Old 08-19-2008, 04:34 PM   #16 (permalink)
To prevent compressor surging from the chip, I installed the ATS ported compressor housing which has a 4'' inlet as opposed to the 3" factory. With that out of the way, getting the 4" intake to mate was a snap. I don't own a welder or the ability to operate one so, I took my van into this place Silicone Hose, Silicone Hoses, Turbo Hose, Turbo Hoses, Intercooler Hose, Intercooler Hoses, T-bolt Clamps and had them do the fab. It was a fairly simple process for them, nothing more than one mandrel bend in the 4" aluminum towards the front near the velocity stack and a silicone 90 at the turbo. I suppose I could've done something myself but I insist on the upmost of quality.
2001 E-350 ext 15 passenger. 7.3L psd, DP-Tuner 20, 60, 80, 80E, 120race, Overboost Annihilator, Turbonetics BB, 4" DiamondEye turbo-back exhaust, custom fabricated 4" intake, Gold Line rebuilt powder coated calipers, braided stainless soft lines, Precision torque converter, TransGo shift kit, ATS Deep Sump trans pan, AutoMeter Ultralite Boost, Trans temp, EGT and in a three pod pillar and fuel pressure, DP-selector and oil temp in an over head console.
New motor in progress.
deltadrummer1 is offline
Old 08-19-2008, 07:46 PM   #17 (permalink)
clev's Avatar
My Photos: (14)
Hi delta; you have any pictures?
'85 E-150 351w, factory order rcvd Oct. '84: Balanced/blue-printed, HYPEREUTECTIC pistons, matching edelbrock performer pkg: cam, lifters, intake, carb, & elec fuel pump. MSD pkg: MSD 6, billet distributor, timing control, & 8.8 wires; AirLift air bags, Deraler tubed trannie pan, FloMaster Exhaust w/duramax ceramic headers, new paint.
'99 E-350 HiTop Companion Van Conversion SD 7.3, factory order rcvd Dec. '98: SuperChip, twin K&N air filters, 203* mod, Deraler tubed trannie pan, B&M trannie cooler, AirLift air bags, Bilsteins, 4" DiamondEye turbo back exhaust.
clev is offline
Old 09-03-2008, 09:00 PM   #18 (permalink)
clev's Avatar
My Photos: (14)
As a follow up (still in the planning stages), I'm looking at the original air box. I currently have two K&N's that cost about $40 each and hate to dispose of them, and then buy a cone or two cones at the same price or more.
I think that I can turn the OEM air box over, do away with the lower half (now on top), and fabricate a rectangular brace/bracket/ box to hold the two K&N's in place. Then, cut out the trapezoid portion of the hood, directly over the filters, and place a backwards facing scoop. Yeah; I think that's a plan!
clev is offline
Old 09-10-2008, 07:25 PM   #19 (permalink)
At last.
A small metal bracket comes off an existing hole, directly above the filter and along where the weather stripping goes, and straps in underneath the metal hose clamp that holds the filter on the intake.
Old 09-10-2008, 09:17 PM   #20 (permalink)
blageurt's Avatar
Nice setup . . . I don't think you need the filterminder deal though. Will you be fabbing a scoop for the hood or does it all fit under the original ?
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , HD cooler , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " ,Not installed yet DP flashed PCM (60 Tow )Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 09-11-2008, 04:32 PM   #21 (permalink)
Thanks! LOL Yeah I had installed for kicks, nice little touch i thought... And it does fit under the stock hood quite nicely. The welder and I talked about fabbing up a cold air box around it too in the future; all in time. (and money)
Old 09-12-2008, 04:44 PM   #22 (permalink)
My Photos: (9)
Hey! That's pretty cool... Talk about simple.
What type of filter is that?
2001 E350 PSD, Deep Emerald Green, 3.55 LS, Premium package, dual alts, rear A/C. Quigley 4x4, Transfer Flow rear tank (27+26), handicap mods, custom interior, Reunel tire carrier w/ Hi-Lift, Sportsmobile nerf bars (black), Amsoil lubes and Dual-Gard bypass oil filter, Amsoil air filters, Eclipse/JL Audio sound system w/ Sirius & 120GB Neo Car Jukebox (MP3 player), J&J stainless grill, Reunel Stainless bumper, 12000# Warn winch, PIAA lights, Bilstein shocks, Ultra Magnum wheels, Michelin tires (265/75-16), Correctrack rear wheel spacers, Bushwhacker flares (painted), Velvet-Ride spring shackles, p/s filter, external tranny and coolant filters, Wicked Wheel, Autometer gauges(5), 203 thermo, BRV+, removed air intake heater, Optima Yellow Tops, "Harpoon" mod, DP-Tuner, 4" exhaust w/ Aeroturbine, Airdog, HX-mod.
