Converting econoline to 6 wheeler - Diesel Forum - TheDieselStop.com
Old 09-13-2009, 06:35 AM   #1 (permalink)
Hi,
I am converting my E-350 6.9 Diesel to 6-wheeler by adding second rear axle(behind original). Reason for this is that I already converted this vehicle to motorhome and now it looks kinda stupid when cab is "hanging" 10 feet over rear axle. Idea is to cut piece of frame with axle from similar E350 and weld it as extension to original frame. So I would like to know if anyone has added tandem axle to econoline before? Any pics? And also are there 6 wheel abs/tracs systems that work with 12 volts?
Pics Pictures by terkaa - Photobucket
terkaa is offline
Old 09-14-2009, 12:04 AM   #2 (permalink)
there are sme recent photos on here of one, dunno what kind of axles it had in it either. it as up on the artic but they all drove and everything. Problem you might have is if you get into steep enough areas ( some camp grounds ive ran into with my minni winnie) is that the angles are too steep to have a spare axle. if its not driving and you put your drive axle n the middle you will hang up and wont be able to drive.
forddodgechevy is offline
Old 09-14-2009, 02:19 PM   #3 (permalink)
chevy tandem pictures by terkaa - Photobucket
Here is what I had in mind... It is a chevy unfortunately but you can see the construction. This is made by motorhome manufacturer. It has rear leaf spring attched to front leaf u-bolts. Rotating joint from rear leaf center to frame and rear axle at the end of rear leaf. This way front axle transfers added weight to rear and pushes it down. Also in steep areas reversing rear axle tends to push up and transfers weight to front axle and pushes it down. Quite clever
terkaa is offline
Old 09-16-2009, 09:23 PM   #4 (permalink)
SIC-E's Avatar
wow, like that tandem install. wanted to do a USA 6x6 tandem on my E450 before they went out of biz but added weight an issue with towing 5ver. good luck and post what ya do.
2004 E450 Cutaway, 6.0L, quigley 4x4, ambulance pkg., maxbrake controller, curt 20k fifth wheel. Future mods: 52" sleeper, tandem (6x6?) rear (aint look'n likely), frame cover. maybe a Herd front bumper.
2003 E350, 7.3l, x-cargo
2003 F350 Lariat, 4x4, CC, SRW, Dark Green Fx4 SOLD
1995 C3500 6.5l work trk, 2x4, CC, DRW, white DECEASED PREMATURALLY
2003 JEEP WRANGLER, ooooops, not anymore!
1986 26' Seaway Northstar w/ 454 Mercruiser
2008 Montana Mountaineer 332PHT
1991 GMC Topkick, CAT, 4' vert. gang boxes, 12' dump. if only all were as reliable!
SIC-E is offline
