You'd have a hard time plugging the sidewall tear the I got once. Ran over an alder stub that someone had cut at an angle (nice and pointy). I don't think I'd ever leave the spare behind unless I felt like walking a long way.
I am going to buy a new Alcoa Classis 19 lb. rim to match to other four and retire the steel rim that weights 10 lbs. more than the Alcoa. this way I have a matching michelin Tire and I know it's not all cracked and old. Maybe I can find a cover for the spare tire to help protect it while under the van. It would also help to carry the jack in the van. I have never even looked at it before. This jack is sweet, 2 Ton Air Jack - RakJak - 18 - Mfg# TBT2
2000, E-350, SuperDuty, Explorer Extended LivingRoom, 7.3L PSD. 3:55 LS Rear, SuperChips 1705, Dual K&N's, FleetGuard WF-2077 Coolant Filter, AutoMeter Phantom Guages - Pyro, Boost, Tranny & Hobbs Hour Meter, 4" SS MagnaFlow Turbo Back Completely Wrapped with Thermo-Tec 2" Header Tape, Sonnax Valve & Tricumulator Shift Springs, Mag-Hytec Tranny & Dana 60 Cover, One-Up Front Spring Option, Bilstein's, Centramatic's, 35 Gallon Main Fuel Tank & Trax II TransferFlow 27 Gallon Aft. Aux. Fuel Tank = 62 Gallon Range, ACPM/AIC, Dual Battery & Dual Alt, FilterMAG, Fumoto, Amsoil Tranny & Rear End, Alcoa's, 4 Leather Captain Chairs w/ Back Bench Seat/Bed, Inflatable Aerobed, 20" LCD TV Overhead, DVD, VCR, KVH TrackVision, SAT/NAV, Walnut Cabinets & Trim, 3000 Watt Sine Wave Power Inverter, BioVault 2.0 Gun Safe, 2xDIN Pioneer DVD Head w/Backup & Side Cameras, 5 Channel Surround Sound System, PowerTank, 12 Volt Refrigerator, RainX Wiper Blades, 3M Rubberized Undercoating, Bob's AC Valve, H3R
2005 E350 Standard Cargo Van, 6.0 PSD, 4.10 L.S., Quigley 4X4 New on 11-18-05
(seems to manufacture oil....1 Qt per 4000 miles)
Warranty Turbo 7-07 22,000 miles
Warranty A/C compressor 10-07 25000 miles
2003 E350 Extended Cargo Van, 7.3 PSD, 3.55, Quigley 4X4 New on 2-1-04 Some Pix
Transfer Flow 46 Gal.***Delaminated***Replaced 8-29-06 UNDER WARRANTEE
XM Radio, Alpine GPS Nav. System 7.5' Western Snow Plow
Quad Captain's chairs and Espar Furnace
OX cable locker on front
ARB locker on rear
BTS Tranny 9-29-07 @55,000 miles
Aluminess Bumpers
Mile Marker 12,000 pound hydraulic winch
The exhaust jack looks cool also, I wonder if it will hold up to a diesel?
The whole thing about a flat tire is Speed. Fixing it fast with the right equipment.
___________________________________
A dramatization:
Imagine your stuck in the center island break-down lane on an interstate with vehicles whizzing by. It's night time and very dark. So you set up your triangle, flares, LED's or whatever you have handy. Put the Flashers on, I have strobe lights installed also, so I fire those on.
The First thing I will do is call *FHP , this calls the State Police in Florida on the cell phone. Then call AAA and tell them where I am. I don't have a GPS, so I need to tell them I'M about 4 miles south of Atlantic Ave . next I would try to pull off as far as I can to a safe, level spot.
That's my next subject. I need to buy a GPS for my van.
So do I try and install the spare tire myself? Or wait for help?
I have the C02 Powertank to run the 1/2" drive Impact Wrench to remove the lugs.
But now I realize I have never tried to take my spare tire out of the van?
I don't have the manual in the van. Panic sets in as I hear cars locking-up tires due to a drunk, or some chick on the cell phone.
Ok, so I failed the safty flat tire change. I never did a dry run to change a tire, only how to plug a tire while the tire was still on the van.
So now I need to take my jack out of the garage and put it in the back of the van, and learn how to drop the spare tire.
This weekend I'M going to learn how to handle a spare tire change.
When I was 18 (1976), I had a 1962 Econoline window van. It was my first vehicle. Very early one morning, in a blinding snow storm, I crested a hill on Route 17 in the Catskill mountains.....fishtailed....hit the median snow bank, and knocked the front left tire off of the rim. No patch kit or compressor was going to fix this problem.
Head and wrist throbbing from the impact that each had with the windshield (no seatbelts...) I set to changing the tire. Got under the truck and used my brand new Sears 3.5 ton bottle jack to lift the front end. Removed the wheel, got the spare out, and was about to put it on......when out of the corner of my eye I spot a brand new Chrysler New Yorker coming over the same hill....just as sidways as I was when I came over it. It was all I could do to get out of the way before the impact.
