Cruise Controll dont work anymore, anyone can help ?
Hello. I have a 1990 model ford Clubwagon E250.
I cant get the cruise control to work anymore. what can be wrong.
someone told me to check the spring on the carburettor or something but I dont now wat that guy bear in mind. it has worked before.
someone has a idea wat it can be ?
A nother problem is my battery`s goes dead after a chort time to try start the engine. I change the old battery`s with new ones but the same problem is there. I have also checked the glow plugs and they work. I have also checked the earth wires from the battery but they are also in good shape. When I turn the egnition on the glow plugs starts to work, the light in the car get werry weak. when I then try to start the engine it almost out of power, wat can be wrong ? the battery`s are new.
Re: Cruise Controll dont work anymore, anyone can help ?
See if there is a switch on the brake arm that turns the cruise off when you mash the brake. It could be out of adjustment.
1998.5 E350 7.3 extended cargo with Late model doors ,po.wer windows, locks and mirrors.Isspro gauges from DPPI, Power Slot Cryo rotors from DPPI, Hawk LTS from DPPI,NAPA DOT 4 brake fluid,NAPA calipers,Evans coolant,Dieselsite ac control valve,Dieselsite 203* thermostat,BTS valve body, Amsoil tranny fluid,4WD deep tranny pan from Dieselsite, DieselSite transmission bypass filter,Amsoil dual oil filter, Amsoil 15-40 wt oil,4 inch Warpspeed Performance exhaust,Thermo-Tec Exhaust Insulating Wrap, Bilstein shocks,Line-X 2-06-2009 103,400 miles following added Beans stage II single shot injectors, Air Dog, Beans regulated fuel return with fuel bowl delete, glow plugs and Stancor gp relay, Beans modified IDM, Stealth HPOP stage I, Dominator 66 turbo, DpTuner reflashed factory pcm that was split shot injectors to the single shots, 9 tunes from DP Tuner including decel tune,tuflocs on all doors, Snow water-methanol injection stage 3 installed by Beans Diesel, BTS tranny
Are the batteries fully charged when you start? Is your alternator charging the batteries after you start it?
If you have a low battery and no charging, it might affect the cruise control.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
What is a self starter?
