Fuel tank fill up -- take too long for last 5-7 gal - Diesel Forum - TheDieselStop.com
Old 02-23-2003, 11:10 AM   #1 (permalink)
My Photos: (17)
It takes WAY TOO LONG to fill the last 5-7 gallons of fuel in the midship tank on the van. Has anyone else seen this problem? I have never had the patience to top off all the way to the filler neck. Is there some way to correct this problem? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Colin
[img]/ubbthreads/images/graemlins/cool.gif[/img]2001 E-350 SuperDuty<font color="green"> 2wd Sportsmobile, <font color="green">BTS Trans, <font color="green">ITP VAN SPECIFIC fuel system mods,3.5" DP with 4"exhaust, 3 pos "Bill's" chip, Autometer Phantom gauges, Baldwin pre pump filter assembly, <font color="green">Reunel bumpers, Warn 9k winch, PIAA lights, Goodyear Wrangler AT/s tires (265/75 R16), Firestone airbags, <font color="green">Con-Ferr roof rack, Bushwacker Fender flares, <font color="green">Correctrack rear wheel spacers, Rancho 2" lift, </font><font color="orange">PHOTOS</font>
youngster is offline
Old 02-23-2003, 11:45 AM   #2 (permalink)
Re: Fuel tank fill up -- take too long for last 5-7 gal
Colin,check out this thread.
http://forums.thedieselstop.com/ubbt...ue#Post1054230
2000 E-350 Van,BTS Tranny,Custom Dana 80 Axle w/ ARB & 3:55 Gears, Swamp 175cc Injectors, Custom 4 Position Chip,TS Billet Intakes,W/Wheel,PS2000,Magnaflow 4" Exhaust,ITP Fuel Regulator,4 gauge pillar post,TTM,CTI Idle Controller,Amsoil Fluids,Evans,203 Thermostat,Coolant Filter,J&J S.S. Grill,Art Rotors,Custom Flame Job,Road Armor Bumper,Warn M15000 Winch,Bushwacker Flares,Bilstein Shocks,Centerlines,Maghytec Covers. dynoed at 345.5 rwhp
FUTURE MODS: Upgraded turbo, HD oil pump,Intercooler with water injection.
http://community.webshots.com/user/aceman116
04 Jeep Rubicon
RE 5.5" Long Arm Lift,1"body/eng.lift,Banks Header/ Exhaust,37" IROKS,Mickey Thomson Classic 2 beadlocks,Road Armor Bumpers,Warn 9500TI winch,Alloy Usa axleshafts,CTM u-joints,Nth degree oil pan skid,Clayton front high clearance brackets,Toys by Troy crossover steering,Poison Spyder Rock Sliders.
Aceman is offline
Old 02-23-2003, 12:25 PM   #3 (permalink)
My Photos: (17)
Thanks for the info. I wasn't aware that transfer flow had these kits
Colin
Old 02-24-2003, 09:27 AM   #4 (permalink)
When I fill up and I know I have about 7 gallons to go I set the handle to its slowest setting. When it clicks it only takes about 30 seconds to nurse the rest in. I found most diesel pumps to be fairly slow anyway so this works 99% of the time. During the slow setting I find things to do like check the oil, kick the tires, wash the windows, empty the trash, etc. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2003 E350 Super Duty Commercial Extended 7.3L Premium Van Group, 3:55 Posi,Turbo Life Saver, Pioneer MP3, Cobra 75 WXST, New Ford AIC(EBAY $260) Draw-tite Activator II Trailer Brake Controller 5500, Autometer(Boost/Pyro/Trans)K&N Air Filters,3.5" down pipe w/ 4" SST back exhaust,KYB shocks,1.5" rear stablizer
2003E350 is offline
Old 02-24-2003, 09:58 AM   #5 (permalink)
My Photos: (15)
This is an old post but it looked appropriate again...! [img]/ubbthreads/images/graemlins/smile.gif[/img]
For all of you who have been asking how to fix your tank so it will fill full without taking 10 minutes to drizzle in the last several gallons, here's how:
While you have your tank off doing the Hutch mod and while the sending unit is out, reach into the tank toward the vent pipe (the small one next to the big fill tube) and you will find the vent tube extends down into the tank about 5 or 6 inches and is about an inch in diameter. With the tubing cutter you used on the steel tubing for the tank mod, reach into the tank, place the cutter on the plastic pipe and cut it off! If you do it as I did, this will leave about an inch of vent tube still attached and should leave an inch or so of air space.
After replacing the tank, you can now fill the tank to the 'visible in the neck' line as fast as you want! I did mine when I did the tank mod a month or so ago and waited to make sure it didn't have side effects...after a month the only side effect is that after the 'low fuel' light comes on and a few more miles I can get 33 gallons in the tank...and the last 5 gallons go in as fast as the first 25!
A caution for the gassers...if you overfill your tank check to make sure your not flooding any filter canisters!
So, *Harpoon* your tank... and fill fast!
Tim
Maroon Harpoon
Y2K F250, XLT, SC, SB,4X4 (no decal), 3.73 LS, Dark Toreador Red, DeeZee running boards, Outland Sport bar, 3 'A' pillar guages, NVK5, Hutch tank, TT fuel reg, harpooned tank and spiderman crawling up the grill... Sunnybrook 26FKS travel trailer and Ham, WBØTUB
Maroon Harpoon is offline
Old 02-24-2003, 10:34 AM   #6 (permalink)
My Photos: (9)
Mine always seems to read full after the pump clicks off, at least according to my Transfer Flow digital gauge. That said, I've never felt the need to take forever to top it off (main tank). The rear I fill slowly to prevent the long fill neck from foaming up, but seem to get it mostly full as well....
2001 E350 PSD, Deep Emerald Green, 3.55 LS, Premium package, dual alts, rear A/C. Quigley 4x4, Transfer Flow rear tank (27+26), handicap mods, custom interior, Reunel tire carrier w/ Hi-Lift, Sportsmobile nerf bars (black), Amsoil lubes and Dual-Gard bypass oil filter, Amsoil air filters, Eclipse/JL Audio sound system w/ Sirius & 120GB Neo Car Jukebox (MP3 player), J&J stainless grill, Reunel Stainless bumper, 12000# Warn winch, PIAA lights, Bilstein shocks, Ultra Magnum wheels, Michelin tires (265/75-16), Correctrack rear wheel spacers, Bushwhacker flares (painted), Velvet-Ride spring shackles, p/s filter, external tranny and coolant filters, Autometer gauges(5), Optima Yellow Tops, Airdog.
msnunes is offline
