correct track spacers - Diesel Forum - TheDieselStop.com
Old 09-06-2005, 09:06 PM   #1 (permalink)
I see there is a company making 2" spacers out of billet aluminum (6061). They are on ebay under f250 spacers from seller ezaccesary .About $110 . Think I could trust product ? What are your thoughts ?
bork is online now
Old 09-07-2005, 12:02 AM   #2 (permalink)
Re: correct track spacers
The steel ones are pretty heavy. If you are on stock tires and wheels, and you are not running fully loaded "all" of the time, then my choice would be some of those billit aluminum ones. Make sure they are for 97 and down "F"250/350. A sliding door won't "slide". You will have to cut about 1/2" off the ends of the studs. The spacer AND the wheel will not be hub piloted. You will need to check the lug nut torque on the spacers periodically. That means removing the wheels. ON EDIT, "Correct Track" only makes the steel ones. So these are from some other company.
1994 E-350 RB 5.8gas 4X4Quigley cargo 4.09 arb-locker f/r 35x12.5-16.5 or 285/75-16.,,, 1997 E-350 EB 5.4gas 4X4Quigley Sportsmobile camper 4.10 arb front, L/S rear 285/75-16/front 33X12.5-16.5/rear ><>J
toalpi is offline
Old 09-07-2005, 08:29 AM   #3 (permalink)
97 on down because of bolt pattern ? 8 x 6.5" right ? And newer is 170mm NOT our vans .
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is online now
Old 09-07-2005, 09:53 AM   #4 (permalink)
My Photos: (9)
That's right...
2001 E350 PSD, Deep Emerald Green, 3.55 LS, Premium package, dual alts, rear A/C. Quigley 4x4, Transfer Flow rear tank (27+26), handicap mods, custom interior, Reunel tire carrier w/ Hi-Lift, Sportsmobile nerf bars (black), Amsoil lubes and Dual-Gard bypass oil filter, Amsoil air filters, Eclipse/JL Audio sound system w/ Sirius & 120GB Neo Car Jukebox (MP3 player), J&J stainless grill, Reunel Stainless bumper, 12000# Warn winch, PIAA lights, Bilstein shocks, Ultra Magnum wheels, Michelin tires (265/75-16), Correctrack rear wheel spacers, Bushwhacker flares (painted), Velvet-Ride spring shackles, p/s filter, external tranny and coolant filters, Autometer gauges(5), Optima Yellow Tops, Airdog.
msnunes is offline
