Old 05-16-2009, 11:50 AM   #1 (permalink)
e350 tranny feals strange
Hi.
On my e350 powerstroke with dp tuner i am wondering about a ting. when i hold steady speed max pedal it will not downshift just starts to accelerate, it would have been better for it to dovn shift to get more power.
if i am going from still and max pedal it feals like it change gears way to early. could have hold the gears much longer to get more power.
feals like it is changing gear way to early sp when next gear come i loss alot of power. have no idea of the rpm, but sometimes it will hold the gears for longer then the truck is much faster..
any ideas what can make the tranny to shift way to early. have not ovned this car for long so dont know if this is correct or not.
1996 e350 7.3 powerstroke.
4" exhaust. custom intake. DP-tuner f5.
stage 1 diy injectors
matsh is offline
Old 05-16-2009, 01:04 PM   #2 (permalink)
Super_Dave's Avatar
Trying to understand everything you're saying...
A couple things that might be helpful. A Power Stroke Diesel generates a lot of torque. So, it doesn't need lots of RPM's like a gas engine to really get the mass of your van moving. Additionally, it doesn't have a high "redline". A gas engine will rev out further.
Another thing, and this is a Ford issue, is that the jump between the Drive gear (D) and the Overdrive gear is pretty big. 1.0 to .71. That might be that "loss of power". Additionally, the E40D's and the 4R100's kind of slide really slowly from that third to fourth (overdrive) gear. Usually, that change comes at around 47MPH or so on the PSD vehicles I have had.
That give you some ideas and some direction for more questions?
Super Dave
2003 Excursion Limited 4WD 7.3PSD - Prodigy brake controller, DP Tuner-60t/80e/AIC/exhaust brake, BG drive line fluids, Timbrin front & rear springs, 203* Tstat, Evans NPG+, coolant filter, Ford Transmission Cure
2007 Buell XB12R Road Racer
Super_Dave is offline
Old 05-18-2009, 11:57 AM   #3 (permalink)
yhea the nead off high rpm to get power that i see, it got alot of power from the lower register.
but i just feal that it could be more happy to dovn shift more often when i press full pedal.
with a bunch of stuff in the van so the wheight goes up a bit it feals better, more boost and use the gears better i think
matsh is offline
Old 05-18-2009, 03:16 PM   #4 (permalink)
blageurt's Avatar
That is because the PCM senses the load in the Van and adjusts the shift strategy accordingly. When I load my puta up heavy ( over 3000 lbs ) it runs like the big lincoln's used to . . .
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , HD cooler , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " ,Not installed yet DP flashed PCM (60 Tow )Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 05-31-2009, 05:43 PM   #5 (permalink)
My Photos: (15)
How did the van drive before you had the tuner installed?
1998.5 E350 7.3 extended cargo with Late model doors ,po.wer windows, locks and mirrors.Isspro gauges from DPPI, 5 speed chip from DP Tuner,Power Slot Cryo rotors from DPPI, Hawk LTS from DPPI,NAPA DOT 4 brake fluid,NAPA calipers,Evans coolant,Dieselsite ac control valve,Dieselsite 203* thermostat,BTS valve body, Amsoil tranny fluid,4WD deep tranny pan from Dieselsite, DieselSite transmission bypass filter,Amsoil dual oil filter, Amsoil 15-40 wt oil,4 inch Warpspeed Performance exhaust,Thermo-Tec Exhaust Insulating Wrap, Bilstein shocks,Line-X 2-06-2009 103,400 miles following added Beans stage II single shot injectors, Air Dog, Beans regulated fuel return with fuel bowl delete, glow plugs and Stancor gp relay, Beans modified IDM, Stealth HPOP stage I, Dominator 66 turbo, DpTuner reflashed factory pcm that was split shot injectors to the single shots, new tunes including decel tune,tuflocs on all doors, Snow water-methanol injection stage 3,
mtnbiktn is offline
Old 06-02-2009, 06:24 AM   #6 (permalink)
My van is very hesitant to downshift when I run the 80e program as well. I figured it was one of the ways Jody used to boost fuel economy. I kind of like it as it gets me a little closer to manual transmission-type control. I find if you drop it out of O/D, it downshifts readily.
My 60t tune downshifts much like stock.
2003 E-350 14-passenger, 3.73 axle, Quadvan 4x4
beaker is offline
Old 06-02-2009, 01:58 PM   #7 (permalink)
My Photos: (9)
I get that too with that setting. Wants to shift up right away too... So when you go to change lanes and pass, you end up blowing a lot of smoke until the thing finally drops down - something to be aware of if you don't want to attract attention to yourself. I use the 40T otherwise, and it shifts fine and hardly smokes.
2001 E350 PSD, Deep Emerald Green, 3.55 LS, Premium package, dual alts, rear A/C. Quigley 4x4, Transfer Flow rear tank (27+26), handicap mods, custom interior, Reunel tire carrier w/ Hi-Lift, Sportsmobile nerf bars (black), Amsoil lubes and Dual-Gard bypass oil filter, Amsoil air filters, Eclipse/JL Audio sound system w/ Sirius & 120GB Neo Car Jukebox (MP3 player), J&J stainless grill, Reunel Stainless bumper, 12000# Warn winch, PIAA lights, Bilstein shocks, Ultra Magnum wheels, Michelin tires (265/75-16), Correctrack rear wheel spacers, Bushwhacker flares (painted), Velvet-Ride spring shackles, p/s filter, external tranny and coolant filters, Autometer gauges(5), Optima Yellow Tops, Airdog.
msnunes is offline
Old 06-03-2009, 04:41 AM   #8 (permalink)
have not tested all settings on the tuner, only with stock, 80e and 100performance, i get more power on 80e so i usual use this or stock, it shifts smother on stock so if i am only driving in the small streets around here i use stock, but if i wot it will just gear up and then smoke alot and use long time to get speed. i think it would have been faster if it had used the gears better.
on 80e if i dont press max throttle just half way then it will run better thru the gears i think..
starting to get used to how it acts so it aint a big problem
matsh is offline
