Old 08-24-2008, 01:42 PM   #1 (permalink)
ujointclothing's Avatar
Send a message via ICQ to ujointclothing
Fuel smell in AC???
Lately, when I run my AC on Normal, I smell diesel fuel. When it's on Max, I don't smell it. (recirc) The odor is pretty strong. I have no visible fuel leaks, and the engine is stock except for a K&N. Has anyone run into this????
Do it nice or do it twice!! Van sponsors: Mickey Thompson, Warn, RBP, Bilstein, Detroit Locker, Atlas Spring, Tuffy Security, Line-X // 06 E350 6.0, Sterling 10.5" rear axle w/Detroit locker, Dynatrac Pro60 front axle w/F550 knuckles & brakes, Knoll Racing front Powerlock, ORU/Lee hydraulic ram assist, Bilstein 5150 series shocks & Nitrogen bump stops, custom dual shock hoops, rear overload airbags, custom front bumper, Warn 16.5 winch,1350CV's front & rear, 1410 yokes, long travel front shaft, RBP 4" stainless exhaust, Atlas custom leaf springs, synthetic winchline, Line-X interior, M/T 38/15.50/20 MTZ's on M/T 20x10 Classic Locks. Thats all I can think of right now!
ujointclothing is offline
Old 08-24-2008, 02:46 PM   #2 (permalink)
Well, obviously, the is a leak of some kind. The normal pulls air from the outside, so where ever that intake is- there must be a leak near by. How close have you looked? Inside cover taken off? Engine running or off?
1999 E-350 Cub Wagon, 7.3L Power Stroke, E4OD, 3.55
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
Kaliburz is offline
Old 08-24-2008, 03:48 PM   #3 (permalink)
BlizzardVan's Avatar
My Photos: (18)
Check in the well of the motor. there is a drain that takes pluid out of the well and to the back of the bell housing. Look for wet marks. Check the plugs on the back of the heads small and large and the fittings at the back of the passenger head and front of the drivers head facing towards the center of the motor. Good luck
Hypermax stage 2 injectors, 4" intake with Ram scoupe, QSSB Turbo, Snow Meth inj, BTS trans no spacer, Salem Kroger 4x4, Sway and traction bars, APX drivers seat, 4" straight exhaust & DP, 4" lift, 18" wheels with 325 nittos, custom valve Bilsteins, DP PCM and F5
...Stuff to make it almost as fast as a pickup.
BlizzardVan is offline
Old 08-25-2008, 12:17 AM   #4 (permalink)
I'm going to dig a little deeper tomorrow.... there has to be fuel leaking somewhere. Thanks for the advice, I'll let you know what happens!!
Old 08-25-2008, 09:32 AM   #5 (permalink)
Clark2's Avatar
The thing about a fuel leak is that you would most likely see drips under your van that looked like oil. With as clean as your van is I think this would be obvious. However, I agree with checking your valley - everything ends up there.
2000 E350 Chateau, 7.3 PSD, Ujointclothing DIY 4x4 conversion, Amsoil dual bi-pass oil filter, Amsoil Blue Air Filter, Reunel rear bumper, Bushwacker Fender Flares, and leaf spring front brackets
Clark2 is offline
Old 09-21-2008, 12:24 AM   #6 (permalink)
Me too!
Did you find the source of the smell? I have the same situation.
PacoPowerstroke is offline
Old 09-22-2008, 11:45 PM   #7 (permalink)
I took it to the dealer, and they replaced a few things. It was a fuel regulator leaking on top of the motor, near the fuel filter. That's what they said atleast..... It stropped leaking, and I'm glad I took it in, they wound up replacing the intercooler tubes, cleaned out my EGR & turbo, and checked out e-thing else. The van runs MUCH better now.
