Is this any good? - Diesel Forum - TheDieselStop.com
Old 11-24-2009, 05:41 PM   #1 (permalink)
MOTOVAN808's Avatar
Is this any good?
FORD VAN 7.3 POWERSTROKE STAGE 2 HIGH PERFORMANCE TURBO:eBay Motors (item 220512519592 end time Nov-24-09 23:17:30 PST)
2002 E-350 ext. Fire survivor!! POWERSTROKE cargo w/divider...new blue paint, all panels dynamated, 220K
Rockin stereo Alpine, xtant, Boston Acoustics, JL Audio.
MOTOVAN808 is offline
Old 11-24-2009, 07:07 PM   #2 (permalink)
MikeL46's Avatar
My Photos: (14)
Interesting. He has 100% positive feedback and the price is low.
The rest you have to take with a grain of salt, as a salesman wrote it. In one place he says the turbo won't affect your mileage, later he says you will get improved mileage.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline
Old 11-24-2009, 09:10 PM   #3 (permalink)
blageurt's Avatar
I also was intriuged by his prices BUT I've never bought stuff from Puerto Rico . . .
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
