Best thing to plug Resonator hole in intake with??? - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 10-11-2010, 06:42 AM Thread Starter
My resonator is about worn through from banging on the top of the fuel bowl and I want to plug that port off. It looks like maybe a 2 1/2" port. Is there something people have used around here to plug those off with?
thanks!
-Ford E350 PSD 1995 --- 500k+ Upgrades-DIY Push Button Manual Shifting E4OD Computer-Stancor Glow Plug Relay-DIY Stage 1 Injectors-Cat Out-Bigger Rear Tires-DIY SD Electric Fuel Pump system
-98 Taurus 3.0 OHV --- 200k+ New H.Gaskets
-MB 300d Turbo Diesel(s): 1980, 84(x2),85, and 87 Fast, nice to work on, great machines. All outgrown and Sold
-GMC Suburban 6.2 Detroit - Slow. Reliable. Sold.
777funk is offline
post #2 of 13 (permalink) Old 10-11-2010, 10:32 AM
505live's Avatar
I got a threaded 2" PVC cap and rammed that in there (threaded b/c it has a shoulder on it). It has ~ 2.5" od, but it is a little tight. You might want to go the Blaguert route and use a piece of 2" PVC and put a cap on the end of it.
On a side note, I was a little surprised at how much the resonator apparently does. Time will tell if I put it back in, will depend on the drone on the fwy at speed. I road trip in this thing, and I've gone to some trouble to reduce NVH.
2003 E350 EXT 7.3L PSD, Bought September 2008 @76,000mi.
DP Tuner F5
Bilstein HD Shocks
Centramatic Wheel Balancers
Autometer Phantom Boost, Transmission Temp, and EGT gauges
Powertrax autolocking rear diff.
Scangauge II xgauge
Dahl 75 Pre-pump fuel filter/water separator
Modified Sinister Diesel fuel bowl delete and regulated return + post pump filtration.
Tow Mirrors
Spahl power remote door locks
Dieselsite Max AC Assist
Added cruise control
Sealed Beam to HID Headlight Conversion
Personal blog
505live is offline
post #3 of 13 (permalink) Old 10-11-2010, 04:53 PM
dieseldude73's Avatar
I'd patch the hole in the resonator with epoxy or RTV... I tried the pvc cap in the intake for about a week before I got sick of the noise. Its like the intake drone fights the exhaust drone and they resonate and echo inside the body of the van.
'96 E350 aka Vanna White, decommissioned @ 380k miles
'99 E350 Clubwagon, V10, 172k miles
'98 F150 Bi-fuel CNG, 184k miles
'06 Dodge Charger Daytona R/T, for my doppelganger, 72k miles
dieseldude73 is offline
post #4 of 13 (permalink) Old 10-11-2010, 07:29 PM Thread Starter
I never really notice much of the intake drone on mine surprisingly. But the engine is so loud in my van maybe it's drowning out the intake. I can hear the turbo whistle if I really hit it going up hill. But I like that sound! I usually stay out of it though. That's just wasted Diesel fuel whistling.
777funk is offline
post #5 of 13 (permalink) Old 10-11-2010, 08:36 PM
van_350sd's Avatar
My Photos: (80)
Does anyone have some photos of the Mods you did to it?
When I open the Doghouse next time I will take some photos
of how I insulated the Turbo with the Thermo-Tec Turbo Wrap
And as most of you know I wrapped my exhaust system complete from the turbo to the Tip, and even the Round Magnaflow Muffler with the 2" Heat Tape Wrap, Natural color.
It completely removed any and all drone in the system. It's amazing how quiet it is inside now.
It took 2 - 50' Foot boxes of the 2" I believe, I think I used 3 Boxes but I cannot remember, and 2 boxes of the Stainless band clamps, you cut the strap to your length and slide these connectors on them, great system.
After 7 Years of the Wrap on the exhaust, no problems at all. The wrap kinda repels the water off of it.
My van also has 2-3 layers of DynaMat on the inside, and DynaLiner, DynaPad. If you remove the two front door Panels you can install the 1/2" thick DynaLiner Black Foam and it will self-stick to the door panel you remove, then screw it back on the door. It will stick out 1/2" more but you don't really notice it very much and the road noise goes down so much. I also installed the Extreme Mat on the Inside door skins, but just doing the 1/2" DynaLiner to the door panels is the most bang for the buck. If you want to go more do the inside door skins. The Inside Doghouse has the extra 1/2" Silver sided Dynamat Under Hood Kit installed, it also helped a bit.
