E-550 6.0L Powerstroke - Diesel Forum - TheDieselStop.com
Old 03-16-2003, 01:56 PM   #1 (permalink)
I was at a dealer the other day getting parts and asked them what they thought they were gonna do with the van and the 6L and they told me that the other day he had an E-550 with a 6L in it. I'm not sure if it was the cutaway, or if they only make the 550's in cutaways or whatever. But from what i saw on Fords website the E-550 was the same front end as all the other vans that exist now and the 6L fit in there. Maybe there wont be any changes for the new engine and if there are maybe they aren't going to change the outside look. I just looked on the ford site and couldn't find any pictures of 550's but they have 450's on there. I wonder where the 550's are.
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 03-16-2003, 06:15 PM   #2 (permalink)
Re: E-550 6.0L Powerstroke
The E550 come in a cutaway and is an awesome looking rig. It has the 19.5 wheels and a straight fron axle. The whole thing sits a lot higher and has extended fenders on the front and an extended massive front bumper. If they had one of those in 96 I would have had to get one instead of the E350. Then I wouldn't have had to change up my springs and change my brakes every year.
trucktech is offline
Old 03-16-2003, 07:41 PM   #3 (permalink)
My Photos: (5)
The place I bought my ambulance from upgraded there rigs to the E450. They sit a lot higher than the 350. In fact they now only have about 2" clearance on there bay doors. Definetly the way to go for the GVWR. The GVWR on the 350 I have from them is 11,000 and the rig weighs 10,020 with just me in it.
1991 Ford PL Custom Ambulance Type III 7.3L Diesel. Photo Here Pioneer AM/FM/XM/CD Stereo. Code 3 lightbar, Whelen Strobes and flasher lights. Whelen flood lights on front, rear and sides. There bright enough to turn darkness into daylight. Siren with several tones plus electronic airhorn and PA. Custom 3" exhaust from manifolds back with a Gibson Superflow Muffler [img]/ubbthreads/images/graemlins/grin.gif[/img]. Dual alternators and dual sets of batteries. If I need a jumpstart all I do is push a button. On spot tire chains that install and de-install themselves at the flip of a switch. Also has air compressor on board along with suction unit and O2 system.
1972 Cadillac Hightop Ambulance by Superior Lucky if I get 10MPG
CompuDoc is offline
Old 03-16-2003, 09:59 PM   #4 (permalink)
The E-550 has been killed and it never had the 6.0, only the non-intercooled 7.3.
Mike
MichaelG is offline
Old 03-22-2003, 03:00 AM   #5 (permalink)
Ahh, man! I thought the E550 was so cool! Are you sure they stopped making them? I know they didn't come with the new motor, but I thought that thing was absolutly perfect for motorhomes and box vans.
Chris
2003 Dodge 3500 Quad Cab Dually (new 7/18/03)
All stock
85,000 miles and counting 13,500 per month!)
UPDATE 5/06...400k MILES, STILL STOCK!
1999 Ford Crew Cab Dually
V10 with K&N Filter Kit
4R100 with Gear Vendors Under/Overdrive;5:13Gears
230K Miles(Blown head gasket)Installing a Cummins!
UPDATE 5/06...INSTALLED A NEW V10, DRIVER SIDE HEAD LEAKS COOLANT AT 85k MILES, NOW I NEED A CUMMINS!
Future Plans:
19.5 inch Wheels
Complete Air Ride Suspension
new girlfriend
UPDATE 5/06...MARRIED NOW AND HAPPY!!!
EMIEVEL is offline
Old 04-07-2003, 02:05 AM   #6 (permalink)
My Photos: (33)
There's two of them at my local dealership right now with 19.5s they were parked around the corner of the building all I could see was high cube van body and the 19.5's on both units till I went around to take a look at em they were Vans shiny and new with 550 on them was in a hurry so I didn't get to observe more than that.
00'F350 psd CC Drw 2wd Bright Amber Western Hauler, exhaust brake transfer flow 50 gal tank tool, 30K Cody goose neck hitch, hawk pads, cryo'ed rotors, stainless lines, 380,000 miles
02' Psd Excursion Limited ultimate Estate Green 7.3L Auto 2x4 hellwig swaybars and rancho 9000's. 381,000 miles.
1993 F-superduty (F-450) 7.3L Gutless non turbo 2x4 Auto, Tire eating S.O.B. 12,750lbs 80,000miles lincoln Vantage 500 Duetz bolted in the back.
