Old 02-10-2007, 09:31 PM   #1 (permalink)
fuel tank capacity?
I just got a Scanguage. Really cool! But it asks what size tank. I looked at an owners manual for my gasser & it looks like its either a 35 or 37? I plugged in 37. Is that right? Or should I syphon out & refill to make sure.
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
Old 02-10-2007, 10:46 PM   #2 (permalink)
Re: fuel tank capacity?
i ve filled my 04 with 35.5 gallons....that was running on vapors
'06 navigator,4x4, ultimate, black/grey interior.
'99 e-300 turbo diesel benz, silver, wife s ride
'77 450SL benz in the family since new.
'06 gmc 3500 dmax/allison, cc, slt. black/dark pewter int.
'91 350sdl turbo diesel benz
'06 mazda 6, daughter s ride.
'89 560sl benz, it s official, i m outta room in the driveway.
hapaschold is offline
Old 02-11-2007, 01:04 PM   #3 (permalink)
On these vans the last couple (4?) gallons is slow to fill, so I loaded a slightly smaller number into my Scangauge.
With a stock tank, I would use 31 or 32 gallons. That leaves a little reserve. With the reserve, I know I can go at least as far as the Scangauge calculates, even if the tank wasn't completely filled to the neck.
With my T-F 46g tank, I use 40 gallons as the tank size.
This doesn't affect any of the Scangauge calculations except things like: distance to empty, fuel to empty, time to empty, etc.
Mike
125W solar panel. Sportsmobile off-road trailer.
54,311 miles. 16.47 mpg average
From Cal to Alaska and Key West and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires. 46 Gal tank - harpooned pump vent tube.
Scangauge
162 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, Turbo hose fitting, Block Heater, Door lock - all under warranty. AC hose, not under warranty.
MikeL46 is offline
Old 02-11-2007, 08:04 PM   #4 (permalink)
Good idea, I should re-enter lower gal. also.
bork is offline
Old 02-12-2007, 11:00 PM   #5 (permalink)
My Photos: (14)
Around 37 gallons is the most I've gotten in mine filling to the neck as in " Captain I don't think she'll take any more...." Your sig says your Harpooned, so filling to the brim for you shouldn't take as long.
I don't have one, but in the other Scan Gauge thread, it seems it might take you a few tanks to get calibration sorted out, IOW checking how much you actually fill against what it thinks you burned, and recal the tank size accordingly.
Since I hand calc, I still sit there, unharpooned, and trickle in the last few gallons till it stands in the filler neck, no foam.
The Scan Gauge still won't be cooler than a F series cluster with tach though [img]/ubbthreads/images/graemlins/bleh.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
ddog
While I love diesels, I don't need one, and unfortunately, after much deliberation its a hobby I currently cannot afford.......... Gone but not forgotten:
1999.5 F250 CC SB XLT 4WD, 7.3 PSD, First F,2nd Diesel, nice but still liked the van better.
2003 E-350 Super Duty Chateau (Club Wagon)7.3PSD, 3rd Clubwagon,First diesel, Never should have sold it....
ddog is offline
Old 02-13-2007, 12:14 PM   #6 (permalink)
It does take a few tanks to get the calibration sorted. But that has no effect on tank size.
For instance, if I entered a 100 gallon tank, the usage, mileage, etc. is unchanged. The only calculation affected are Distance to Empty, Hours to Empty, etc.
Mike
Scangauge
MikeL46 is offline
Old 02-14-2007, 09:44 PM   #7 (permalink)
Why are there two different tank sizes, that differ by only two gallons? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
That makes very little sense to me. [img]/ubbthreads/images/graemlins/confused.gif[/img]
I don't recall looking up the capacity on my new one. My '96 E150 boasted a 41 gallon tank. The tank in my 2004 doesn't appear significantly different from the tank in my old gasser. What gives? Is the difference entirely in the vent dome and the vent? As in, diesel foams so it needs to use a larger portion of the vent dome?
"Nothing in life is so exhilarating as to be shot at without result." - Sir Winston Churchill
May your road stay clear & dry, may your fuel never gel, and may you never be outsmarted by your idiot lights.
2002 F-250 XLT SC LB 4x4 7.3PSD 6-Sp 3.73 L-S, Snugtop Snuglid Tonneau, 235/85 MC HTRs, <span style="color: red">DPTuner F5</span> AFE Stg II, Turbo LifeSaver, MAP BRV, Autometer Cobalts, Magnaflow 4", WW, TAG, AIH del, CCV, AirDog, In-tank, Harpoon, HPX, ITP fuel sys, LL8 del, 203*, Oilguard & SP Diesel bypass filtration, ART rotors, PFC pads, Heater Core Ctl Valve, Bilsteins, Velvet Ride Shackles, South Bend Clutch, <span style="color: green">21.27 mpg</span>
2004 <span style="color: red">E</span>-350
XLT Wagon 6.0PSD 3.55 L-S TDM EZ-Entry 11 pass., AIC, custom MBRP 4" w/dual Aeroturbines, Airdog, harpoon, Overhead Cobalts
Pictures . . . Parts Links
DarthSurplus is offline
Old 02-14-2007, 11:12 PM   #8 (permalink)
ahhh, so I'm not the only one wandering. eh?
bork is offline
Old 02-15-2007, 11:04 AM   #9 (permalink)
My 2004 sales brochure for all E-series claims they have a 35-gallon tank. All of them.
