compound turbos? - Page 9 - Diesel Forum - TheDieselStop.com
Old 05-15-2009, 11:18 PM   #121 (permalink)
blageurt's Avatar
Carful not to put some new picture windows in that nice block you currently have . . .
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 05-16-2009, 12:41 PM   #122 (permalink)
Originally Posted by rpm1 View Post
Quoting myself, somehow a set of 300's made it under my valve covers.
Looking for 575 now.
Blag-Thanks, I am leaning towards aluminum.
575+ sounds all good and well, but what kinda torque #s are you tinking??? That's what I'd like to see.
2002 E350, ext cargo, 7.3, 215K. 'Slash'
DP-Tuner (no start-stock-80 tow-decel-80 economy), Diamond Eye 4" turbo back w/muffler, Amsoil air filters.
2000 XJ heavily modded. 'Daisy'
2008 Suzuki B-King 'Cash' RED DRAGONS
Crunch406 is offline
Old 05-16-2009, 06:40 PM   #123 (permalink)
Not sure. Guessing around 900-1000? Swamps is pretty good at keeping the torque down to keep engines together. There are several 600+ horse stock engines out there with swamps tuning.
2003 E-350 7.3, 38R, DIY intake, 4" turbo back, Swamps Tunes, forged rods, exhaust ported heads, comp 910's, h-11's, stealth twin pumps, 300cc hybrids, racerx trans and tc, water injection
rpm1 is offline
Old 08-07-2009, 09:56 AM   #124 (permalink)
Slowly but surely............
rpm1 is offline
Old 08-07-2009, 09:57 AM   #125 (permalink)
rpm1 is offline
Old 08-07-2009, 06:58 PM   #126 (permalink)
blageurt's Avatar
Nice fabrication , hope it works as good as it looks . . .
1990 KX500
blageurt is offline
Old 08-08-2009, 07:10 AM   #127 (permalink)
Thanks Blag. I made a few tweaks from the pictures and it fits real well now. I also took that top piece off and put on another one with a big hole cut in it to see how it fits from the inside. It's tight to the downpipe and wastegate tube so I have to add some bulges in those spots. Still have to fill in the top front, then get it tigged up. Screw holes will get welded and ground smooth. Also need to add some kind of cupholders and laptop mount.
rpm1 is offline
Old 08-08-2009, 08:50 AM   #128 (permalink)
VISIONQUEST's Avatar
nice
nice work looks like progress i was wondering whaat happened to your project you might want some insultaion in that bad ass motor cover for knocking down the sound , but im sure you no that , i cant wait to see the finished unit
4x4 quigley 2001 e350 psd 3.55 posi front & rear/ insulated fully/ all power/ 4flex steel 6 way heated/rear removeable leather captain chairs / carbon fiber dash cover/ 2000watt rockford fosgate sound system system12 speakers/scmt/magna flow complete from turbo back/carbon fiber gauges auto meter trans,boost,exaust pre/isspro tack/crime stopper alarm remote start stop /towing package/
Custom Pro Built Trans steel planets tripple disc Red Eagle discs hardend input & drive drum /
W/A Intercooler... SIngle shot stage 2
2001 E350 4.10 all stock cargo 140k
VISIONQUEST is offline
Old 08-08-2009, 02:32 PM   #129 (permalink)
Thermotec makes a heat and sound mat called the suppressor. I will do one or 2 layers of that inside.
rpm1 is offline
Old 09-08-2009, 10:47 AM   #130 (permalink)
any progress
any progress got her done yet?
Old 09-08-2009, 09:17 PM   #131 (permalink)
Unfortunately no. Time and money...... Still need to finish the doghouse, get the wastegate flange welded on 38r, fab the dump tube, make some sort of box to mount an air filter under the van, run the oil lines for the 47, get the water pump, heat exchanger, and reservoir for the a/w, get everything welded up. So close yet so far away. Probably gonna add another a/w for the second stage, but I can do that down the road. I'd love to get it done before the track closes, but its not looking good at this point.
rpm1 is offline
Old 10-25-2009, 10:57 PM   #132 (permalink)
A little more progress. Got a fuelab pump and made a bracket out of aluminum.
Also picked up a fuel tank. Not sure if I will just do a 5/8 pickup or sump it. I will also shorten it to make room for a transfer case.
26x7x3.5" heat exchanger for the air/water cooler fits well inside the front bumper. Need to get some ears welded on and I can use factory drilled holes to mount it.
This thing WILL be up and running by spring!!! As long as it doesnt break on the dyno getting tuned.
rpm1 is offline
Old 10-26-2009, 02:06 AM   #133 (permalink)
fordnut350's Avatar
Did you say make room for a transfer case?!? Aren't you busy enough? Man this thread is too cool!
2001 F-350 CC LB 4X4 06 frontend 6.5" pro-comp lift with 35" BFG muds on 18x10 Mickey T's 4" MBRP SS exhaust Airraid intake Hypetech tuner
fordnut350 is offline
Old 10-26-2009, 08:50 AM   #134 (permalink)
Ha! I'm not 100% sure I am going to convert to 4wd. But I do have front/rear axles and a transfer case. I imagine they will find their way into the van someday....
rpm1 is offline
Old 10-30-2009, 09:29 AM   #135 (permalink)
exchanger
kool what's the size of that excchanger radiator unit ?
Similar Threads
Compound Turbos "X" Project DART505 Upgrades and Aftermarket - 99 & up 7.3L Engine 5 04-30-2006 05:15 PM
Turbos for compound charging clamgulch Upgrades and Aftermarket - 99 & up 7.3L Engine 78 02-19-2006 11:51 AM
Newer turbos quieter than older turbos? RobParks1 6.0L Power Stroke Engine and Drivetrain 3 11-17-2005 06:34 PM
Newer turbos quieter than older turbos? RobParks1 Upgrades and Aftermarket - 6.0L Engine 0 11-17-2005 12:20 AM
