can i get some help with these codes??
i am pulling these codes.
P0113 - intake air temp circuit high input
P0705 - transmission range sensor circuit malfunction
as for the air temp code i did check to make sure that the sensor was plugged in..but as for the tranny code...is that the black flat thing on the drivers side of the tranny where the shifter rod/cable goes to the tranny??
thanks in advance as always boys.
2000 E-350, all stock except for a edge programer.
over 1,300,000 kms
located north of toronto, ontario
