center console for obs van - Diesel Forum - TheDieselStop.com
Old 03-07-2007, 11:29 PM   #1 (permalink)
I remember when I ordered my van many yrs ago, I couldnt get the center console with a 7.3 . I have seen them on trucks and looked like they might fit. Has anyone ever installed one? It is the extra piece that goes on the dog house.
Dann
My Mods http://community.webshots.com/user/sconure
1996 E-350 , Bean's stage 2 injectors, 3" intake plenums, dual EGT gauge, boost, tranny, fuel pressure gauges.
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 03-08-2007, 08:37 AM   #2 (permalink)
My Photos: (15)
Re: center console for obs van
Do you mean the cup holder,map holder that hooks on top of the dog house cover?
1998.5 E350 7.3 extended cargo with Late model doors ,po.wer windows, locks and mirrors.Isspro gauges from DPPI, Power Slot Cryo rotors from DPPI, Hawk LTS from DPPI,NAPA DOT 4 brake fluid,NAPA calipers,Evans coolant,Dieselsite ac control valve,Dieselsite 203* thermostat,BTS valve body, Amsoil tranny fluid,4WD deep tranny pan from Dieselsite, DieselSite transmission bypass filter,Amsoil dual oil filter, Amsoil 15-40 wt oil,4 inch Warpspeed Performance exhaust,Thermo-Tec Exhaust Insulating Wrap, Bilstein shocks,Line-X 2-06-2009 103,400 miles following added Beans stage II single shot injectors, Air Dog, Beans regulated fuel return with fuel bowl delete, glow plugs and Stancor gp relay, Beans modified IDM, Stealth HPOP stage I, Dominator 66 turbo, DpTuner reflashed factory pcm that was split shot injectors to the single shots, 9 tunes from DP Tuner including decel tune,tuflocs on all doors, Snow water-methanol injection stage 3 installed by Beans Diesel, BTS tranny
mtnbiktn is offline
Old 03-08-2007, 09:20 AM   #3 (permalink)
The drink launcher?
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
Old 03-10-2007, 01:48 PM   #4 (permalink)
I don't know if it was the whole dog house or an extra piece that attached to the dog house. At the time I ordered, the salesman told me it wouldn't fit with the diesel. It has map holder and cup holder on the dog house. I have seen them on other vans although not diesel.
Dann
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 03-10-2007, 09:56 PM   #5 (permalink)
My Photos: (15)
Does your engine cover have two knobs sticking out of it so that the cup holder could be attached? A pic would help.
mtnbiktn is offline
Old 03-11-2007, 02:14 PM   #6 (permalink)
Everything on my doghouse is smooth all around. No knobs sticking out. Only storage area is on top of dog house with some of it under ash tray. So basically indentations on top of house. What I was talking about is an add on or original that had a map holder and cup holder that was on the main side of dog house facing rear of van. I dont' have any pics of it. Do any of you have pics? Maybe you guys have what I am looking for. I would love to buy one, but was told it didn't fit. If it does,I would get one.
Dann
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 03-11-2007, 02:52 PM   #7 (permalink)
blageurt's Avatar
You have to go to a Junkyard and take one off a Window Van. It just bolts to the doghouse. On my last junkyard quest I almost bought one but decided against it due to center access reasons.Plus on my last Van all it did was provide more places for me to lose stuff in.
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 03-11-2007, 09:27 PM   #8 (permalink)
SIC-E's Avatar
dann,
try: winegardner sales lima, ohio 419.227.9047 they also go by j&g auto on ebay. barns full of stuff from conversion company take-offs. good luck
2004 E450 Cutaway, 6.0L, quigley 4x4, ambulance pkg., maxbrake controller, curt 20k fifth wheel. Future mods: 52" sleeper, tandem (6x6?) rear (aint look'n likely), frame cover. maybe a Herd front bumper.
2003 E350, 7.3l, x-cargo
2003 F350 Lariat, 4x4, CC, SRW, Dark Green Fx4 SOLD
1995 C3500 6.5l work trk, 2x4, CC, DRW, white DECEASED PREMATURALLY
2003 JEEP WRANGLER, ooooops, not anymore!
1986 26' Seaway Northstar w/ 454 Mercruiser
2008 Montana Mountaineer 332PHT
1991 GMC Topkick, CAT, 4' vert. gang boxes, 12' dump. if only all were as reliable!
SIC-E is offline
Old 03-11-2007, 10:37 PM   #9 (permalink)
Good leads, thanks guys. Now I know that they might fit. I don't mind about the access to rear, as long as I can still get dog house off with no problem.
Dann
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
