front end lift - Diesel Forum - TheDieselStop.com
Old 02-09-2003, 07:48 PM   #1 (permalink)
front end lift
i have a 93 E350 2x4 and was wanting some info on lifting the front end 1-2inches already put new springs with knuckles in them and the springs just relaxed over time. any info would be greatly appreciated <font color="blue"> </font>
93 e350 7.3 idi n\a E40D k&n air filter 3in exaust ram air 265/75/16 tires american racing baja rims 205000 miles autometer C2 pyrometer and propane is next
diesel350 is offline
Old 02-09-2003, 08:34 PM   #2 (permalink)
My Photos: (5)
Re: front end lift
Try air bags. I don't know if they will give lift or not but they will give more support. My ambulance had them already when I bought it so I do not know what the height was before.
1991 Ford PL Custom Ambulance Type III 7.3L Diesel. Photo Here Pioneer AM/FM/XM/CD Stereo. Code 3 lightbar, Whelen Strobes and flasher lights. Whelen flood lights on front, rear and sides. There bright enough to turn darkness into daylight. Siren with several tones plus electronic airhorn and PA. Custom 3" exhaust from manifolds back with a Gibson Superflow Muffler [img]/ubbthreads/images/graemlins/grin.gif[/img]. Dual alternators and dual sets of batteries. If I need a jumpstart all I do is push a button. On spot tire chains that install and de-install themselves at the flip of a switch. Also has air compressor on board along with suction unit and O2 system.
1972 Cadillac Hightop Ambulance by Superior Lucky if I get 10MPG
CompuDoc is offline
Old 02-11-2003, 05:51 PM   #3 (permalink)
Re: front end lift
There might be some old posts from years ago by me and others if you run a search.
From what I recall we simply used air bags and heavy springs in the front. On some vans that an atm service had, the shop I worked for wound up using the air bags to get the alignment right. The air bags were needed to help the spring with the weight, without the air bag the alignment was off. We set each bag up seperately and marked the area by where we put the valve with the poundage used so if something happened you at least had a starting point. These vans were one ton cargo vans that were armored for atm service, they had bulletproof windsheilds and doors and lots of extra weight in them. We got the springs through napa or somewhere and got the strongest ones they offered, and they were stronger than we could get from ford. We did one with just the springs and it came back for air bags. After that we just did springs and air bags at the same time, and these were new vans with new springs, but they could not handle all the extra weight.
Adding air bags should get you back to stock height. If you want a lift I would research some of the pre-runner 2wd pickups with a similar suspension system.
ducky is offline
