Old 06-27-2008, 07:02 PM   #1 (permalink)
Air bag helper springs
I've been thinking of getting some put on after I get my receiver hitch installed. I figured since it was an extended van (1 ton), the hitch being "that much" further back could be an issue. I don't foresee needing it, but I'd rather have the air assist if needed..... I don't tow that much.
Any how, there are these "Ride Rite" springs I found at the local parts shop. According to the online info, the are installed inside (in board) of the rear springs. You remove the axle bumper stop and then the unit bolts to that part some how. It essentially sits just inside the frame over the axle. The lower part of the spring mount kind of goes around the shock mount. Part number on ride rite site is 2032. A PDF is available online....
So, anyone running an air bag system on their van and how do you like it? Which brand and weight capacity?
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
Kaliburz is offline
Old 06-27-2008, 07:54 PM   #2 (permalink)
We have an “Air-Lift” air bag system under a 2004 E-350 6.0L extended van with an additional two foot extension added to the rear end. We also have a stabilizer bar on the rear end. The combination of these two items really made the van handle much better. The van is in expedited service and the most we have hauled in it was 5200# on a 2000 mile run. For that load we ran the bags at 100 PSI. It still was a little “squirrelly”; but it handled the load at 70MPH. We drop the pressure down to 10 PSI when it is empty - otherwise you can’t stand the bumps. We also run 85 PSI of air in the rear tires, so that contributes to the harsh ride. The air bags have been on for about the last 120,000 miles and there have been no problems. I wouldn’t be without them.
Ken.......
Ken Kaepernick is offline
Old 06-30-2008, 01:33 PM   #3 (permalink)
Cool. Thanks.
That Air Lift one, is it the type that mounts over the leaf spring and has the bracket bolted on the exterior of the frame? The 'Ride Rite' ones I saw get mounted "next to" the spring inboard vs over the spring. I'm wondering of the positioning would make any difference.....
Kaliburz is offline
Old 07-02-2008, 01:17 AM   #4 (permalink)
ujointclothing's Avatar
Send a message via ICQ to ujointclothing
The ride-rite is a good kit for an off the shelf unit on a stock rig. I'm not too crazy about some of their mounting brackets, but they get the job done, and sometimes there just aren't any options. This is how I chose to build mine:
Lots of fab, but they're done exactly the way I wanted.
Do it nice or do it twice!! Van sponsors: Mickey Thompson, Warn, RBP, Bilstein, Detroit Locker, Atlas Spring, Tuffy Security, Line-X // 06 E350 6.0, Sterling 10.5" rear axle w/Detroit locker, Dynatrac Pro60 front axle w/F550 knuckles & brakes, Knoll Racing front Powerlock, ORU/Lee hydraulic ram assist, Bilstein 5150 series shocks & Nitrogen bump stops, custom dual shock hoops, rear overload airbags, custom front bumper, Warn 16.5 winch,1350CV's front & rear, 1410 yokes, long travel front shaft, RBP 4" stainless exhaust, Atlas custom leaf springs, synthetic winchline, Line-X interior, M/T 38/15.50/20 MTZ's on M/T 20x10 Classic Locks. Thats all I can think of right now!
ujointclothing is offline
Old 07-02-2008, 07:50 PM   #5 (permalink)
That is a nice looking setup. I have the Firestone sport-rite 2181 and they work great on my stock suspension, extended e-350. I tow a 10k travel trailer with a weight distributing hitch. Before I put the airbags on, it sat nose high, even with the WD hitch. With the airbags pumped to 90-100psi, it sits level and tows great. It was an easy install too. Here is a pic of it installed.
2005 E-350 XLT Extended 6.0
1984 Mustang SVO
SVONick is offline
Old 07-03-2008, 06:53 AM   #6 (permalink)
sixiron's Avatar
My Photos: (11)
If you do not tow that much ....might consider using Timbrens...they replace the bump stops and work great...
they activate on heavy loads and no air to fool with
been using them for 5 years or so on my extended cargo that trailers occassionally
I think its Vehicle Suspension Kits - Timbren Suspension Enhancement Systems
2002 E-350 ext. cargo..4" DP+exhaust/gauges/ CCV mod/ AIH delete/TT mirrors wC-btr's/Amsoil Dual by-pass/Racor 45P prepump/ITP regulated return w/fuel bowl delete/tank mods/203*/timbrens/bilstein/Hella/ DP tuned/BTS trans/ alum baja wheels/cryo rotors...dyno 335 hp...164,062 miles
98 E-350 PSD...575K
04 VW TDI/PD Jetta wagon
cat 2 mic f/filter,CCV/muffler/fuel filler mods,Evo skidplate/ RC1+
sixiron is offline
Old 07-03-2008, 09:39 AM   #7 (permalink)
If you install air bags on the rear, make sure you fill the two bags independently. It is very tempting to tie the fill lines together and fill both to the same pressure, but don't do it.
