E350 Club Wagon New Trailer Wiring Question - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 06-13-2007, 08:23 PM Thread Starter
Was curious to know if there is an easy plug-in (hoppy) avaiable for wiring a new plug for a trailer or do I have to do the nasty and do a hard wire? I got a used hitch and it has a 5-way/with a 4 plug but just has the wires and not sure how or where I need to attach.
tabs4634 is offline
post #2 of 10 (permalink) Old 06-13-2007, 10:19 PM
carrfamilynj's Avatar
My Photos: (6)
Re: E350 Club Wagon New Trailer Wiring Question
I've got an '04 E350 15 pass, I found the trailer wire plug dead-ended inside the driver's side frame rail just behind the rear axle. Instead of buying the FORD $70 adapter, I used splice taps to run my own $3 4 wire flat plug back to the hitch. Use a test light to determine what's what, the colors don't match up. The aftermarket adapters only go up to 2003, or I would've gone that route.
'04 E350 XLT SuperDuty "Crew Van"-3 rear benches removed,
equipment shelving installed.
Specs: 5.4 V8, 3.55 open rear, K & N with modded snorkel, Black Magic Extreme 16" electric puller fan, In-Dash Auto-Meter Phantom electric coolant and ATF temp gauges, Derale Deep Transmission pan cooler, TransGo Shift Kit, Gabriel Hi-Jackers rear air shocks, polished aluminum billet grill, Euro-clear corner lenses with 18 LED amber bulbs, Euro-clear headlights with Sylvania Silverstar Ultra bulbs, Lund bugshield, 55 watt driving lights, stainless trim rings with chrome deep lug nuts, Valley Class 4 Receiver Hitch
Purchased 5/2006 w/44k, 69k as of 3/2008
carrfamilynj is offline
post #3 of 10 (permalink) Old 06-14-2007, 10:30 AM
Probably depends on what packages it was built with. My 1992 had all the wiring already and under the dash had all the trailer brake wiring. The connector they used in 1992 wasn't really compatible with anything i was using or could find, so i cut the connector off and just soldered to the wires. But the wiring was all their. If the van doesn't have a trailer tow package it may not be there though.
Eric
, 6,900 lbs.
Dodge 1997 Ram 3500
yaric008 is offline
post #4 of 10 (permalink) Old 06-14-2007, 10:30 PM
my 99 E350 XLT psd had all the plugs for plug & play. I have a closed utility traler that I wired in a connector from factory plug above axle & to trailer. So I have the typical 4 pin plug at trailer & a 2 pin plug at trailer for brakes. Up front is a tekonsha brake control. (envoy model) That plugs into harness from factory in left side kick panel. (back behind emergency brake pedal, under panel)
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
post #5 of 10 (permalink) Old 06-28-2007, 09:31 PM
KTD
I've got an '04 E350 15 pass, I found the trailer wire plug dead-ended inside the driver's side frame rail just behind the rear axle. Instead of buying the FORD $70 adapter, I used splice taps to run my own $3 4 wire flat plug back to the hitch. Use a test light to determine what's what, the colors don't match up. The after market adapters only go up to 2003, or I would've gone that route.
I have a 06 E350 V10. I put the trailer brake in up front. Simple plug and play. I cannot find the connector in the rear anywhere. I am hoping it is where you just said in your post. Do you happen to have the part number for that Ford Adapter? I will gladly pay $70 for it. I just bought this Van to tow my race trailer, I put on Dual rear wheels, Dual exhaust, Computer, Air intake, and now a simple trailer connector is about to ruin my weekend. Any help is appreciated!
KTD is offline
post #6 of 10 (permalink) Old 06-28-2007, 09:42 PM
go to home depot and get a fox and hound and try to figure out where the wire is back there. Should be pretty simple to find, that's if it's there at all.
Eric
, 6,900 lbs.
Dodge 1997 Ram 3500
yaric008 is offline
post #7 of 10 (permalink) Old 06-29-2007, 06:30 AM
My Photos: (6)
I don't recall the part # but tell the parts guy you have the 4 pin plug that ends on the frame rail, and you need the extension. The brake control wire is not in that harness, that is a separate deal, MAdVAn has a post on here somewhere detailing how to get that hooked up.
post #8 of 10 (permalink) Old 06-29-2007, 06:39 AM
KTD
Thanks a bunch guys. I'll look for that other post.
KTD is offline
post #9 of 10 (permalink) Old 06-29-2007, 09:59 PM
I rigged my brake controller into harnes behind front kick panel & ran a wire from the blue on that 4 pin plug above axle to my trailer brakes . also need the ground in that 4 pin which is white or maybe green. Test lamp will show the right pins if you have someone hit the manuel over ride on controller. I just used those two wires for my trailer, cause it is a single axle small utility trailer & doesn't need a charging system for a battery. No battery on trailer. Works fine.
bork is offline
post #10 of 10 (permalink) Old 07-05-2007, 05:44 PM Thread Starter
Thanks for all you help guys - after doing some feeling around I found the factory 4 plug - it does come down the driver side frame rail - while tracking it I found the rest of it above the rear axle same side. The plug was to corroded to use so out came the wire cutters and butt connectors. You do not have a whole lot of room to work - but I guess that's why they charge you $ 70.00 for the adaptor. I also found the brake control adaptor under the dash after doing some test light probing. Even less room there - just cut what wires I needed and spliced - my back has been paying for it since. Now unto the mirrors !!!
Tab [img]/ubbthreads/images/graemlins/tongue.gif[/img]
tabs4634 is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > E-Series Vans
