I have a question/problem.
Last week I was on a little road trip from Thursday through Sunday.
I took on fuel upon leaving odomiter reading was 65017.
Upon arrivel at my location I took on fuel at the local Flying-J, 21.163 gal., odometer reading 65493. Total milage traveled today is 476 mi.
When I do the math it comes out to 22.4 mpg.
I kept the c.c. set at 65 mph as much as possable.
Comming home Sunday doing everything the same, 65 mph, refueling at the Flying-J, I seem to get 24.551 mpg.
Not to look a gift horse in the mouth, But What Gives??
Any Suggestions??
2003, E-350, XLT, Chateau, 7-Pass. Club Wagan, 7.3L PSD, 3:55 LS Rear, SuperChip, AMSOIL TS-126 Air Filter, Fleetguard LF-9027 Bypass Oil filter, Sirius Satellite Radio, Garmin GPS, SuperCrewzer, AutoMeter (Pyro. Trans. Boost)Gauges, 4" Diamond Eye Turbo Back Exhaust, Sonnax valve & Tricululator springs, PML Alum. Tran's Oil Pan, Tru-Cool 4739 Tran's Cooler, ScanGuage Monitor, DAHL 100 Fuel Filter, "Last of the 7.3's".
USMC-(Ret).
You Don't Always Get What You Want, But If You Try Some Times You Just Might Find, YOU GET WHAT YOU NEED.
I would love to see #'s like that!
But i cannot ever see it happening. (my van) (18 open road summer)
I would check the ODO with the mile markers. To see if its out of range.
Test at a few speeds. Could be in cal at 50 and out by 60mph.
You can use a gps or timed 1 minute mile for baseline (60mph) set the CC to get your data.
I lost 1/10 with a tire change to a 33. I travel 1 mile and register 9/10 at 60. I installed a truspeed to recal the speedo/odo
Must have been down hill on the way there........and even steeper down hill with a tail wind on the way back.
2005 E350 Standard Cargo Van, 6.0 PSD, 4.10 L.S., Quigley 4X4 New on 11-18-05
(seems to manufacture oil....1 Qt per 4000 miles)
Warranty Turbo 7-07 22,000 miles
Warranty A/C compressor 10-07 25000 miles
2003 E350 Extended Cargo Van, 7.3 PSD, 3.55, Quigley 4X4 New on 2-1-04 Some Pix
Transfer Flow 46 Gal.***Delaminated***Replaced 8-29-06 UNDER WARRANTEE
XM Radio, Alpine GPS Nav. System 7.5' Western Snow Plow
Quad Captain's chairs and Espar Furnace
OX cable locker on front
ARB locker on rear
BTS Tranny 9-29-07 @55,000 miles
Aluminess Bumpers
Mile Marker 12,000 pound hydraulic winch
2000 F250 ...... just cuz people are dumping them for the fuel bill. Got mine on ebay for $8749 with 116K on the clock. Go-fast mods to follow.....
What about the quality of the fuel? Different stations?
Do it nice or do it twice!! Van sponsors: Mickey Thompson, Warn, RBP, Bilstein, Detroit Locker, Atlas Spring, Tuffy Security, Line-X // 06 E350 6.0, Sterling 10.5" rear axle w/Detroit locker, Dynatrac Pro60 front axle w/F550 knuckles & brakes, Knoll Racing front Powerlock, ORU/Lee hydraulic ram assist, Bilstein 5150 series shocks & Nitrogen bump stops, custom dual shock hoops, rear overload airbags, custom front bumper, Warn 16.5 winch,1350CV's front & rear, 1410 yokes, long travel front shaft, RBP 4" stainless exhaust, Atlas custom leaf springs, synthetic winchline, Line-X interior, M/T 38/15.50/20 MTZ's on M/T 20x10 Classic Locks. Thats all I can think of right now!
I agree with the wind factor!
It most definately can make that much difference in mileage.
Another thing to consider is elevation (seriously). If your starting point is a bit higher than your finish point it could make a little difference on the return trip. Combine that with a small wind hitting your tail on the way out and same wind hitting your face on the return trip.......can most assuredly cause the mileage drop. These vans have a pretty good size to them (ie, pushing a brick wall down the road ) and a little wind can go a loooooong way for (or against) mileage.
99 7.3L PS E-350XLSD with Ambulatory roof.
(((XM))) Satellite Radio
4" turbo back Diamond Eye exhaust (portadiesel)
Pair of K&N High flow filters
HPX Hose from D.I. (blew out.....pulled it and plugged now)
In-tank and prepump mods (homemade version)
203* thermostat (dieselsite)
Tru-Cool 4739 MAX Transmission cooler (dieselsite)
Boost Relief Valve (dieselsite)
Pillar mount Di-Pricol gauge set
Sonax/tricumulator (Black Cloud)
Jody flashed econo tune PCM (DP-Tuner)
Van specific regulated fuel return (ITP)
70k miles driven annually...mostly pulling 8 1/2 foot tall 7x14 enclosed trailer
Cruise on at 61mph and 1736rpm's I don't stop 'till she needs more go juice!
I went over the numbers once more yesterday as I had more time to look carefully at them.
They come out the same 22.4 going, & 24.5 on the return leg.
I'm not sure how to calculate for eleavation....Here at home in Cochise County I am at 4658 ft.
Going up to Laughlin, NV. I know I was well over 5k+ getting to the Kingman area.
The wind was all over the place not sure how to calculate for that.
