Was cleaning up the van the other day and realized just how crappy the plastic piece below the front bumper has started to look (calling it the facia for lack of better term). This is on my 03 and originally it was an off grey/black color that matched the running boards. It now has a very unattractive mottled look with some staining on it from road goo that just won't go away.
Has anyone had success in keeping this part looking good and if so, what do you do to it? I have tried all sorts of cleaners, etc, but it just looks old already while the rest of the van still looks almost new.
do it and your running boards up in bed liner material itll look like youre a high class redneck (i can use it cause i r one)
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
I hadn't thought about painting it and that sure would make it look better. That might just be the long term solution. However, with the rino liner I could clean the bugs off with a wirebrush and it would look the same all the time...
Any other suggestions out there?
I use Maguires Black Magic on my plastic parts that works pretty good. Another product is Stoners Trim Shine in a spray can. I found both at Kragens. I don't think I would paint it due to the beating that part takes from stones and gravel.
2001 F-350 CC LB 4X4 06 frontend 6.5" pro-comp lift with 35" BFG muds on 18x10 Mickey T's 4" MBRP SS exhaust Airraid intake Hypetech tuner
well a shine wont take care of dings and dents along with scratches
mottled he said i assumed general dings from stones so if painted it still wont look right
Thanks for the feedback on this. I have kept it clean and used the plastic cleaner products on it and it of course gets a few dings from the usual road debris, but the main thing with it is the overall discoloration and now uneven and faded look. Just making the van look old before her time... If it keeps bugging me I will try and paint it in the spring.
Dave:
I used a paint product I got from Dennis at ITP.
It worked rather well.
I cleaned the entire area with strong degreaser soap.
Then wiped down the entire bumper with laquer thinner.
Masked off the crome part of the bumper
then spray painted the area.
worked for me.
2003, E-350, XLT, Chateau, 7-Pass. Club Wagan, 7.3L PSD, 3:55 LS Rear, SuperChip, AMSOIL TS-126 Air Filter, Fleetguard LF-9027 Bypass Oil filter, Sirius Satellite Radio, Garmin GPS, SuperCrewzer, AutoMeter (Pyro. Trans. Boost)Gauges, 4" Diamond Eye Turbo Back Exhaust, Sonnax valve & Tricululator springs, PML Alum. Tran's Oil Pan, Tru-Cool 4739 Tran's Cooler, ScanGuage Monitor, DAHL 100 Fuel Filter, "Last of the 7.3's".
USMC-(Ret).
You Don't Always Get What You Want, But If You Try Some Times You Just Might Find, YOU GET WHAT YOU NEED.
