Went out yesterday, Regular was $3.17-3.35. Diesel was $3.01-3.07.
Premium was out of sight at $3.35-3.63.
And they say it will get worse in the next month.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
I must be living in wrong country.... It's twice the price here [img]/ubbthreads/images/graemlins/confused.gif[/img]
98 E350 PSD Cargo "Under construction"
F5 DP Tuner (10 pos)(mounted on a-pillar) w/pane files -PS 2000 -SC 1705 (code reader) - Snow stg 2 - 3xUltraLites in a-pillar - 3x UltraLites on dash -4"Magnaflow (15970)turbo/back -4" DIY AFE intake -ITP overboost kit. Detroit locker.
And the hottest mod so far: Tranny built by RATS, BIG thanks to Ole Ringstad
TC lock-up switch, Jingle bells killed, Excursion gauge cluster (tack).
Waiting to be mounted: roll cage, Two garret gt3782bb - real twins.
Working on: brackets to relocate alternator, sidepipes. AC and vacuum pump delete (for space)
Headers, and a second HPOP
Did the Republik of California taxes go up on gas? Curious, 'cause usually Wisconsin's gas prices are very similar to CA.
No, taxes are still the same. They claim the price rise is because CA has a unique blend of gas (to reduce pollution/smog) and demand is high for the limited supply of that gas.
Oh, and they have some refineries shut down for conversion to 'Summer' gas.
Mike
It was my first year here and I didn't know why everyone made such a big deal about a little snow.
Mike
New York [img]/ubbthreads/images/graemlins/smile.gif[/img]
2.82 diesel [img]/ubbthreads/images/graemlins/mad.gif[/img]
2.49 rug [img]/ubbthreads/images/graemlins/mad.gif[/img]
Just came back from a short trip on Monday, 12 Mar '07, and the most expensive diesel (that I saw) in the Austin, TX area was $2.89; the cheapest was $2.63. This was about .10 cents higher than permium gas. The gas forcast in Tejas is >$3.00 by summer; diesel will be higher. What a rip off!! The news here states that the new, earlier DST is responsible; what a crock!! We have a lot of politicians getting VERY RICH with petroleum.
