Brake Hoses 2003 E350 - Diesel Forum - TheDieselStop.com
Old 07-24-2007, 09:07 PM   #1 (permalink)
XRACER's Avatar
For what it's worth......
I just had to replace my bulging right front brake hose, and found that the part is on national back order. I had to go to Raybestos for it.
I figure that it really should have lasted longer than 50K miles, and the fact that you can't even buy one from Ford should tell you something.
Might want to check yours now.......
2005 E350 Standard Cargo Van, 6.0 PSD, 4.10 L.S., Quigley 4X4 New on 11-18-05
(seems to manufacture oil...)
Warranty Turbo 7-07 22,000 miles, Warranty A/C compressor 10-07 25000 miles
2003 E350 Extended Cargo Van, 7.3 PSD, 3.55, Quigley 4X4 New on 2-1-04
Some Pix
New Pix 9-12-2010
Transfer Flow 46 Gal*Delaminated*Replaced 8-06 UNDER WARRANTY
7.5' Western Snow Plow
BTS Tranny 9-29-07 @55,000 miles, Aluminess Bumpers, Mile Marker 12,000 pound hydraulic winch
2000 F250 ...... just cuz people are dumping them for the fuel bill. Got mine on ebay for $8749 with 116K on the clock.
1-1-09 BTS Tranny, 500+ HP at the rear wheel
XRACER is offline
Old 07-24-2007, 10:09 PM   #2 (permalink)
MikeL46's Avatar
My Photos: (14)
Re: Brake Hoses 2003 E350
I noticed in your signature that your van seems to manufacture oil. It is probably excess fuel diluting the oil. I would take that one back to the dealer for investigation.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline
Old 07-24-2007, 10:11 PM   #3 (permalink)
XRACER's Avatar
I did. They replaced the turbo. [img]/ubbthreads/images/graemlins/confused.gif[/img]
I'll check again in 3000 miles......
Some Pix
New Pix 9-12-2010
XRACER is offline
