Old 05-23-2007, 04:21 PM   #1 (permalink)
Blue smoke......
During a burn out (competition) last weekend a big bang (like blowing a tire)came from under hood.... Idle got crappy like running on 7? and tons of blue smoke from the exhaust. Let it cool down for a short time and fired it up again. Voila - idle's fine and no more blue smoke, so i hit the track again [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
However- the last couple of days i've noticed a litle blue cloud from the tail when going off the fun pedal. I've checked the oil level and it clearly consumes a litle.... Idle's just fine, and motor's pulling strong as usual. Can this somehow be injector related? Or turbo? (Boost# normal - 32-35psi)
Ideas most welcome [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Øystein
98 E350 PSD Cargo "Under construction"
F5 DP Tuner (10 pos)(mounted on a-pillar) w/pane files -PS 2000 -SC 1705 (code reader) - Snow stg 2 - 3xUltraLites in a-pillar - 3x UltraLites on dash -4"Magnaflow (15970)turbo/back -4" DIY AFE intake -ITP overboost kit. Detroit locker.
And the hottest mod so far: Tranny built by RATS, BIG thanks to Ole Ringstad
TC lock-up switch, Jingle bells killed, Excursion gauge cluster (tack).
Waiting to be mounted: roll cage, Two garret gt3782bb - real twins.
Working on: brackets to relocate alternator, sidepipes. AC and vacuum pump delete (for space)
Headers, and a second HPOP
437/1116Tq Dyno
PICS: http://community.webshots.com/album/346517884jXrDba
70' Mustang FB 408 stroker... Is it possible to sqeeze a PSD into this one? Hmmm
oystein is offline
Old 05-23-2007, 07:51 PM   #2 (permalink)
My Photos: (17)
Re: Blue smoke......
loud bangs tend to point to broken parts. Might want to see if you can have a compression check done.... Blue smoke at the tail pipe indicates oil is being burned in the combustion chamber. It is either coming in from the rings (piston) or the valves (guides,broken spring, stuck valve). The comp check will find any of these problems. I would think that turbo related would sound really loud in a van as the turbo is right next to the driver.....
just some thoughts.
youngster
[img]/ubbthreads/images/graemlins/cool.gif[/img]2001 E-350 SuperDuty<font color="green"> 2wd Sportsmobile, <font color="green">BTS Trans, <font color="green">ITP VAN SPECIFIC fuel system mods,3.5" DP with 4"exhaust, 3 pos "Bill's" chip, Autometer Phantom gauges, Baldwin pre pump filter assembly, <font color="green">Reunel bumpers, Warn 9k winch, PIAA lights, Goodyear Wrangler AT/s tires (265/75 R16), Firestone airbags, <font color="green">Con-Ferr roof rack, Bushwacker Fender flares, <font color="green">Correctrack rear wheel spacers, Rancho 2" lift, </font><font color="orange">PHOTOS</font>
youngster is offline
Old 05-24-2007, 04:04 PM   #3 (permalink)
Had a compression check this morning. All of them is 480-500psi except of #6 being 420psi. The tech says that's normal / ok.
437/1116Tq Dyno
oystein is offline
Old 06-04-2007, 04:10 PM   #4 (permalink)
Oh, I know where the loud bang came from - (at least i think i know)
The filter element "exploded" [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/blush.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
I can't belive i didn't see that at once [img]/ubbthreads/images/graemlins/blush.gif[/img] [img]/ubbthreads/images/graemlins/blush.gif[/img] [img]/ubbthreads/images/graemlins/blush.gif[/img] [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
437/1116Tq Dyno
oystein is offline
Old 06-05-2007, 10:01 PM   #5 (permalink)
BlizzardVan's Avatar
My Photos: (18)
This is why intake is so important in our vans. As soon as you turn up the power a little the stock configuration just doesn't cut it. Good luck with the fix. Glad that is all it was. Did Van eat any of the filter?
Hypermax stage 2 injectors, 4" intake with Ram scoupe, QSSB Turbo, Snow Meth inj, BTS trans no spacer, Salem Kroger 4x4, Sway and traction bars, APX drivers seat, 4" straight exhaust & DP, 4" lift, 18" wheels with 325 nittos, custom valve Bilsteins, DP PCM and F5
...Stuff to make it almost as fast as a pickup.
BlizzardVan is offline
Old 06-06-2007, 10:45 AM   #6 (permalink)
No, I don't think so. The filter blew open all the way from front to back... It doesn't look like any parts missing [img]/ubbthreads/images/graemlins/shrug.gif[/img]
BTW This was one of my AFE pro guard7 filters!!! [img]/ubbthreads/images/graemlins/confused.gif[/img]
437/1116Tq Dyno
oystein is offline
Old 06-06-2007, 11:54 AM   #7 (permalink)
My Photos: (13)
Did you figure out why it flamed in the intake?
Maybe it was valve float? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Bill
97 E-350 Quigley Van Picts
Supporter/User of THE CURE E4OD/4R100 Transmission Control
WWW.FORDTRANSMISSIONCURE.COM
TO RENT THIS SPACE SEE YOUR ADMINISTRATOR
ads@thedieselstop.com.
MADVAN is offline
Old 06-06-2007, 05:56 PM   #8 (permalink)
Bill
I have no clue, but maybe you're into something.
All i know is that it was not related to propane. (Not alowed in the competition - even had to remove the tank..)
437/1116Tq Dyno
oystein is offline
Old 06-06-2007, 06:28 PM   #9 (permalink)
My Photos: (13)
Was thinking float. Due to filter blew outwards.
Flame could have been chasing the air with all the fuel.
Just a WAG.
Bill
MADVAN is offline
