Re: Fuel tank difference between 92-96 vs 97-03 (want a TransferFlow)
If it helps, I have the T-F 46 Gallon tank in my 04. And I believe it is the same tank that Salem-Kroger and SMB install in newer vans.
The tank was designed for Quigley conversions and uses the Quigley transfercase crossmember for support. You may have to fabricate a crossmember, but it is not a difficult piece to make. Maybe the Quigley crossmember has changed and the tank doesn't fit new Quigley's??? Or maybe it was an emmisions requirement that it doesn't meet???
Mike
125W solar panel. Sportsmobile off-road trailer.
54,311 miles. 16.47 mpg average
From Cal to Alaska and Key West and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires. 46 Gal tank - harpooned pump vent tube.
Scangauge
162 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, Turbo hose fitting, Block Heater, Door lock - all under warranty. AC hose, not under warranty.
Excellent news!!
If the 46 gal TF fits in 94, I'll make it fit in 95 for sure.
Btw, did the TF come from quigley installed or did you have to add it after you got it yourself? TF tells me they didn't start making them for quigleys until 97 or so...
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">If the 46 gal TF fits in 94, I'll make it fit in 95 for sure.
</div></div>
That's an 04, not a 94 that I have. Sorry if I misread your original concern about the years.
Put your information in your signature line and it will be easier to know which years you are talking about.
Mike
Scangauge