1994 7.3 I.D.I.T. factory turbo, auto 2x4 DRW with lots of upgrades, 11 transmissions under 100K factory warranty. 280,000 miles Currently Cavitated and parked.
96 F-800 24'flat 5.9L cummins, 4spd allison juice brakes.
89 F-800 6.6L 5+2 27,00lbs light weight with National 556A crane behind the cab.
2006 T800 KW 550 C-15 18spd 22K front, 52K rears murray ramps, 195" W.B. CA spec heavy haul SOLD
2006 Murray 16 tire professional lowbed SOLD
1996 fetherlite 4 horse GN, Walton 18' 14K tag tilt equipment trailer.
Dualie is offline
Old 04-07-2003, 04:05 PM   #7 (permalink)
Well dang, go back and check out the engine. I didn't think they stoped making the E-550 but couldn't find it on the ford site and couldn't find any eyewitnesses.
Eric
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 04-09-2003, 01:12 PM   #8 (permalink)
whotnow's Avatar
My Photos: (13)
They quit making them, my step dad was on that line,and has now been bumped back down to the regualar production line.
FOKISD Charter Member from Chillicothe, OHIO
2004 Excursion, Auto, 4X4, 6.0 Turbo diesel, Harley Instument Cluster, Heavy duty Headlight harness w/Fog Lights mod, 26/24 inch wipers, 3.73LS, X and F w/350 blocks/spring upgrade, XMradio, Grill and tail light guards, Sunvisor w/marker lights, rear spoiler, 2 JL audio 12's, Front Marker Mod, rear swaybar, Hella Highbeams mounted on grill guard, Air rite Airbags, Born On 12-03
2002 F550, Auto, 4x4, 7.3 turbo Diesel, Altec Boom, utilitybed, Ex-Allegheny Power Truck.
whotnow is offline
Old 04-09-2003, 09:03 PM   #9 (permalink)
My Photos: (33)
I asked around at the dealer and they were both bought by the same guy they were both V-10's what a waste of a bad arse van!
Dualie is offline
Old 04-09-2003, 09:13 PM   #10 (permalink)
Well... damn...
sure they don't put the 6L in the 450 then?
Eric
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 04-10-2003, 11:11 AM   #11 (permalink)
yARIC008.....yes I am sure, the 6l is not in the E150, E350, E450 or the discontinued E550. Look on the Ford or Ford Fleet sites. It will not fit without major physical changes to the vehicle.
The open question is when it will be included, there are three opinions floating around:
1) it will never be put in the E because the E will be killed and not replaced. I doupt this one.
2) it will not be in the E until the E has a redesign. Then there are opinions on when that redesign is...some say a year after the superduty which might be in 2006 so 2007.
3) the E will have some changes to fit the 6l in 2005.
Opinions on top of opinions is all there is. The only FACT is that the 6l is not available in the E and the E-550 has been discontinued.
I would think Ford would want to kill the 7.3 in the E since it is the only product line using that engine now.
Mike
MichaelG is offline
Old 04-11-2003, 08:57 AM   #12 (permalink)
I'll add another rumor:
The local Ford salesman I've been dealing with supposedly called a Ford engineer buddy who said that the 6.0L will come out in the E-350 this coming January. I've also been talking to a conversion van company rep who supposedly confirmed that general timeframe through his inside channels.
As with all rumors, YMMV. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
-- 2003 Excursion EB 6.0L
-- 2008 F350 CC SRW Short Box 6.4L
typhoid is offline
Old 04-11-2003, 04:41 PM   #13 (permalink)
I liked the new E550 I wounder why they discontinued it.It can't be because of the engine they can put the 7.3 in it.It sat high and was a very nice truck for some one who wants to get into a bigger but not hugh truck.Also why would they bring it out for really only a year ,Kinda dumb if you ask me?They must be working on a truck to compeat with the chevies now .
'05 F350 XLT reg cab 4x4 Diesel/auto longbed ,tow command ,upfitter switches
Cat320 is offline
Old 04-11-2003, 06:46 PM   #14 (permalink)
The E-550 was a lot more expensive then the E-450 and no one ordered them. I also think the new F650 ended up to be close in price
Mike
MichaelG is offline
Old 04-13-2003, 03:22 PM   #15 (permalink)
Are we sure that they just didn't limit the production of these trucks, i went to a dealer today to look at trucks and saw a couple there. They were all 7.3L but yeah.. i asked a sales man if they still make them and he said they had just gotten those 3 in. so... that's weird.
Eric
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
