Old 03-08-2008, 04:03 PM   #1 (permalink)
fuel filter drain assembly replacement
Has anybody changed one of these on a van? I have a 1996 Powerstroke E-350. I can't get to the bolts which secure the filter housing to the engine. Tried to take the turbo compressor manifold off to give myself some room and I can't budge that either. I found a thread which describes how to do the repair on a pick-up and it looks so simple. I'm leaking fuel out of the valley and I hope this small fix will do the trick. Thanks for the help. Dylan
dylanbolles is offline
Old 03-08-2008, 07:36 PM   #2 (permalink)
blageurt's Avatar
Assumiing you have already removed doghouse completely , along with the intake hose /resonator and Turbo "Y' intake. Cover the intake boots with rags or duct tape so nothing fall inside. Disconnect the IPR connector from the IPR and from the housing. I had to loosen the Trans dipstic tube as well . There might be a hose connected from the drain in the front too., Work from the Passenger side and use a small mirror to see the two 13 mm bolts which the bowl is mounted with. Don't forget to disconnect the two rubber return lines from the heads to the FPR. The bowl assembly comes out from the passenger side. If you can remove the passenger seat it's easier. Hope this helps. I had more room because I removed my Turbo to rebuild it. If your Turbo needs attention now is the time . . . When you get it out make sure to clean the FPR screen and change all your o-rings. Also shim the FPR if you want higher fuel pressure . . . lot easier when it's out. Don't replace all those hoses and clamps too . Make sure the clamps are tight without stripping them . Or buy the good sleeve type clamps thats what I did . Good luck
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , HD cooler , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " ,Not installed yet DP flashed PCM (60 Tow )Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 03-08-2008, 08:57 PM   #3 (permalink)
sixiron's Avatar
My Photos: (11)
removing the turbo would make the job a lot easier...it's not that much labor to do it...good preventive maintance anyway...just 2 o-rings need to be replaced...would give you a whole lot more room to get both arms in around your work...
Anybody need a complete filter assy PM me ...I have an extra
bd
2002 E-350 ext. cargo..4" DP+exhaust/gauges/ CCV mod/ AIH delete/TT mirrors wC-btr's/Amsoil Dual by-pass/Racor 45P prepump/ITP regulated return w/fuel bowl delete/tank mods/203*/timbrens/bilstein/Hella/ DP tuned/BTS trans/ alum baja wheels/cryo rotors...dyno 335 hp...164,062 miles
98 E-350 PSD...575K
04 VW TDI/PD Jetta wagon
cat 2 mic f/filter,CCV/muffler/fuel filler mods,Evo skidplate/ RC1+
sixiron is offline
Old 03-09-2008, 01:50 PM   #4 (permalink)
thanks guys, that's some good information. i guess i'll go ahead and remove the turbo. sounds like that will help on a couple of counts. are the o-rings available at a regular parts store or do folks get them online?
Old 03-09-2008, 04:22 PM   #5 (permalink)
blageurt's Avatar
I went to an O-ring place and got ALL the O-rings in Quadruples for less than 10 bucks.
Fords want 5 bucks for 2 for the Turbo alone. There are also some clowns trying to sell Kits for the drain for 15 bucks . The O-rins cost like 2 cents . . . Find an O-ring place and bring the o-rings with you so they can be matched. I brought the complete filterbowl with everything loose so the guy could match everything . Make sure you get the right type for the application ie: Viton for oil like Turbo O-rings and the others for Diesel. Any place that services Hydraulic lines /equipment should have these O-rings. Tell them what they are being used for and thats it.
1990 KX500
blageurt is offline
