f-350 front springs in e-350? - Diesel Forum - TheDieselStop.com
Old 08-26-2009, 02:25 AM   #1 (permalink)
MOTOVAN808's Avatar
will it work? are they the same?
2002 E-350 ext. Fire survivor!! POWERSTROKE cargo w/divider...new blue paint, all panels dynamated, 220K
Rockin stereo Alpine, xtant, Boston Acoustics, JL Audio.
MOTOVAN808 is offline
Old 08-26-2009, 06:41 AM   #2 (permalink)
Send a message via Yahoo to txevt
part numbers are different, gvwr for the front is different.
1995 Ford E350 cutaway, 7.3L DI Turbo, E40D, 4.10 Posi, SRW, ambulance prep package. Wheeled Coach box.
txevt is offline
Old 08-26-2009, 12:43 PM   #3 (permalink)
MikeL46's Avatar
My Photos: (14)
I had heard the F-Series springs have the same ends on them, but are ~3" longer. The trick is to get the correct weight rating on the spring.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline
