Re: Fan Noise???
The first time that fan came on, it seemed like we had broken something - it is soooo loud!
Mostly, it comes on at low speeds (30-40) going up and down hills and using power. I'm guessing that you only hear it when it is coming up to speed, then it continues to run for some more time, but cannot be heard.
125W solar panel. Sportsmobile off-road trailer.
54,311 miles. 16.47 mpg average
From Cal to Alaska and Key West and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires. 46 Gal tank - harpooned pump vent tube.
Scangauge
162 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, Turbo hose fitting, Block Heater, Door lock - all under warranty. AC hose, not under warranty.
