Dirty air... how bad? Any hope? - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 04-19-2017, 08:58 AM Thread Starter
I have a 03 e450 that I bought last year. Long story short, the air filter assembly is broken in a way that air could easily bypass the filters. I have no way of knowing how long this was the case.
Is there anything I can do to mitigate potential problems caused by this?
Thanks for any help, very nervous about this...
pigpen1 is offline
post #2 of 3 (permalink) Old 04-20-2017, 07:24 AM
Any damage has already been done and it's no use to worry excessively about it. I would just continue to operate the vehicle and see if the engine continues to run OK.
Of course, I'd immediately put a good air cleaner on. Be sure you clean all the hoses between the air cleaner and the turbo.
While you're cleaning the intake hoses, check for damage to the turbo wheel. If the leading edges are damaged, it indicates the dirty air was at work. Other damage can include damaged rings which can result in burning oil and low compression. Dirt can also get into the crankcase and damage bearings, etc., but without an engine tear-down, you won't know.
MichaelPatrick is offline
post #3 of 3 (permalink) Old 04-20-2017, 07:28 AM
can you post pics of your broken air box?
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > E-Series Vans
