Cruise Control
Just finished installing the FORD cruise control kit in my 2001 E350 PSD.
The kit came with a new steering wheel with the cruise buttons on it, a new clock spring, a brake switch, and other misc items. And directions
The install took no more than 2 hours. The hardest part was taking the steering wheel off. But I managed to pull it off without a puller. Be careful around the air bag. Make sure you disconnect BOTH batteries.
I highly recommend this kit for you guys that don't have cruise.
I priced around and the prices ranged from $160 to $200. I went to Fette Ford in Clifton, NJ and ordered it for $160. Can't beat that price for a factory kit. I asked the parts guy to look up the price for steering wheel alone and it was $198. [img]images/icons/shocked.gif[/img]
Part number is YC2Z-9A818-AA
Hope this helps [img]images/icons/cool.gif[/img]
Billy T.
gnxtc2@aol.com
'97 Black F250HD,XLT, SC, LB, 4x4, Suncoast E40D, Triple Disk Converter, Dana 60, 3.55LS, built 12/97, US GEAR downpipe, Bilstein 5150s, Front add-a-leaf w/urethane bushings, VDO EGT, Trans Temp, and Boost gauges, Hellwig rear swaybar, Shimmed fuel regulator, 4" Exhaust-Straight piped,FORD AIC, Custom triple A-pillar gauge holder,B&M Supercooler, gutted EBPV, B&M Transpan, ART Cryo slotted rotors, Tony Wildman 4 position chip, Joe Servo IDM, MAP sensor mod, Blackbird rear disc conversion, RSK w/ "V" & "F" code SD springs, 149K
PICTURES OF IT ALL
Fort Lee, NJ
