Check Rear Axle Endplay - Diesel Forum - TheDieselStop.com
Old 02-21-2003, 10:08 AM   #1 (permalink)
One of the service points at 30,000 is a check of rear axle end play.
I have the shop manual on CD and cannot find the procedure.
The one example I found is part of a rear differential assembly process using dummy bearings, removal and reinstallation of shims, etc.
When I take my van in to the local F**D folks for the 30K service, how are they going to check rear axle end play?
The reason I ask is that I might clean forget to take it in and end up doing the entire 30K service myself.
I have a nice set of dial indicators with a good magnet. Can you just remove the calipers and check it by hand. It doesn't say backlash or runout........just end play.
I guess I'm asking mainly for numbers. It must develop some acceptable slop over the first 30K miles
Thanks in advance,
Yardbrew
America....love it or leave it
02 E350 PSD Cargo with windows/power/CC/3.55 LS/Prodigy/Reese WD & Dual Cam/....from Cochise
Van Color:Gray--Bumper Color:Gray--Wheel Color:Gray--Hubcaps:metallic--Tire Color:black--Grill Color:gray plastic
I pull a 1987 Wells Cargo Express Wagon (20 ft)
Yardbrew is offline
Old 02-27-2003, 03:44 PM   #2 (permalink)
Re: Check Rear Axle Endplay
Ever figure anything out about this? I am wondering also about this. Mine has a definite sound now that really sounds like something is going on with the rear axle.
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 02-28-2003, 02:28 PM   #3 (permalink)
I just posted over in the 7.3 Eng and Drivetrain forum.
Will see what happens.
Yardbrew
Yardbrew is offline
