I did it. I bought the extra Classic Rim from SouthwestWheel.com and I'M taking it to Costco to have the new michelin installed.
Those Alcoa rims are very sweet. I think it's 19 lb.s . and 209.00 is a great price. They have 17" rims also, does anyone have 17" tires on the van?
I'M going to weight the new rim and the steel rim as I have four naked rims in boxes. The steel rims are like brand new because I removed them when I bought the van. I ordered the steel rims from the factory because I like the Alcoa rims vs, the Ford Aluminum rims. The Alcoa's have the highest tow/weight rating for the 350 vans, so they say. The Alcoa Classic Truck or Trailer Wheel
So now I get to lower the original spare tire and do a trial run for a change.
Happy Days...
2000, E-350, SuperDuty, Explorer Extended LivingRoom, 7.3L PSD. 3:55 LS Rear, SuperChips 1705, Dual K&N's, FleetGuard WF-2077 Coolant Filter, AutoMeter Phantom Guages - Pyro, Boost, Tranny & Hobbs Hour Meter, 4" SS MagnaFlow Turbo Back Completely Wrapped with Thermo-Tec 2" Header Tape, Sonnax Valve & Tricumulator Shift Springs, Mag-Hytec Tranny & Dana 60 Cover, One-Up Front Spring Option, Bilstein's, Centramatic's, 35 Gallon Main Fuel Tank & Trax II TransferFlow 27 Gallon Aft. Aux. Fuel Tank = 62 Gallon Range, ACPM/AIC, Dual Battery & Dual Alt, FilterMAG, Fumoto, Amsoil Tranny & Rear End, Alcoa's, 4 Leather Captain Chairs w/ Back Bench Seat/Bed, Inflatable Aerobed, 20" LCD TV Overhead, DVD, VCR, KVH TrackVision, SAT/NAV, Walnut Cabinets & Trim, 3000 Watt Sine Wave Power Inverter, BioVault 2.0 Gun Safe, 2xDIN Pioneer DVD Head w/Backup & Side Cameras, 5 Channel Surround Sound System, PowerTank, 12 Volt Refrigerator, RainX Wiper Blades, 3M Rubberized Undercoating, Bob's AC Valve, H3R
I have a 20 ton jack in my van. Granted, they put a tire carrier on the rear door. Always have a spare tire for your vehicle (and I usually get rid of those 'emergency' types for my cars and shove a full size in somewhere....been lucky so far). If I buy a new set of tires (2 or 4 at a time), I keep which ever one is the 'best' for the spare (if it's better condition then the spare).
Buddy has a 92 F250.... spare was still in the under side carrier. He doesn't like them there. We pulled it out.... the rim still had paint on the lug holes. No one ever took the thing out.... looked like the OEM tire from 1992. Still held air though....
I still recall swapping a tire on my Sable in college. Side was sliced from something, wouldn't hold air. Using the OEM screw jack and wrench...I think it took me 30 min or longer. After that, I kept a 2nd OEM jack w/ the built in handle removed- used a socket and ratchet to raise it fast, then a breaker bar to lift the last few. Takes longer to use the jack then anything else..... uggg.
1999 E-350 Cub Wagon, 7.3L Power Stroke, E4OD, 3.55
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
Just about a month ago I ran over this stud sticking out of the ground at my buddies house trying to pull into his back yard. I kept asking if i was clear then all of a sudden, BAM-SSSSSSSSSSSSSSSSSS. Basically the entire side wall was torn, about a 5 inch gash wide open. That tire was trashed. Just pulled the truck out of the yard and over a side walk and changed the tire, went pretty easy I suppose. I was about to get new tires the next day but unfortunatly the one that I ripped was one of the ones that was fairly new and I wanted to keep.
I keep a 3-ton floor jack in the van along with the spare. The device under the van is shot. I use a 1/2" ratchet and 7/8 deep well socket to change my tires.
Audrey C. Duff Memorial Car Show
May 16, 2009 11am to 4 pm
Trucks and Bikes are welcome!!!