I also changed/cleaned the Air Filters yesterday, They were full of crap at the 5k mark.
Also Blackstone sent there report, I'm good to go for another 3k on the oil.
I am using Rotella-T Syn. and the Fleetguard filter.
This oil has 9500k on it, and still good.
USMC-(Ret).
He's not talking about elevation i.e. air density, he's talking about elevation change - as in going from the top of a hill to the bottom.
Yeppers.............that's what I meant. And yes, driving uphill one way then downhill on the way back can (and will) cause some difference in mileage (at least it does while pulling my trailer).
To tell it a little differently:
1 mile from sea level to 1,000 feet drives a whole lot different than the same mile from 1,000 feet to sea level.
Also even if his speedo is out of whack a little bit............it's all relative. Unless something strange happened on the trip his 65 mph reading on the speedo on the way out should be the same speed at 65 on the way back.
An update to this story.
With the price of Diesel being what it is, I have put the Van in semi retirment.
I picked up a little Ranger as a Daily driver.
However, I did pull my Travel Trailer (22ft) over to Red Mountain, Near Scottsdale two weeks ago.
Pulling my wagon I got 14 mpg in a 15~20 knot wind.
55~60 mph seems to be the right speed for best fuel usage.
I will be hitting the road this summer sure would like to take the Van, But the price of fuel will dictate.
USMC-(Ret).
I don't care how many miles I can get out of my van, I just love the power and range I have with it. I have the 35 gallon main tank and the 27 rear Aux TF Tank for a 62 gallon total range. With my 4" magnaflow straight through exhaust I would bet I get close to 20 mpg if I set the cruise at 65.
Diesel is 4.07 a gallon here, last year it was under 3.00.
I think your numbers are about the best you can get.
Don't let a few hundred dollars in fuel stop you from using your van.
My van is like a living room inside, with the overhead TV, dvd etc, and the rear bench/bed and captains. It's so comfortable having all the room. The passanger can get up and go to the back to the living room, we keep a cooler right by the front, and we are spoiled.
I just had my AC Charged-up yesterday and the system takes 4 lbs. of 134A and 13 oz. of pag oil. Now the van is blowing 41 degrees in the front and 43 degrees in the rear.
The van is so much better than being stuck in a car, especially a small car.
2000, E-350, SuperDuty, Explorer Extended LivingRoom, 7.3L PSD. 3:55 LS Rear, SuperChips 1705, Dual K&N's, FleetGuard WF-2077 Coolant Filter, AutoMeter Phantom Guages - Pyro, Boost, Tranny & Hobbs Hour Meter, 4" SS MagnaFlow Turbo Back Completely Wrapped with Thermo-Tec 2" Header Tape, Sonnax Valve & Tricumulator Shift Springs, Mag-Hytec Tranny & Dana 60 Cover, One-Up Front Spring Option, Bilstein's, Centramatic's, 35 Gallon Main Fuel Tank & Trax II TransferFlow 27 Gallon Aft. Aux. Fuel Tank = 62 Gallon Range, ACPM/AIC, Dual Battery & Dual Alt, FilterMAG, Fumoto, Amsoil Tranny & Rear End, Alcoa's, 4 Leather Captain Chairs w/ Back Bench Seat/Bed, Inflatable Aerobed, 20" LCD TV Overhead, DVD, VCR, KVH TrackVision, SAT/NAV, Walnut Cabinets & Trim, 3000 Watt Sine Wave Power Inverter, BioVault 2.0 Gun Safe, 2xDIN Pioneer DVD Head w/Backup & Side Cameras, 5 Channel Surround Sound System, PowerTank, 12 Volt Refrigerator, RainX Wiper Blades, 3M Rubberized Undercoating, Bob's AC Valve, H3R
I'm with you van 350sd! The convenience and room behind the driver is worth every penny of fuel. I am jealous of you guys boasting 20 mpg. I'm pretty much stock as far as mechanicals and hold at 12 mpg. But with 160 gallons on board I've got a 1900 mile range. Can't drive 1900 miles without needing to stop and stretch the back side. Hi Hi.
Love this site!
2001 E450 Super Duty 7.3 Liter Turbo. 19 pass bus body. 160 gallon fuel tank. 2 KW inverter. Added air compressor. Sat TV, Mobile communications platform.
Morning All:
An update to the fuel saga.
1. After installing the Dahl fuel filter, I have been using Mexican Diesel exclusivly the past few months, I am paying $2.20 gal. down there.
With no problems what so ever. I would note anyone thinking of installing the Dahl filter use the 5/8 hose not the 3/8, MY VAN seem to like the 5/8...??? not sure why.
2. I ran into a fellow FORD 7.3 driver at Home Depot, during the conversation he mentioned SuperChip had a Mod to there program that he is using.
I contacted SuperChip, Sent my unit back for updating, I got it back two weeks ago, I reset my PCM to the High Preformance setting as recommended by SC, I have yet to do the "Hard Numbers" But there is a noted improvment in fuel usage.
I shall be hitting the road on my summer trip the end of Aug. That will be the acid test.
USMC-(Ret).
Quote: I contacted SuperChip, Sent my unit back for updating, I got it back two weeks ago, I reset my PCM to the High Preformance setting as recommended by SC,....
UNQUOTE
Is your SuperChip the one that plugs in the box? If so, I have the same set up and didn't know they could be enhanced. Do you 'know' what they did to it? Have you had time to do any estimations on fuel economy these past 5 days? What was the charge for the upgrade?
