E-350 Super Duty Chateau (Club Wagon)7.3PSD, 3rd Clubwagon,First diesel, Never should have sold it....
ddog is offline
Old 12-05-2007, 01:47 PM   #6 (permalink)
SuperbeastVan's Avatar
As far as I know the 7.3 in the vans never had an intercooler. They didn't put them in till the 6.0 went in. The van and truck turbo housings are the same, but the inners are different. A buddy put a Banks kit on his 75 van that he installed a 7.3 in. The kit worked with some slight modifications. He had to get the truck turbo tho and swapped the new turbo core from the Banks kit to work.
Ken Schwarz
Dayton, NJ
2000 E350 4x4 Dually
Clamshell Style Rear Doors, Gullwing Passenger Side! Hopefully soon to have Air Suspension and Tilt Nose.
SuperbeastVan is offline
Old 12-07-2007, 12:30 AM   #7 (permalink)
fordnut350's Avatar
I have a 95 E-350 with a 7.3. I was wondering if a 6.0 intercooler will bolt into a earlier van then I could have some tubes fabbed up to fit. Has anybody tried this?
2001 F-350 CC LB 4X4 06 frontend 6.5" pro-comp lift with 35" BFG muds on 18x10 Mickey T's 4" MBRP SS exhaust Airraid intake Hypetech tuner
fordnut350 is offline
Old 12-07-2007, 09:55 AM   #8 (permalink)
I don't think the 7.3 versions have any room for an intercooler. I've looked at mine and couldn't see any way to get it in. The 6.0 is either shorter or sts back further and the rad and A/C coil sit farther back and the intercooler goes in front of it. It is about the same size as the rad.
Ken Schwarz
Dayton, NJ
