Old 11-10-2007, 06:48 PM   #1 (permalink)
sixiron's Avatar
My Photos: (11)
Dyno # from GTG today
I just returned from the Souther Smoke Show in Winston-Salem, NC sponsered by powerstroke.org...
I was the only van there
ran on a mustang dyno , the same guys I have run on B/4 the last 3 times so I had a decent baseline from what I had done with the older van
here is what I put down:
333 hp 798 lb torque...I feel like the torque # is higher and not totally realistic but
all they pulled to was 2397 RPM with a shutdown after that ..all in all a few heads turned at those numbers ...
run#1 298 hp 901tq 1670 rpm
run#2 322 hp 801 tq 2340
run#3 332.9 hp 795 tq 2390
fwiw
bill
don't know if the regulated return system entered into the picture but
2002 E-350 ext. cargo..4" DP+exhaust/gauges/ CCV mod/ AIH delete/TT mirrors wC-btr's/Amsoil Dual by-pass/Racor 45P prepump/ITP regulated return w/fuel bowl delete/tank mods/203*/timbrens/bilstein/Hella/ DP tuned/BTS trans/ alum baja wheels/cryo rotors...dyno 335 hp...164,062 miles
98 E-350 PSD...575K
04 VW TDI/PD Jetta wagon
cat 2 mic f/filter,CCV/muffler/fuel filler mods,Evo skidplate/ RC1+
sixiron is offline
Old 11-10-2007, 07:01 PM   #2 (permalink)
My Photos: (13)
Re: Dyno # from GTG today
COOOOOL! Bill.
Makes the non vannies wonder.
Did jody add any motor tune when he did the trans tune?
Quiet with less air in fuel?
Bill
97 E-350 Quigley Van Picts
Supporter/User of THE CURE E4OD/4R100 Transmission Control
WWW.FORDTRANSMISSIONCURE.COM
TO RENT THIS SPACE SEE YOUR ADMINISTRATOR
ads@thedieselstop.com.
MADVAN is online now
Old 11-11-2007, 07:42 AM   #3 (permalink)
sixiron's Avatar
My Photos: (11)
Bill, same PCM out of the old van , Jody's HPII tune...
maybe there is something to the air-in-fuel thing...
I am running this by Ryan Bean, he said I might pick-up a "few" hp but we were joking at the time and I didn't take him seriously...
later
bill
98 E-350 PSD...575K
sixiron is offline
Old 11-11-2007, 08:29 AM   #4 (permalink)
My Photos: (13)
Bill
It should pickup some (small) hp/tork/mpg.
Also the motor should be quieter.
This would happen with just air removed from the fuel.
How high did bean set the pressure. 62psi max seems to be the # the PSD with splits likes.
Bill
Old 11-11-2007, 09:03 AM   #5 (permalink)
sixiron's Avatar
My Photos: (11)
I couldn't see the gauge when they set the pressure cause its buried behind the reg.return but Bean did say that the splits like it between 65-70#...Bean set it himself with another reading the gauge from the rear..
later bill
98 E-350 PSD...575K
sixiron is offline
Old 11-11-2007, 02:02 PM   #6 (permalink)
My Photos: (13)
I will bet bean does not want to do other vans. [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
What a PITA!
I think Jody's flash 2 is 80e mode.
Bill
Old 11-11-2007, 04:46 PM   #7 (permalink)
Good numbers Bill, why the big difference from 1st run to the 3rd? How do they do a run? 1st gear only? If so, a few seconds your maxed out? Do you have original/stock injectors inplace? & where, now, is regulator at? Can it be installed under van by fuel pump, for easy access?
On edit; Now I see difference, RPM. my bad.
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
Old 11-11-2007, 06:17 PM   #8 (permalink)
My Photos: (13)
Bork
Also you will notice 2397 max rpm. It has more in it!
Wonder if it started to defuel or they shut it down.
My bet would be that van was cool then warmer also. Run 1,2,3
Either way 1670 rpm would be a good cruise rpm to have. By 2300 it lost 100 ftlbs.
Six might be looking for 355 after all.
Bill
Old 11-11-2007, 07:47 PM   #9 (permalink)
sweet!! ,six sounds like you had some fun!!! got to believe RR system helped better fuel delievery always has to be a good thing my van was like night and day when i installed system , and yes installation on a van is a PIA and to top it off it was like 10 degrees out and i did it in my driveway(don't ask i still think i am 19)but with that said now that i have done one i think doing one again would not be that hard.nice #'s proud to be a vaner!
wade
2002 E350 EXT. Cargo 7.3PSD , silver metallic , bought new presently 178K , dual alts. , auxiliary idle control , rear a/c heat , premium group , michellin LTX M/S on AMERICAN RACING WHEELS outlaw II's , centramatic balancers , optima yellow tops not worth the extra money imo weak at best replaced with wal-mart everstart maxx more snap 1/3 the price , ITP in tank mods van specific , ITP prepump filter,ITP regulated return system van specific , DP-TUNER F5, stock,40 tow,80 econo,120 extreme , NON-EBPV turbo pedistel DIESELSITE viton o-rings ,K&N filters tempararelly till i devise a better set up , more modds on way
FULLAUTO is offline
Old 11-11-2007, 09:30 PM   #10 (permalink)
sixiron's Avatar
My Photos: (11)
Thanks for kind words everyone...
Yes it was a lot of fun and surprising to me
Yes stock injectors...jody 80 econo program only
The dyno guys protect themselves...usually the first run is a warm up and I know of at least 2 trucks that had water leaks and were pulled off after the warm up pull...
example: my first pull Ended at 52.4 MPH...
Borq...they strap the vehicle down on the dyno ...ease on throttle until it shifts into 4th gear ( OD locked out on automatics) (manual trans into high)and then its full throttle ...my second run ended at 76.3 MPH, 3rd run ended at 77.4 mph
soo there's not a whole lot of full throttle action ..if you want to dyno your own vehicle you can and then you can do what you like
Wade, my hats off to you for installing one of these RR systems
by yourself...my throttle response has been just great since the install...my engine is smoother and quieter +I am having a lot of fun smoking ricers that won't let me get out of the passing lane safely...
98 E-350 PSD...575K
sixiron is offline
Old 11-12-2007, 12:16 PM   #11 (permalink)
BlizzardVan's Avatar
My Photos: (18)
Sounds like a great event. It suprises people when a vehicle the size of a van moves out pretty good.
Hypermax stage 2 injectors, 4" intake with Ram scoupe, QSSB Turbo, Snow Meth inj, BTS trans no spacer, Salem Kroger 4x4, Sway and traction bars, APX drivers seat, 4" straight exhaust & DP, 4" lift, 18" wheels with 325 nittos, custom valve Bilsteins, DP PCM and F5
...Stuff to make it almost as fast as a pickup.
BlizzardVan is offline