Next on the List: a blown tranny!
msnunes is offline
Old 09-12-2008, 08:28 PM   #23 (permalink)
Thanks! Mission accomplished! The filter is from these guys Silicone Hose, Silicone Hoses, Turbo Hose, Turbo Hoses, Intercooler Hose, Intercooler Hoses, T-bolt Clamps, they even have a bigger one but it won't fit under the hood. And to be completely honest I did question its smaller size at first, compared to AFE's and such, but I've ran it open without the filter around the neighborhood and noticed no difference. The end opening must be the difference. Either way though, I'm more than happy with the work they've done.
-Olyaee
Old 09-12-2008, 11:35 PM   #24 (permalink)
My Photos: (9)
Okay, now for the follow-up questions:
I take it you checked out other (maybe, more common) filter brands? What was the reason for going with that supplier? Does it happen to be compatible with other filters of that style (like for F-series or something)?
And how's the performance compared to your prior stock setup?
msnunes is offline
Old 09-14-2008, 08:41 PM   #25 (permalink)
brands?
yes
It was the house filter at Turbo Hoses which they designed and it's more than proven itself on all of their projects.
It'll fit and any round pipe with the proper diameter and clearance around it.
I installed an ATS housing, 4" exhaust and the intake in one big swoop so I never got to exclusively test the intake. With those three mods though the difference was very noticeable.
Old 09-16-2008, 09:19 AM   #26 (permalink)
anash13's Avatar
Will the "Inlet pipe" & "Filter" to the turbo be an "Off the Shelf" item in the near future?
Have you any idea on cost?
Great looking setup....I LIKE IT!!!
2003, E-350, XLT, Chateau, 7-Pass. Club Wagan, 7.3L PSD, 3:55 LS Rear, SuperChip, AMSOIL TS-126 Air Filter, Fleetguard LF-9027 Bypass Oil filter, Sirius Satellite Radio, Garmin GPS, SuperCrewzer, AutoMeter (Pyro. Trans. Boost)Gauges, 4" Diamond Eye Turbo Back Exhaust, Sonnax valve & Tricululator springs, PML Alum. Tran's Oil Pan, Tru-Cool 4739 Tran's Cooler, ScanGuage Monitor, DAHL 100 Fuel Filter, "Last of the 7.3's".
USMC-(Ret).
You Don't Always Get What You Want, But If You Try Some Times You Just Might Find, YOU GET WHAT YOU NEED.
anash13 is offline
Old 09-16-2008, 07:02 PM   #27 (permalink)
Yeah I'm not worried about it. Other than the filter media on the end cap, it's just a standard cone filter. I'm sure I could find an even larger filter that'll fit but this is the one they had and I'm pleased with it's design and performance.
Filter $60
Silicone 90 $125
velocity stack $120
Then add in the aluminum piping and labor rate around $120/hr to make it all fit. I was out the door for a pretty penny but with one simple *****in set up. I'll probably sell it one day since I plan on going with a whole new twin turbo intercooled set up; but that's a few years away.
Check out the welds, Christian did these and the others you see on their site.
Old 11-01-2008, 02:02 AM   #28 (permalink)
smitty333's Avatar
k&n makes a cold air intake for the e vans with a v10 (77-2570) ... it bolts to the firewall and front grill area ... i think im gonna get one of these and mod the intake tube to fit to the 7.3's turbo ???
what do yall think ?
2002 e 350 super duty, power windows, locks and mirors, custom interior, 20 in KMC xd spy wheels.
http://i45.photobucket.com/albums/f6...d-side-333.jpg
smitty333 is offline
Old 11-01-2008, 10:02 AM   #29 (permalink)
anash13's Avatar
Smitty:
That K&N unit looks promissing, I like it.
From the K&N web-site it looks like it would work.
Keep us posted
VERY GOOD IDEA
USMC-(Ret).
anash13 is offline
Old 11-01-2008, 02:27 PM   #30 (permalink)
smitty333's Avatar
heres a few pics ... this is of the v10 set up
im going to try to find the ford "intake scoop" (for lack of the correct term ?) that comes on the v10 and use it on my 7.3
i like how the unit contours and seams to seal to the underside of the hood ... keeping a true cold air intake is important
and then just work with some 4 inch tube and try to limit the bends to small angles... i will need to accomodate the sensor, but that shouldnt be a problem... just relocate it near where it was with the stock intake ??? i think ?
only thing i can see so far is that the rad might be different ?
anyone know where to get that ford air scoop thang ? ha ha .... i bet the dealer wants an arm and a leg ?
