E4OD vs 4R100 and what year - Diesel Forum - TheDieselStop.com
Old 03-10-2007, 04:53 PM   #1 (permalink)
Hi all,
Anybody know what build # or year model Ford switched to the 4R100 transmission in the E350 diesel vans?
Which is the better trans?
Also I believe they switched to rear disks about this same time which im sure is a big improvement. Should I be looking at the later year 7.3l (1999.5+ I think) to get these features? Is it that big a deal?
Aaron
idamanzz is offline
Old 03-10-2007, 08:50 PM   #2 (permalink)
Re: E4OD vs 4R100 and what year
They are the same transmission, the E4OD was renamed to conform to ISO standards. The differences that you will see between the "named" transmissions are because 4R100's are newer and so have the newest design parts.
E4OD = Electronic 4 speed Over Drive (Ford's nomenclature)
4R100 = 4 speed Rear wheel drive 100 [relative torque rating] (ISO nomenclature)
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 03-10-2007, 08:54 PM   #3 (permalink)
Thanks!
idamanzz is offline
Old 03-10-2007, 09:15 PM   #4 (permalink)
My Photos: (14)
As I have been on the hunt for a replacement van and research and receiving input, from a mechanicals standpoint it seems the 99.5 to 2000 is the best combination of mechanicals. Those years get the rear disks on the full floater rear,a 4R100 and you will get forged rods in the motor if Modding is your thing. The exact start of PMR (powdered Metal Rods) is the subject of much debate, but if you don't plan on building a High HP PSD (Over 350-400) its not an issue. PMRs started sometime in 2001 as did he semi float rear end.
You'll get the dead head fuel system which can give cackle and other injector noise in 99 and up, but that can be cured by the ITP regulated return system. The 98van I was looking at in MI with the old style non-dead head fuel system was Quiet, quieter than my '03.
The 99.5 and up get you the larger turbo intake pipes and some other upgrade for more base HP. Cheaper to add a reg return to a 99.5 and up, than to upgrade the turbo and intake on a 98 back which may also require injector upgrade (more turbo means you need more fuel).
Thats the short version of some of the information out there. I would buy the newest van withthe least amount of miles you can afford. My price point puts me out of the 99.5 and up unless I want a real high miler or an up north van.
ddog
While I love diesels, I don't need one, and unfortunately, after much deliberation its a hobby I currently cannot afford.......... Gone but not forgotten:
1999.5 F250 CC SB XLT 4WD, 7.3 PSD, First F,2nd Diesel, nice but still liked the van better.
2003 E-350 Super Duty Chateau (Club Wagon)7.3PSD, 3rd Clubwagon,First diesel, Never should have sold it....
ddog is offline
Old 03-11-2007, 10:30 AM   #5 (permalink)
It's not a relative torque rating, it's an absolute torque rating. The 100 means 1000 lb-ft torque capacity after the torque converter. The torque converter multiplies engine torque about 2:1.
Casey_1 is offline
Old 03-11-2007, 11:02 AM   #6 (permalink)
Hey ddog,
Thanks for the reply -
Regarding:
"You'll get the dead head fuel system which can give cackle and other injector noise in 99 and up, but that can be cured by the ITP regulated return system. The 98van I was looking at in MI with the old style non-dead head fuel system was Quiet, quieter than my '03"
Ive read a bit about the cackle issue and im not liking it or the increased noise issue. How prevalent is this problem?. Shouod I be looking for pre 98 for these reasons?
How big a fix is the "ITP return" Cost? Hours?
Cheers
Aaron
idamanzz is offline
Old 03-11-2007, 12:46 PM   #7 (permalink)
I thought the torque converter(TC) locked up was only transmitting all engine power 100% without slippage. I didn't know it had gears in it to multiply output?
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
Old 03-11-2007, 05:52 PM   #8 (permalink)
My Photos: (10)
E4OD and 4R100 are not the same. The 4R sprung from the E4. Lockup and pump are not the same and require different programing. 4R has pulsed lockup.
And of all things look out for the MECHANICAL DIODE (sprag) in the 4R.
Don't have build dates, but mid 00 early 01 in think.
Somewhere on TDS there is a way to test sprag. Just don't remember.
Bill
MADVAN is offline
Old 03-11-2007, 06:43 PM   #9 (permalink)
A torque converter has something of hydraulically linked gearing. There are a lot of parts inside of a torque converter. http://www.howstuffworks.com/torque-converter.htm
Now the original fluid coupling used in early automobiles did not multiply torque, it only slipped to allow a vehicle to stop while in gear.
Old 03-11-2007, 06:48 PM   #10 (permalink)
Bill
Minor differences, no more different than different years of production of the E4OD. The only parts of the transmission that is electronically controlled is the solenoid pack, which is a 10 minute swap once you have the pan off.
It's like comparing a 1969 302 to a 1989 5.0L. Not all the parts directly interchange, but it is the same motor.
Old 03-11-2007, 07:43 PM   #11 (permalink)
My Photos: (10)
http://forums.thedieselstop.com/ubbthrea...rue#Post3256467
MADVAN is offline
Old 03-11-2007, 08:38 PM   #12 (permalink)
OK, look at it this way. When you get a repair manual, on the cover it says "E4OD / 4R100". The cases are the same dimensions, the internals are the same dimensions, the oil pans are the same dimensions.
I understand that a 2002 4R100 won't bolt directly into a 1989. Nor will a 1996 E4OD bolt directly into a 1989. Parts need to be changed to match the computer programming of that particular truck.
If you want to get really technical about it, you can ID a 4R100 case by it having a PTO port, where a E4OD does not.
Old 03-11-2007, 09:25 PM   #13 (permalink)
My Photos: (10)
Correct
But all has to be from a 7.3. Bell housing bolt patterns are not the same for gas and diesel. Not even getting into that the diesel has more clutches.
Bill
MADVAN is offline
Old 03-14-2007, 09:12 PM   #14 (permalink)
clev's Avatar
My Photos: (14)
Not to start an arguement, but the A4OD and 4R100 are not the same; specifically, the parts will not interchange. I can't give you all the specifics, but when I had to replace the torque convertor on my E-350, there was a different part number between the A4 and 4R. I'm getting ready to install a US Gear Underdrive and the connection parts are different. The best advice is to take everything that you read here with a grain of salt and talk with a Ford parts expert for your final decision.
'85 E-150 351w, factory order rcvd Oct. '84: Balanced/blue-printed, HYPEREUTECTIC pistons, matching edelbrock performer pkg: cam, lifters, intake, carb, & elec fuel pump. MSD pkg: MSD 6, billet distributor, timing control, & 8.8 wires; AirLift air bags, Deraler tubed trannie pan, FloMaster Exhaust w/duramax ceramic headers, new paint.
'99 E-350 HiTop Companion Van Conversion SD 7.3, factory order rcvd Dec. '98: Triple AutoMeter C2 A-pillar gauge pod, SuperChip, twin K&N air filters, 203* mod, Deraler tubed trannie pan, B&M trannie cooler, AirLift air bags, Bilsteins, 4" DiamondEye turbo back exhaust, US Gear Underdrive Auxillary Transmission.
clev is offline
Old 03-14-2007, 11:52 PM   #15 (permalink)
First, there is no such thing as A4OD. There is E4OD and 4R100.
The torque converters are different between the E4OD and 4R100. That's one of the things that was beefed up for the 4R100.
Casey_1 is offline