If both fill lines are tied together, when you go around a corner, the outside bag will transfer air to the inside bag and make the vehicle lean more than if you didn't have the air bags. Kind of like a reverse anti-sway bar.
When cornering with the fill lines separated, the outer bag pressure will increase and the inner air bag pressure will decrease and the lean will be reduced.
Mike
125W solar panel. Sportsmobile off-road trailer.
54,311 miles. 16.47 mpg average
From Cal to Alaska and Key West and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires. 46 Gal tank - harpooned pump vent tube.
Scangauge
162 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, Turbo hose fitting, Block Heater, Door lock - all under warranty. AC hose, not under warranty.
MikeL46 is offline
Old 07-03-2008, 02:53 PM   #8 (permalink)
XRACER's Avatar
I usually don't make comments like this.....especially on the 'friendly' forum.....but I have to say that this is pretty irresponsible behavior. Running over weight, over the speed limit, and over inflated put's others at risk.
If you want to be a hero, take it to the race track....
JMHO
2005 E350 Standard Cargo Van, 6.0 PSD, 4.10 L.S., Quigley 4X4 New on 11-18-05
(seems to manufacture oil....1 Qt per 4000 miles)
Warranty Turbo 7-07 22,000 miles
Warranty A/C compressor 10-07 25000 miles
2003 E350 Extended Cargo Van, 7.3 PSD, 3.55, Quigley 4X4 New on 2-1-04
Some Pix
Transfer Flow 46 Gal.***Delaminated***Replaced 8-29-06 UNDER WARRANTEE
XM Radio, Alpine GPS Nav. System
7.5' Western Snow Plow
Quad Captain's chairs and Espar Furnace
OX cable locker on front
ARB locker on rear
BTS Tranny 9-29-07 @55,000 miles
Aluminess Bumpers
Mile Marker 12,000 pound hydraulic winch
XRACER is offline
Old 07-03-2008, 04:59 PM   #9 (permalink)
blageurt's Avatar
Van racing , now that would be wild . . . especially pulling a trailer . . .
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , HD cooler , 3:55 D70FF, Michelin LTX " E "
Not installed yet DP flashed PCM (60 Tow )Autometer Triple Pillar Guage pod ,New Injector O-rings /IPR /lift pump /filterbowl @ 235K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is online now
Old 07-05-2008, 10:09 AM   #10 (permalink)
Nice custom set up. Is the frame mount custom also, or was that stock air bag manufactuer???
A buddy had a kit installed on a 3/4 ton Chev and it was similar to the one I'm looking at. Mounted where the axle bumper went.
The online instructions that I looked at (most of them) all tie both of the air bags together w/ one common fill. I'm thinking of getting a compressor kit. Looked at the auto system but I think I'll pass on that one.
I won't be doing that much towing w/ the van, but I just don't like the idea of the back going down if I do. I tend to borrow trailers from friends and they don't use weight distributing hitches at all.
Here is another question- Where does one put the air controls (and guage) on a van? It seems as if it's a limited area under the steering wheel on mine. I mean, I have the duel tanks so the switch is there. I don't want to mount anything near the engine cover (it's hard enough to get that on/off). (1990 van, so I don't recall what the newer style looked like near the driver area).
Kaliburz is offline
Old 07-05-2008, 08:04 PM   #11 (permalink)
JMHO
What was the weight of the truck compared to GVWR? What was the speed limit?
Tire inflation guides specifically recommend extra inflation (over cold inflation) for high speed use.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 07-07-2008, 02:34 PM   #12 (permalink)
The upper mounts on mine were custom made as well.
Old 07-12-2008, 12:10 AM   #13 (permalink)
I ended up getting the Ride Rite 2032. I happen to come across a kit on Ebay, and got it for a good price. Now I just have to get an air inflation kit....
Also picked up an air spring kit for the front. Was cheap enough and from the same seller..... don't know if I'll use it, but I'll have it if needed. I don't think I could have gotten them any cheaper....
Kaliburz is offline