So here we are.....me and mister New Yorker......my trailer hitch punched clean through his right front fender, van knocked off the jack, cold, head pounding, and pretty much wanting my mommy.
Luckily I lived to laugh about it.
I learned an important lesson that day. Rule one: get to a safe spot. Never try to change a tire in a danger zone. It's just not worth whatever damage you might otherwise do to the truck. Shred a flat tire, damage a hub or a wheel well, whatever. Just don't stop in a bad place NO MATTER WHAT. Drive way off the road, go to the next exit, do whatever you have to do, but don't stop unless you have no choice. And if that happens, wait for help. A couple of flashing lights 100 yards behind you to slow traffic down will save your life.
ARB locker on rear
Aluminess Bumpers
My first car was a unmarked state police car, 1 year old, so it was a 1973 Chevy Biscayne w/ the 400/4 barrel air cleaner said 300 Horsepower. Dual spotlights, un-connected siren, pozzi traction, and just a fast car. I remember putting leaded high test in this car with octane booster, had the carbs set for more fuel. It had that cool, flip top air cleaner top.
my 8-Track Craig Quad tape player with Car Krickets in all four corners, I had more fun in that car.
When I was growing up in a small town, the cops never bothered us, we could drink, pary with no worries.
now=a=days, the cops are all bust crazy, they want to get everyone for a seed, or roach etc.
the good old days are gone.
I've considered leaving my spare @ home as well, but sidewall damage keeps me from doing so. The only reason I would is to not have the extra 150lbs, or the giant brick of a tire on top of the brick that is my van. I keep a repair kit anyway...... I know that as soon as I don't have that spare, something will go wrong.
Do it nice or do it twice!! Van sponsors: Mickey Thompson, Warn, RBP, Bilstein, Detroit Locker, Atlas Spring, Tuffy Security, Line-X // 06 E350 6.0, Sterling 10.5" rear axle w/Detroit locker, Dynatrac Pro60 front axle w/F550 knuckles & brakes, Knoll Racing front Powerlock, ORU/Lee hydraulic ram assist, Bilstein 5150 series shocks & Nitrogen bump stops, custom dual shock hoops, rear overload airbags, custom front bumper, Warn 16.5 winch,1350CV's front & rear, 1410 yokes, long travel front shaft, RBP 4" stainless exhaust, Atlas custom leaf springs, synthetic winchline, Line-X interior, M/T 38/15.50/20 MTZ's on M/T 20x10 Classic Locks. Thats all I can think of right now!
I have extra faith in my sidewalls because they have steel plies. I also know I can call on CAA or a tire shop for mobile service. It is my work van though... I would pack a spare for travelling for sure.
95 F350 Crew 5spd/4.10, SuperChips tuner, solid flywheel, T444E waterpump, 205° stat, Locked F&R, 9.00R16 Michelins
97 E350 SRW cutaway, E4OD/D70/4.10, 19.5" wheels & 16ply rubber, BD-Power trans pan, relocated batteries w/marine switch, 1800W inverter
84 C30 Suburban, 6.2/4-spd, 3.21s
Other rigs I goof around with regularly:
93 F350 4x4, 7.3 IDI turbo, 5spd, 4.10s
90 F250 4x4, 7.3 IDI, 5spd, 3.55s, D60 swap, straight pipe, turned up fuel screw
I like the idea of a matching wheel on the spare tire. Have one on my van so I can do 5 wheel rotations. Takes about an hour with hand tools, but at least I know the spare has air and I can change it when needed.
Mike
125W solar panel. Sportsmobile off-road trailer.
54,311 miles. 16.47 mpg average
From Cal to Alaska and Key West and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires. 46 Gal tank - harpooned pump vent tube.
Scangauge
162 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, Turbo hose fitting, Block Heater, Door lock - all under warranty. AC hose, not under warranty.
this just happend to me last night the valve stem cracked lost air fast. hit a corner and the rear was all over so i pulled over tire was about half flat then only took about a minet to go to the rim. to make madders worse the stupit kid at big o put my spare on (back door spare)with an impact and spun the carage bolt used on the carrier. so we could not get it off. i was heading to my dads for dinner so i had him bring me one of his old dodge wheels but the inner circle was to small. we tried to cut the spare off but broke the only sawsal blade we had. lucky i was only about 10 miles from my sisters house my bother inlaw has a beed braker he picked up the tire and put a new valve stem in for me just 3 short hours later i was good to go
I had a blow out on my tt camper coming down from Lake George last summer and had to use the jack from the van to get it changed. It is really not a big deal; easy to figure out. The hard part is putting the jack and lever back in place! Getting the spare down is easier than it looks also you just have to get the screwdriver down that hole and you can feel it catch then you're good to go. I think sun is the worst thing for tires and being under the van it does not get any so I just maintain the 80lbs, a little armourall if I get bored.
2005 E-350 Super Duty Chateau 6.0 PSD
1999 Chevy Express Mark III
2000 Honda Odyssey
2002 Forest River Shamrock 25BH
