Ambulance Style Battery Box - Diesel Forum - TheDieselStop.com
Old 03-16-2003, 11:35 PM   #1 (permalink)
I've looked several times for battery boxes that you usually see on ambulances. The ones I'm looking for go right behind the drivers door and below the floor of the van. Does anybody know if you can find them "off the shelf" or custom made?
1991 E350 7.3 IDI with "bubble" top. Front and rear airbags, compressor, Hellwig rear sway bar, dual auxiliary fans over industrial radiator, Banks trans command, front suspension all polyurethane, after market A/C, a bunch of gauges, removed soup bowl, Holly Red lift pump.
airguy is offline
Old 03-17-2003, 09:03 PM   #2 (permalink)
My Photos: (17)
Re: Ambulance Style Battery Box
Next time you see an ambulance, find out who manufactured it. The boxes you are looking for were probably custom made for that specific ambulance. They would probably sell you one if you called and asked.
[img]/ubbthreads/images/graemlins/cool.gif[/img]2001 E-350 SuperDuty<font color="green"> 2wd Sportsmobile, <font color="green">BTS Trans, <font color="green">ITP VAN SPECIFIC fuel system mods,3.5" DP with 4"exhaust, 3 pos "Bill's" chip, Autometer Phantom gauges, Baldwin pre pump filter assembly, <font color="green">Reunel bumpers, Warn 9k winch, PIAA lights, Goodyear Wrangler AT/s tires (265/75 R16), Firestone airbags, <font color="green">Con-Ferr roof rack, Bushwacker Fender flares, <font color="green">Correctrack rear wheel spacers, Rancho 2" lift, </font><font color="orange">PHOTOS</font>
youngster is offline
Old 03-18-2003, 05:16 AM   #3 (permalink)
My Photos: (5)
Try PL Custom . The one that is in my ambulance is built into the body and rolls out in a drawer style.
1991 Ford PL Custom Ambulance Type III 7.3L Diesel. Photo Here Pioneer AM/FM/XM/CD Stereo. Code 3 lightbar, Whelen Strobes and flasher lights. Whelen flood lights on front, rear and sides. There bright enough to turn darkness into daylight. Siren with several tones plus electronic airhorn and PA. Custom 3" exhaust from manifolds back with a Gibson Superflow Muffler [img]/ubbthreads/images/graemlins/grin.gif[/img]. Dual alternators and dual sets of batteries. If I need a jumpstart all I do is push a button. On spot tire chains that install and de-install themselves at the flip of a switch. Also has air compressor on board along with suction unit and O2 system.
1972 Cadillac Hightop Ambulance by Superior Lucky if I get 10MPG
CompuDoc is offline
Old 03-26-2003, 10:20 PM   #4 (permalink)
Airguy,
These are custom built by the manufacturer.
You could order one of these from an ambulance manufacturer. They will usually want the unit number of the ambulance, and then they duplicate what was built for that unit.
Wheeled Coach (www.wheeledcoach.com) is the worlds largest ambulance manufacturer. They have pretty good service help than can give you part numbers. You would then have to cut out the side of your van &amp; weld the supports etc into place &amp; do any battery cable changes needed. Send me a pm if you need more help on the ambulance end, I have been in that business for many years.
2002 F-350 Lariat PSD 4x4 Crew Cab DRW LB SOTF
Vortex Liner, 3M Paint Protectant Film
Mor Powa !!!!
Check out - NOVAPS - Northern Virginia Power Strokes in the TDS Events forum
RocketRacing is offline
