Old 04-16-2006, 10:06 PM   #1 (permalink)
My Photos: (9)
bigger dia. tires?
I have a C6 with 3.54 final drive. The stock tires are 235/85R16. Are there bigger tires that I can put on the stock steel rims to increase hwy fuel economy? What are the pros and cons? TIA
88 E350 7.3 C6 154k
done: Remanufactured Inj pump, New Stanadyne injectors, Michelin M/S tires, ShellZone AF & Fleetrite SCA, replaced and relocated fuel filter assembly, elec fuel pump, no flying saucer, return lines/ o-ring kit, new heater core, 8 Beru glow plugs, oil & filter, stabilator on sliding door (plastic slider cracked in half)
Hot compression readings:
2. 500 1. 500
4. 460 3. 420
6. 540 5. 465
8. 480 7. 540
to do: transmission fluid, fix rust spots, WVO conversion.........
nubiecanobie is offline
Old 04-16-2006, 10:39 PM   #2 (permalink)
Re: bigger dia. tires?
Those are the tallest tires that will fit in the wheelwells. Stock tires on the vans (at least mine) are 245/75R16, so the 235/85's are taller than the stock tires.
Your least expensive option is to swap in a rear axle with a higher (numerically lower) ratio. Although I'm not sure if you will find stock gears higher than 3.54 in a 1 ton axle. I've seen 2.79 and 3.00 axles in Fords, but those were 1/2 tons.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
