exhaust smoke under boost - Diesel Forum - TheDieselStop.com
Old 08-20-2005, 04:25 AM   #1 (permalink)
I noticed quite a bit of smoke coming out of the exhaust when I got heavy on the pedal. The van is stock with 124,000 on the odometer. It uses some oil inbetween oil changes.
A friend told me the oil seals in the turbo are probably the problem. If this is the case, can the seals be changed ?
Thanks for any input.
99 Ford E-350 w/ the 7.3 Turbo Diesel. No mods, 118,000 miles as of 4/20/2005
sparky134 is offline
Old 09-10-2005, 08:57 AM   #2 (permalink)
Re: exhaust smoke under boost
What color is the smoke?
If it is black or gray, I would suspect a boost leak.
"Nothing in life is so exhilarating as to be shot at without result." - Sir Winston Churchill
May your road stay clear & dry, may your fuel never gel, and may you never be outsmarted by your idiot lights.
2002 F-250 XLT SC LB 4x4 7.3PSD 6-Sp 3.73 L-S, Snugtop Snuglid Tonneau, 235/85 MC HTRs, <span style="color: red">DPTuner F5</span> AFE Stg II, Turbo LifeSaver, MAP BRV, Autometer Cobalts, Magnaflow 4", WW, TAG, AIH del, CCV, AirDog, In-tank, Harpoon, HPX, ITP fuel sys, LL8 del, 203*, Oilguard & SP Diesel bypass filtration, ART rotors, PFC pads, Heater Core Ctl Valve, Bilsteins, Velvet Ride Shackles, South Bend Clutch, <span style="color: green">21.27 mpg</span>
2004 <span style="color: red">E</span>-350
XLT Wagon 6.0PSD 3.55 L-S TDM EZ-Entry 11 pass., AIC, custom MBRP 4" w/dual Aeroturbines, Airdog, harpoon, Overhead Cobalts
Pictures . . . Parts Links
DarthSurplus is offline
Old 09-10-2005, 08:28 PM   #3 (permalink)
From what I can see from the sideview mirror the smoke appears to be gray.