The exhaust heat tape wrap is so good, you can touch the wrap while the exhaust is hot, I only touched it near the tail pipe though. I'm sure at the downpipe it's much hotter.
2000 E350-Super Duty Ext. Mobile LivingRoom-7.3LPSD
van_350sd is offline
post #6 of 13 (permalink) Old 10-12-2010, 12:41 AM
goshen's Avatar
I used a 2" pvc street female adapter and a 2" threaded plug rtv'd into the adapter. made the installation stick out only a couple of inches from the intake tube. 2" pvc has an external diameter of 2 3/8" clamps in nicely. if you used ABS pipe instead it would probably look cleaner tho.
2000 E350 7.3 powerstroke Goshen Coach
Mods completed:
upped tire size to 235/85R16E's. With my 4.11 rear end, this gives me a new effective gearing of 3.80
4" Diamond eye turbo back straight pipe
4-5" Bully Dog SS elbow exhaust tip
Bean's Stage 1 injectors
TS 6 position chip
Bean's custom tunes
Modded IDM module
Mods in progress:
battery relocation to rear drivers side
belly toolbox
Reese hitch
Follow my progress:
goshen is offline
post #7 of 13 (permalink) Old 10-12-2010, 03:42 PM
I also wrapped the exhaust system, did the up pipes from the manifolds too. It really brings down the noise and heat in the cab, best part is, I can still hear the turbo too (thats really the only thing I wanna hear)!
post #8 of 13 (permalink) Old 10-12-2010, 08:26 PM
van_350sd's Avatar
My Photos: (80)
So did you use the Schedule 40?
I believe it's rated at 140 F, or something like that.
How many inches long is the pipe?
Anyone have pics of this mod?
post #9 of 13 (permalink) Old 10-12-2010, 08:46 PM
Feedback Score: 2 reviews
Im pretty sure I just used a pvc cap. If I can find the stock tube, I will take a pic.
2003 E-350 7.3, 38R, DIY intake, 4" turbo back, Swamps Tunes, forged rods, exhaust ported heads, comp 910's, h-11's, stealth twin pumps, 300cc hybrids, racerx trans and tc, water injection
rpm1 is offline
post #10 of 13 (permalink) Old 10-13-2010, 12:33 AM
goshen's Avatar
yeah sorry, 2" sch 40 pvc pipe has a 2 3/8" outside diameter. sch 80 has the same outside diameter. 80 has a smaller internal diameter, they both can use the same fittings.
If you use the cap with an adapter or the cap by itself, make sure you seal the threads with silicone, but not so much that any gets into the intake.
Mods completed:
TS 6 position chip
Bean's custom tunes
Modded IDM module
Mods in progress:
belly toolbox
Reese hitch
Follow my progress:
goshen is offline
post #11 of 13 (permalink) Old 10-13-2010, 07:37 AM
drinkypoo's Avatar
My Photos: (25)
I like to seal threaded connections I might want to remove again with Rector Seal #5. It's fuel-safe including diesel.
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #12 of 13 (permalink) Old 10-16-2010, 01:39 AM
MOTOVAN808's Avatar
The intake resonator is easily bypassed with a chew can. Call me a redneck for knowing this, but the one i used fit just right and it was hard plastic. I put a clamp on it for good measure and it sealed well...but in a pinch a Mt Dew can fits too.
I found the ride a bit noisey, so i put the resonator back on.
2002 E-350 ext. Fire survivor!! POWERSTROKE cargo w/divider...new blue paint, all panels dynamated, 220K
Rockin stereo Alpine, xtant, Boston Acoustics, JL Audio.
MOTOVAN808 is offline
post #13 of 13 (permalink) Old 10-16-2010, 04:21 AM
goshen's Avatar
if you use the soda can don't drink it first! If it's unopened you can clamp harder on it...
Mods completed:
TS 6 position chip
Bean's custom tunes
Modded IDM module
Mods in progress:
belly toolbox
Reese hitch
Follow my progress:
goshen is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > E-Series Vans
