compound turbos? - Page 5 - Diesel Forum - TheDieselStop.com
Old 02-04-2008, 05:34 PM   #61 (permalink)
Wow, that is cool.
2003 E-350 7.3, 38R, DIY intake, 4" turbo back, Swamps Tunes, forged rods, exhaust ported heads, comp 910's, h-11's, stealth twin pumps, 300cc hybrids, racerx trans and tc, water injection
rpm1 is offline
Old 02-05-2008, 08:11 AM   #62 (permalink)
Trying to figure out which side is transom & where the power out put is? Is the exhaust exiting out the side of craft? Are the 2 engines connected together then to power output? What kinda boost do they average?
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
Old 02-05-2008, 08:20 AM   #63 (permalink)
The transom is where the exhaust exits. They are each connected to their own outdrive.
Sea-Pro Marine - Mercury Marine MerCruiser Diesel - D7.3L D-Tronic LD
rpm1 is offline
Old 02-05-2008, 08:49 AM   #64 (permalink)
My Photos: (10)
RPM
It was another way i looked at to do a install.
The induction will fit in the van.
Just thew it out for you to see.
That motor was rated at 300 crank hp, with rpm of 36 to 3800
Its also is 2 points down on compression.
Bill
MADVAN is offline
Old 02-05-2008, 09:08 AM   #65 (permalink)
Originally Posted by MADVAN View Post
RPM
Bill
I understand that, thanks. That would be neat but awfully pricy. New that aftercooler setup is about 6k! Using just that manifold and a fabbed aftercooler could be doable, though.
I am still undecided on how it is going to get intercooled. I want to get the 47 mounted on a bracket and go from there. The weather is not cooperating with me. Supposed to get another 6-12" tonight.
rpm1 is offline
Old 02-05-2008, 09:20 AM   #66 (permalink)
My Photos: (10)
Yeh. Merc is nuts. Pricing is a joke.
Its over $3000 for a IDM.
Mercruiser Parts - StemToStern.com
Bill
MADVAN is offline
Old 02-06-2008, 08:15 PM   #67 (permalink)
Hey RPM, ;will a 99 pedestal fit a 96 engine?
Thanks, Dann
My Mods http://community.webshots.com/user/sconure
1996 E-350 , Bean's stage 2 injectors, 3" intake plenums, dual EGT gauge, boost, tranny, fuel pressure gauges.
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 02-06-2008, 10:18 PM   #68 (permalink)
I believe it will. But there is an early 99 and a late 99-03 pedestal. The early 99 may be the same one you have.
rpm1 is offline
Old 02-07-2008, 08:09 AM   #69 (permalink)
I will have to check and take pics. You were saying you wanted to sell yours later?
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 02-07-2008, 08:16 AM   #70 (permalink)
RPM, does yours look like this one?
eBay Motors: turbo mount pedistal ford 7.3 powerstroke turbo diesel (item 120218145513 end time Feb-07-08 1555 PST)
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 02-10-2008, 07:29 PM   #71 (permalink)
Well I won this a/w on egay. eBay Motors: Water To Air Intercooler 12 x 12 x 4.5 1000HP New (item 250211830920 end time Feb-07-08 20:08:43 PST)
I will do pressure and temperature drops across the intercooler. If it works, great. If not I guess I will cut off the end tanks and have a good core welded in. Still not sure where I will mount the heat exchanger, and what type of pump.
Hopefully this week I can get the 47 mount mocked up. Here is what I had in mind.
Excuse my bad paint skills!
The support will be welded to a 1/2"? plate that bolts between the top 2 trans bolts.
Comments, suggestions?????
rpm1 is offline
Old 02-10-2008, 08:13 PM   #72 (permalink)
Not sure why I can't get the ebay link to work, but here is a pic from the auction.
I will pressure test it before it sees any boost or water!
rpm1 is offline
Old 02-10-2008, 08:57 PM   #73 (permalink)
My Photos: (10)
Cool.
Do you have some specs? Max cfm, pressure drops ect.
Thats about the configuration i was looking at. Just liquid lines on the other end.
Bill
MADVAN is offline
Old 02-10-2008, 09:20 PM   #74 (permalink)
No specs. Here is the text from the auction.
<h1 class="style8" align="center">Welcome to Jat-Racing
</h1>
Water/Air Intercooler New!
Brand new Water/Air Intercooler. Core dimensions 10 inches x 5 inches x 4.5 inches thick for maximum cooling, overall Intercooler size 12 1/4 inches long x 12 inches wide x 4.5 inches thick . Perfect size for custom applications. Inlet/Outlet 3 inches , weighs empty 10.8 lbs, HP Rating 1000HP, Bar & Plate Core, Water in/Out is -10An fittings that are included with this sale. Additionally two holes are threaded on the sides for custom made brackets (No brackets included, nor any mounting hardware), the side holes are threaded for M10 screws. This intercooler is cast aluminum with polished finish. Great Water to Air IC at a real affordable price. You get exactly what you see below. 3 year warranty trough us against manufactuer defects. These are manufactured overseas for us by a professional Coolers/Radiators company that we know and trust. get yours today limited quantities available.
It was 100$ shipped, so I am not expecting too much from it.
rpm1 is offline
Old 02-10-2008, 09:38 PM   #75 (permalink)
My Photos: (10)
Originally Posted by rpm1 View Post
It was 100$ shipped.
Bill
MADVAN is offline
Similar Threads
Compound Turbos "X" Project DART505 Upgrades and Aftermarket - 99 & up 7.3L Engine 5 04-30-2006 05:15 PM
Turbos for compound charging clamgulch Upgrades and Aftermarket - 99 & up 7.3L Engine 78 02-19-2006 11:51 AM
Newer turbos quieter than older turbos? RobParks1 6.0L Power Stroke Engine and Drivetrain 3 11-17-2005 06:34 PM
Newer turbos quieter than older turbos? RobParks1 Upgrades and Aftermarket - 6.0L Engine 0 11-17-2005 12:20 AM
