Old 01-05-2009, 04:28 PM   #1 (permalink)
Change to gold and new hoses
Well, I've finished off the case of additive I bought a long time ago and will finally make the change to gold (HOAT) antifreeze in my 02 E350.
At the same time it will probably be prudent to change out the hoses. Where is everyone buying their coolant hoses these days? My local Autozone supplies them but needs to know if I have an engine oil cooler hose in the lower radiator hose. I guess I can figure it out. Guess I'll replace the heater hoses at the same time.
What about thermostat and housing? Suggestions?
I have 106K at the present time. Have had no problems and the hoses all "look" OK.
However, I believe it's time.
My plan is to drain it and fill with water a few times and then change out the hoses and fill with distilled water until I get down to the nearly all distilled water level and then add the antifreeze.
Has anyone had any problem getting the block plugs out?
Yardbrew
America....love it or leave it
02 E350 PSD Cargo with windows/power/CC/3.55 LS/Prodigy/Reese WD & Dual Cam/....from Cochise
Van Color:Gray--Bumper Color:Gray--Wheel Color:Gray--Hubcaps:metallic--Tire Color:black--Grill Color:gray plastic
I pull a 1987 Wells Cargo Express Wagon (20 ft)
Yardbrew is offline
Old 01-05-2009, 06:11 PM   #2 (permalink)
I had to replace my water pump about 10 months ago which meant pulling my radiator. I flushed the radiator and cooling system, replaced all hoses, serpentine belt, idler pulley and the belt tensioner since I had everything open and easy to get to. I just replaced the thermostat and gasket since the housing was in excellent shape.
It took me a little while to figure out how the quick connects worked on the heater hoses, but it wasn't too bad once I figured them out.
Bill J., Lexington, KY
2000 Excursion Ltd 7.3 PSD
2000 E350 Super Duty 7.3 PSD
whjco is offline
Old 01-06-2009, 12:24 AM   #3 (permalink)
van_350sd's Avatar
Sounds like a plan.
I have had great luck with very high quality hoses from Marine Stores, like West Marine. The Yacht/Boating fuel & water hoses have higher standards and ratings than the automotive hoses. They always have killer Good Year and other brands, many with double layer braids/systems.
It's worth a look if there is a West Marine nearby.
best Scott
2000 E350-SS-ExplorerExt.MobileLivingRoom-7.3LPSD-3:55LS-SCT1705-DualAmsoilEaAAirFiltersFleetGuardWF-2077CoolantFilter-AutoMeterPhantomGuages-Pyro-Boost-Tranny+HobbsHourMeter-4"SSMagnaFlowWrappedw/Thermo-Tec2"HeaderTape-SonnaxValve+TricumulatorShiftSprings-Mag-HytecTranny+RearEndCover-1UpFrontSpringOption-Bilstein's-Centramatic's-35GallonMainTank+TraxII TransferFlow27GallonAft.Aux.Tank=62GallonRange-ACPM/AIC-DualBattery+Alt-FilterMAG-Fumoto-ALLAmsoil-Alcoa's-ExplorerConversionInstalledDynaMatCompleteInterior-4LeatherCaptainChairs/BackSeat/Bed-InflatableAerobed-19"SharpLCD-DVD-KVHTrackVision-SAT/NAV-Garmin Nuvi 750-WalnutCabinets+Trim-3000 Watt Inverter-BioVault2.0GunSafe+400 RDS-2xDINPioneerDVDHeadw/Backup+SideCams-Cobra29LTDBT-300WLIN-NovaULTRA-PAK1858Strobes-InteriorLEDLights-FiberStars-UnderCarrige+DogHouseSoundProofing-RainXWipers-Bob'sACValve-MagnaFine-3MCoatings-HellaHorns-TintedGlass-FirstAid-H3RCleanAgentHalotron2.5#-SureFireLights-48"Hi-Lift-C02PowerTank5#SnapOn1/2"ImpactMG725
van_350sd is offline
Old 01-09-2009, 08:48 PM   #4 (permalink)
van_350sd's Avatar
Here is a place that has the blue silicone hose, I'M going to replace some of my hoses with the blue hose soon. They use the blue silicone hose on most of the P71 Crown Vic's in the Police Cars.
I'M also going to have my serpentine belt replaced. Better to replace it before it breaks, gets old and cracked after 8 years.
Hoses & Fittings -- Fleet Oil and Truck Supply - Heavy Duty Truck Parts
This hose holds up well.
Old 01-10-2009, 02:25 PM   #5 (permalink)
My Photos: (28)
With the changing of the hoses, what about the clamps?
The dealer replaced the water pump for me awhile back(only ones with the tool to pull the fan..) and reused the hose clamps from the factory. Now that it is -25 and has been for the last few weeks there is a leak down around the lower hoses..
Dealer says that there is no problem reusing the hose clamps from the factory, but every one that I have talked to about it says replace them...
Thoughts on this from members?
IT IS MINE ALL MINE.....(The Van that is, it has been Released by Lenholder)
It is a Very wet fall. Might need Hip waders. Next on the list is Snow, and that could be any day.
2000 E350 7.3PSD, Hellwig Stablizer bar, Headlight Harness upgrade 265/75/16E, 140 Lightforce w/blue, yellow, clear covers. My Photos http://photos.thedieselstop.com/showgall...&stype=&ppuser=
"FAILURE IS NOT AN OPTION"
Alaskapsdvan is offline
