Re: First oil change, MicroTuner Temptation
I added:
pyro for EGT (post turbo)
Tranny temp gauge
I am super conservative and timid, so this is about all I will do before the warranty runs out (25.5 K miles right now).
Next time I change air filters, will see about modifying the air box.
I use KN air filters now. I think the jury is still out concerning how much benefit you get by drilling holes in the air box. Can it hurt anything????
Will make an exhaust upgrade after that. Better breathing and maybe a bit cooler.
Would love to make the turbo run cooler somwhow. If I get a "wicked" or similar turbo mod, then I will move the EGT probe to pre-turbo in order to get a better reading.
The scarey part is that I didn't get my EGT pyro installed until about 10K and I had already pulled my loaded trailer 7,000 miles with the pedal to the metal going up hills and through the mountains. God only knows how hot the turbo temps got. [img]/ubbthreads/images/graemlins/depressed.gif[/img]
<font color="blue">2003E350 </font color> , you need a pyro NOW. Even running naked, I use it to shut down the engine.
Once the warranty runs out, I will get a chip immediately.
Am really tired of pulling my trailer with one eye on the pyro. [img]/ubbthreads/images/graemlins/confused.gif[/img] [img]/ubbthreads/images/graemlins/confused.gif[/img] (NOTE: if you're going to pull much weight for a lot of miles, get the 4.10).
Having said all of that, you can't beat the 3.55 if you're not going to pull anything heavy. My van seems to love 70 MPH on Texas highways.
If F**d puts a cooler in the 6.0 vans, I'm heading back to Cochise the day I find out. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Yardbrew
America....love it or leave it
02 E350 PSD Cargo with windows/power/CC/3.55 LS/Prodigy/Reese WD & Dual Cam/....from Cochise
Van Color:Gray--Bumper Color:Gray--Wheel Color:Gray--Hubcaps:metallic--Tire Color:black--Grill Color:gray plastic
I pull a 1987 Wells Cargo Express Wagon (20 ft)
