Old 12-07-2002, 10:31 AM   #1 (permalink)
Altenator Output
I could use a little feedback.I recently had to replace the regulator on the 165 amp leece-neville alternator on my 90 E 350 retired ambulance.[I think I fried it with a careless jump start] Anyway,I had noticed that both batteries were "boiling" constantly indicating an overcharge.So using the manuals I did some testing with my multimeter doing the ignition on,off and running voltage checks.If I'm not mistaken I think the battery voltage was 12.36 and 12.34 and when hooked up and running it was up to something like 14.38 with the help of the alternator.I thought that was high untill I had the alternator in my hands where I could see the thing and on the regulator was a sticker that said something like replace with this number regulator and set to 14.25 volts.Well, I took it in for a complete rebuild and every thing seemed fine.But the next day whan I tried to start it again it cranked progressively slower and slower and of course woudn't start,so with a propper jump I got it started and did a voltage check and got a reading of 13.17. Sooo,does anybody have a similar alternator that knows what their voltage reading is while running?. I could be wrong,but I thought it was up in the 14's before the rebuild although I still dont know how the drop in voltage would cause the van's starting problems.The batteries still read o.k. Sorry to be so long winded,Thank You, James.
90 E 350 7.3 IDI N.A. 165 Amp Leece-Neville Alt K&N Lifetime Air Filter E4OD 4:10 Previously a Medical Transport Van,[It took folks from the convalescent home to see the doctor] 230,000 miles on the engine,can't see how the trans could be original but no upgrades.She don't smoke or burn any oil,they must have taken excellent care of it.All lights and flashers removed and patched.I've fallen in love with the ride,10,000 lbs.rides like a Lincoln.
jamessmith is offline
Old 12-07-2002, 08:54 PM   #2 (permalink)
My Photos: (13)
Re: Altenator Output
JAMESSMITH
You have to load test the batts.
Many batts will read a good voltage and have zilch for amperage.
BILL-MADVAN [img]/ubbthreads/images/graemlins/smokin.gif[/img]
97 E-350 Quigley Van Picts
Supporter/User of THE CURE E4OD/4R100 Transmission Control
WWW.FORDTRANSMISSIONCURE.COM
TO RENT THIS SPACE SEE YOUR ADMINISTRATOR
ads@thedieselstop.com.
MADVAN is offline
Old 12-07-2002, 11:18 PM   #3 (permalink)
An alternator should put out at least 13.8 volts. 14.3 is a tad high but ok. Since it's on the high side, probably because of the duty it was rated for, it's going to keep the batteries hot. Usually a careless jump start will knock out the regulator and not the alternator itself.
~ Pete ~
1999 E-350 PSD - Super duty cargo - 3.55 LS...Bilsteins, dual alternators, all power...125K miles - now with a new Jasper trans and torque convertor.
PJC99 is offline
Old 12-08-2002, 08:55 PM   #4 (permalink)
My Photos: (5)
I also have a Leece-Neville and my output is about 14.2. I replaced the regulator once because the voltage was fluctuating. It helped but after a while it was doing the same thing. I wound up replacing the alternator. The one I have now came with a lifetime warranty.
Cost was $195.00
Also by giving a bad jumpstart such as positive to negative and creating sparks you might have blown a diode in the alternator.
1991 Ford PL Custom Ambulance Type III 7.3L Diesel. Photo Here Pioneer AM/FM/XM/CD Stereo. Code 3 lightbar, Whelen Strobes and flasher lights. Whelen flood lights on front, rear and sides. There bright enough to turn darkness into daylight. Siren with several tones plus electronic airhorn and PA. Custom 3" exhaust from manifolds back with a Gibson Superflow Muffler [img]/ubbthreads/images/graemlins/grin.gif[/img]. Dual alternators and dual sets of batteries. If I need a jumpstart all I do is push a button. On spot tire chains that install and de-install themselves at the flip of a switch. Also has air compressor on board along with suction unit and O2 system.
1972 Cadillac Hightop Ambulance by Superior Lucky if I get 10MPG
CompuDoc is offline
