E-series higher capacity gas tank / dual tank options? - Diesel Forum - TheDieselStop.com
Old 12-14-2007, 02:37 PM   #1 (permalink)
505live's Avatar
I was wondering what options exist for improving fuel capacity in my 93 clubwagon E350. The factory tank is only ~30 gal? Making my own B100 I'd really like more capacity, at least 40 gallons.
Edit: I should note I'd prefer to avoid having a permanent tank inside the vehicle. I'm ok w/ having a transfer tank for long trips, but for weekend trips a higher cap on-board tank would be nice.
2003 E350 EXT 7.3L PSD, Bought September 2008 @76,000mi.
DP Tuner F5
Bilstein HD Shocks
Centramatic Wheel Balancers
Autometer Phantom Boost, Transmission Temp, and EGT gauges
Powertrax autolocking rear diff.
Scangauge II xgauge
Dahl 75 Pre-pump fuel filter/water separator
Modified Sinister Diesel fuel bowl delete and regulated return + post pump filtration.
Tow Mirrors
Spahl power remote door locks
Dieselsite Max AC Assist
Added cruise control
Sealed Beam to HID Headlight Conversion
Personal blog http://505live.com
505live is offline   Reply With Quote
Old 12-14-2007, 11:27 PM   #2 (permalink)
blageurt's Avatar
My Photos: (9)
Re: E-series higher capacity gas tank / dual tank options?
Get one of the rear square deals that are in the Cube Vans they are 40 and 50 gallons respectively.
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D60FF, EBPV Delete , DP flashed 60 Tow , 140 V idm , Autometer Triple pod , Michelin LTX
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 , MSD IGN , Custom C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
blageurt is offline   Reply With Quote
Old 12-15-2007, 05:09 PM   #3 (permalink)
SIC-E's Avatar
google "trasnsfer flow" tanks
2004 E450 Cutaway, 6.0L, quigley 4x4, ambulance pkg., maxbrake controller, curt 20k fifth wheel. Future mods: 52" sleeper, tandem (6x6?) rear (aint look'n likely), frame cover. maybe a Herd front bumper.
2003 E350, 7.3l, x-cargo
2003 F350 Lariat, 4x4, CC, SRW, Dark Green Fx4 SOLD
1995 C3500 6.5l work trk, 2x4, CC, DRW, white DECEASED PREMATURALLY
2003 JEEP WRANGLER, ooooops, not anymore!
1986 26' Seaway Northstar w/ 454 Mercruiser
2008 Montana Mountaineer 332PHT
1991 GMC Topkick, CAT, 4' vert. gang boxes, 12' dump. if only all were as reliable!
SIC-E is offline   Reply With Quote
Old 12-16-2007, 12:09 AM   #4 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: blageurt</div><div class="ubbcode-body">Get one of the rear square deals that are in the Cube Vans they are 40 and 50 gallons respectively. </div></div>
They bolt into same space as a stock diesel van?
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline   Reply With Quote
Old 12-17-2007, 09:53 AM   #5 (permalink)
505live's Avatar
Forgive my ignorance, what are the rear square deals that come in Cube Vans, and where does one get them??
DP Tuner F5
Bilstein HD Shocks
Scangauge II xgauge
Tow Mirrors
Old 12-17-2007, 10:23 AM   #6 (permalink)
My Photos: (9)
Transfer Flow may not have a solution anymore. They no longer sell their aft-axle tank (which I have) except for disabled-van installs where it replaces your stock tank. Otherwise, they have the 46 gal replacement tank, but that's only for 4x4 vans....
