Old 08-22-2008, 09:52 PM   #1 (permalink)
clev's Avatar
My Photos: (14)
another air intake question
Why is a cone type filter mod, with a scoop, better than the OEM. I read about them all the time and am contemplating starting a project next month to install one on my van. However, I had a friend ask me today, "Why"? I didn't have an answer except to say for better air intake which I could not substantiate. The twin K&N's have 2 unobstructed vents coming from the front of the grill so does the cone 'really' provide more air to the turbo?
'85 E-150 351w, factory order rcvd Oct. '84: Balanced/blue-printed, HYPEREUTECTIC pistons, matching edelbrock performer pkg: cam, lifters, intake, carb, & elec fuel pump. MSD pkg: MSD 6, billet distributor, timing control, & 8.8 wires; AirLift air bags, Deraler tubed trannie pan, FloMaster Exhaust w/duramax ceramic headers, new paint.
'99 E-350 HiTop Companion Van Conversion SD 7.3, factory order rcvd Dec. '98: SuperChip, twin K&N air filters, 203* mod, Deraler tubed trannie pan, B&M trannie cooler, AirLift air bags, Bilsteins, 4" DiamondEye turbo back exhaust.
clev is offline
Old 08-23-2008, 10:37 AM   #2 (permalink)
blageurt's Avatar
I think the "cone " shape is just that a shape , to better fit in the F series boxes / air raid/ whatever housings designed fot the f-series trucks. As you know aftermarket manufacturers don't give a rats ass about Econolines, since we are a very small market.
That being said many on this forum and other places have taken it upon themselves to rectify this. Blizzard and Sixiron have the simplest /best setup so far. It's all bout best bang for the buck. If I wasn't a roofer /tradesman I would do the scoop thing too. Unfortunately my truck is a mule, not a show horse, so I modify it in other areas like suspension / exhaust and soon Baby swamps. I am stickiing to the Ford 1618 deals which I buy by the case , and change them more often. When I have the time I will probably do the "T" cone thing and build a style of scoop /cowl Induction vibe, similar to the 70's Camaro's /Trans ams which will be "construction" proof. I am thinking Aluminium housing and Intake pipe like Blizzard. Six has not posted pictures yet so I can just Imagine what his is like. But he removed the stock filterbowl like Blizzard to incrase space. I don't think I will be doing that . . .
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , HD cooler , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " ,Not installed yet DP flashed PCM (60 Tow )Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is online now
Old 08-24-2008, 03:59 PM   #3 (permalink)
BlizzardVan's Avatar
My Photos: (18)
The shape of the filter medium doesn't matter it is the volume of air you get with the least amount of restriction. I have a 4" unresticted path back to my turbo. This whole process began because I was sucking the stock intake flat and killing the motor when I came up on boost. This is why the 4" wire wound hose was such a find.
Surface area wise, circular is usually more effiecent than flat or square for a given space. I use a large oval in the fiberglass scoupe/box I built. I still believe this is the best mod and necessary to get the full benefit out of all other engine mods.
Hypermax stage 2 injectors, 4" intake with Ram scoupe, QSSB Turbo, Snow Meth inj, BTS trans no spacer, Salem Kroger 4x4, Sway and traction bars, APX drivers seat, 4" straight exhaust & DP, 4" lift, 18" wheels with 325 nittos, custom valve Bilsteins, DP PCM and F5
...Stuff to make it almost as fast as a pickup.
BlizzardVan is offline
Old 08-24-2008, 09:14 PM   #4 (permalink)
My Photos: (9)
As another interested bystander, can you describe the improvement of your new intake over stock? Either seat-of-the-pants, or some other way?
2001 E350 PSD, Deep Emerald Green, 3.55 LS, Premium package, dual alts, rear A/C. Quigley 4x4, Transfer Flow rear tank (27+26), handicap mods, custom interior, Reunel tire carrier w/ Hi-Lift, Sportsmobile nerf bars (black), Amsoil lubes and Dual-Gard bypass oil filter, Amsoil air filters, Eclipse/JL Audio sound system w/ Sirius & 120GB Neo Car Jukebox (MP3 player), J&J stainless grill, Reunel Stainless bumper, 12000# Warn winch, PIAA lights, Bilstein shocks, Ultra Magnum wheels, Michelin tires (265/75-16), Correctrack rear wheel spacers, Bushwhacker flares (painted), Velvet-Ride spring shackles, p/s filter, external tranny and coolant filters, Wicked Wheel, Autometer gauges(5), 203 thermo, BRV+, removed air intake heater, Optima Yellow Tops, "Harpoon" mod, DP-Tuner, 4" exhaust w/ Aeroturbine, Airdog, HX-mod.
Next on the List: a blown tranny!
msnunes is offline
Old 08-24-2008, 10:49 PM   #5 (permalink)
clev's Avatar
My Photos: (14)
Thanks for the input guys, I really appreciate it. Still planning and still intend to start within the next few weeks. I'll photgraph each step and attempt to post.
clev is offline
Old 08-25-2008, 10:19 AM   #6 (permalink)
anash13's Avatar
Morning Gent's:
I also am looking forward to seeing some of these air intake mod's.
FYI: I am hitting the road at the end of the week, I shall be out for 12 days, about 1800 mi
I shall be keeping close track of fuel millage and cost for a report upon my return on or about the 9/11.
2003, E-350, XLT, Chateau, 7-Pass. Club Wagan, 7.3L PSD, 3:55 LS Rear, SuperChip, AMSOIL TS-126 Air Filter, Fleetguard LF-9027 Bypass Oil filter, Sirius Satellite Radio, Garmin GPS, SuperCrewzer, AutoMeter (Pyro. Trans. Boost)Gauges, 4" Diamond Eye Turbo Back Exhaust, Sonnax valve & Tricululator springs, PML Alum. Tran's Oil Pan, Tru-Cool 4739 Tran's Cooler, ScanGuage Monitor, DAHL 100 Fuel Filter, "Last of the 7.3's".
USMC-(Ret).
You Don't Always Get What You Want, But If You Try Some Times You Just Might Find, YOU GET WHAT YOU NEED.
anash13 is offline
Old 08-26-2008, 03:23 PM   #7 (permalink)
My Photos: (18)
Before I changed the intake I wasn't able to even drive the van very hard. The minute I put my foot to the floor the van would beging to take off and build boost then die. The stock plumbing would suck flat like a cheap straw because of the restriction in the stock system. It took me months to figure out what was going on. If you are going to really try to get into the 400 hp range with a 7.3 I think you should start with the air intake. Especially if you are going to up the turbo cfm.
