So I have some new bumpers for the 2003, and I'm considering a hydraulic winch for the front. The original bumper seems to be mounted to a bracket, which seems to be bolted to the frame. It may be spot welded too, but I haven't gotten a good look yet. So my questions are these:
1. What is the shear strength of the bolts that hold the brackets on?
2. Should I weld the brackets to the frame?
3. What is the procedure for protecting the truck prior to welding?
4. What sort of flow and pressure can I expect from the stock power steering pump, and are there after-market options?
Thanks for any help........
2005 E350 Standard Cargo Van, 6.0 PSD, 4.10 L.S., Quigley 4X4 New on 11-18-05
(seems to manufacture oil....1 Qt per 4000 miles)
Warranty Turbo 7-07 22,000 miles
Warranty A/C compressor 10-07 25000 miles
2003 E350 Extended Cargo Van, 7.3 PSD, 3.55, Quigley 4X4 New on 2-1-04 Some Pix
Transfer Flow 46 Gal.***Delaminated***Replaced 8-29-06 UNDER WARRANTEE
XM Radio, Alpine GPS Nav. System 7.5' Western Snow Plow
Quad Captain's chairs and Espar Furnace
OX cable locker on front
ARB locker on rear
BTS Tranny 9-29-07 @55,000 miles
Aluminess Bumpers
Mile Marker 12,000 pound hydraulic winch
2000 F250 ...... just cuz people are dumping them for the fuel bill. Got mine on ebay for $8749 with 116K on the clock. Go-fast mods to follow.....
I can answer #3
1) Everyone agrees that you should completely disconnect both batteries.
2) Not everyone agrees but I also disconnected the PCM and the IDM
2000 E350 Chateau, 7.3 PSD, Ujointclothing DIY 4x4 conversion, Amsoil dual bi-pass oil filter, Amsoil Blue Air Filter, Reunel rear bumper, Bushwacker Fender Flares, and leaf spring front brackets
I can answer #3
Can you elaborate on this? I've done hours of welding on my van and never done this.
Ken Schwarz
Dayton, NJ
2000 E350 4x4 Dually
Clamshell Style Rear Doors, Gullwing Passenger Side! Hopefully soon to have Air Suspension and Tilt Nose.
1) Not sure, but you could always upgrade to grade 8's. They are fairly large bolts. If your 2003 is like my 2000, it really isn't a shear force. The way mine bolts, it would be a pulling force. My mounts are welded to the frame.
2) Welding is almost always stronger than bolting, as long as it is welded properly.
3) Cover burnables as best you can with sheet metal or even tin foil before welding.
4) Not really sure of pressures, but I don't believe it is enough to power a hydrolic winch if that is what you are thining.
Just a note to think of. If you are leaning away from an electric winch and you get stuck in deep water and stall the engine you will not be able to use your winch.
Ken Schwarz
Dayton, NJ
Disconnecting the batteries is pretty widely done. It has to do with the batteries being grounded to the frame or something like that. I've read of people welding without disconnecting with no problems, but it is a risk. In regards to the computers - it is required by the Ford Manual and I did it since it only takes a couple minutes and the modules are expensive.
With the AIC keeping the engine at 1100 rpm (and the emergency brake engaged 'switch' thrown) I'm hoping that one of these will work.....Hydraulic Recovery Winches
Still just wondering on a flow and psi specs on the PS pump. I'm not really concerned with the need to run the engine. A powerfull electric winch will leave you stuck AND with a dead battery if you don't keep the engine running.
As for the bolts, the bumper is held on to the mounting bracket by bolts in tension. The bracket is held on to the frame rails by bolts in shear. I guess I could just weld up the whole thing.....
ARB locker on rear
Aluminess Bumpers
Bolt it together with grade 8 's and weld the seams where the brackets meet the frame as a safety. That way if they move at all you will see it the paint flake or come off the welds . Bolting should be fine with proper ones , use a factor of safety for bolt Shear Stress of 5 ( where .7854 x diameter squared would be bolt area in inches ) and Max Shear Stress in PSI.
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , HD cooler , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " ,Not installed yet DP flashed PCM (60 Tow )Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
OK, I found the shear and tension info. In case you need to know....a 1/2" grade 8 will fail at about 30,000 lbs in tension and 17,000 lbs in shear.
I'd still like to find the power steering pump specs, but I'm having trouble.
Anyone?
ARB locker on rear
Aluminess Bumpers