2001 E350 PSD, Deep Emerald Green, 3.55 LS, Premium package, dual alts, rear A/C. Quigley 4x4, Transfer Flow rear tank (27+26), handicap mods, custom interior, Reunel tire carrier w/ Hi-Lift, Sportsmobile nerf bars (black), Amsoil lubes and Dual-Gard bypass oil filter, Amsoil air filters, Eclipse/JL Audio sound system w/ Sirius & 120GB Neo Car Jukebox (MP3 player), J&J stainless grill, Reunel Stainless bumper, 12000# Warn winch, PIAA lights, Bilstein shocks, Ultra Magnum wheels, Michelin tires (265/75-16), Correctrack rear wheel spacers, Bushwhacker flares (painted), Velvet-Ride spring shackles, p/s filter, external tranny and coolant filters, Autometer gauges(5), Optima Yellow Tops, Airdog.
msnunes is offline   Reply With Quote
Old 12-17-2007, 10:49 AM   #7 (permalink)
MikeL46's Avatar
My Photos: (14)
The T-F 46 gallon tank can be used on a 2wd van, you just have to fabricate a crossmember/tank mount for the front. The tank was designed to use the Quigley transfer case crossmember as a mount.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
106345 miles. 16.65 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
MikeL46 is offline   Reply With Quote
Old 12-17-2007, 11:27 AM   #8 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 505Live</div><div class="ubbcode-body">Forgive my ignorance, what are the rear square deals that come in Cube Vans, and where does one get them??
</div></div>
maybe its the empty space behind axle? On my extended there is a large area,in between spare tire & differential. I was thinking about making a box for tools & spare parts. I guess I start looking under diesel box vans in parking lots. I hope they are made out of aluminum.
BTW; I pm'd blageurt, with the question, just in case he does not revisit this thread again. He's not a real frequent poster.
Old 12-18-2007, 08:44 AM   #9 (permalink)
Here's Blageurt's PM reply;
"I'm not sure if they are aluminium or not but yes they are bolted behind the axle. If you have the service manual they are an OEM tank that comes with the Cubes. As soon as it stops snowing here I'll crawl underneath my nieghbours truck and take a picture and take some measurements. If you give me your email I could scan the manual picture and send it to you as well. I would look in scap yards or get one made. There are lots of them here in Toronto ( cube vans I mean ).They should be easy to find."
_________________________
Old 12-18-2007, 09:53 AM   #10 (permalink)
505live's Avatar
Very cool, thanks! Sounds like it might could be had for less than the $1000 for a T-flow tank... Just have to relocate the spare.
DP Tuner F5
Bilstein HD Shocks
Scangauge II xgauge
Tow Mirrors
Old 12-18-2007, 11:42 AM   #11 (permalink)
My Photos: (9)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 6L_E350</div><div class="ubbcode-body">The T-F 46 gallon tank can be used on a 2wd van, you just have to fabricate a crossmember/tank mount for the front. The tank was designed to use the Quigley transfer case crossmember as a mount.
Mike </div></div>
I suppose it would fit, then... But due to ground clearance it doesn't sound like something TF would support. But, then, that kind of thing has never stopped most of us before. The aft-axle tank, on the other hand, was marketed to the 2wds as well.
Old 11-27-2012, 02:53 PM   #12 (permalink)
So you guys should know, I just talked to John at Quadvan, they buy and install the Transfer-Flow 46 gal tanks. They designed a crossmember to bolt into the top of the stock frame, to hang the tank in position. This is designed for the 4x4 system, but would also fit the 2WD as well. The fill neck and hoses are different between gas & DSL. They stock these tanks there, and can supply the tank, with the crossmember and the correct installation kit for your van. Contact them at Quadvan.com or call for more information. 503-224-3629
quadvanptsman is offline   Reply With Quote
Old 11-28-2012, 12:41 PM   #13 (permalink)
My Photos: (18)
Sweet!
1999 E-350 Cub Wagon, 7.3L Power Stroke, E4OD, 3.55
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS x2
1994 Chevy C2500 6.5L TD, 3.42
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1981 VW Rabbit Pickup 1.6L diesel (project)
1978 VW Rabbit 1.5L diesel (project)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem (project)
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
Kaliburz is offline   Reply With Quote
