Old 11-25-2007, 04:29 PM   #1 (permalink)
Which gear lube for rear?
Not much in "Larry's secrets". I wanted to add lube to rear since it it kinda low. what should go in ? & are they compatible? It seems I have a dana 60, full float, open, in a 1999. I got it with 250k. So I dont know any history of whats in it now. One of the pennz oil places wanted $180.00 to suck out & put in sythetic. They claim that is what is required. I'd rather buy at parts store & do myself for that price.
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
Old 11-25-2007, 04:37 PM   #2 (permalink)
u2slow's Avatar
My Photos: (16)
Re: Which gear lube for rear?
Your owner's manual should spec exactly what Ford recommends.
IMO, since it not posi, I would fill it with Saftey-Kleen's 80W90 GL-5 that I buy by the 5gal bucket for $33. [img]/forums/images/%%GRAEMLIN_URL%%/wink.gif[/img]
95 F350 Crew 5spd/4.10, SuperChips tuner, solid flywheel, T444E waterpump, 205° stat, Locked F&R, 9.00R16 Michelin XLs
97 E350 SRW cutaway, E4OD/D70/4.10, 19.5s on the rear, deep trans pan, batteries inside, 1800W inverter, manual glowplugs
84 C30 Suburban, 6.2/4-spd, 3.21s
Other rigs I goof around with regularly:
93 F350 4x4, 7.3 IDI turbo, 5spd, 4.10s
90 F250 4x4, 7.3 IDI, 5spd, 3.55s
, D60 swap, straight pipe, turned up fuel screw
u2slow is offline
Old 11-25-2007, 05:48 PM   #3 (permalink)
Ordinarily I'd say just top off with synthetic, but with the mileage you should do a full drain.
Pull off the rear cover and drain, then use paper towels to soak up what is in the bottom of the carrier (you will also get a little metal flakes in the bottom). I like to use some brake-kleen to make sure I get everything.
Use form-a-gasket to seal the cover back up. I like to snug the bolts, let the sealer set up some, then torque them fully. I feel this helps keep the sealer from going inside the pumpkin.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 11-25-2007, 06:09 PM   #4 (permalink)
My Photos: (13)
Bork
180.00 is insane!
If looking to save on some cash.
Check your gear ratio.
Required.
The dana 3.55 is dino.
The dana 4.10 is sythetic (required)
Bill
97 E-350 Quigley Van Picts
Supporter/User of THE CURE E4OD/4R100 Transmission Control
WWW.FORDTRANSMISSIONCURE.COM
TO RENT THIS SPACE SEE YOUR ADMINISTRATOR
ads@thedieselstop.com.
MADVAN is offline
Old 11-25-2007, 09:30 PM   #5 (permalink)
Ratio is a 3.55. I'd like to pull cover & do it right like Roboto said , but for now,(due to timing & want enough time as not to rush job) if I did add dino & it happens to have syn, do think it'll hurt it? If the end seals are leaking, is there ever any visual evidence, besides braking? Also since Madvan says 3.55 gets dino, will it help in long run if I install syn, when I do the full clean out?
bork is offline
Old 11-25-2007, 09:39 PM   #6 (permalink)
I'd just top off with regular dyno.
Old 11-25-2007, 10:07 PM   #7 (permalink)
My Photos: (13)
Bork
You can upgrade to syn if you want. Just not required.
Remember if its an LS you need the additive.
Bill
MADVAN is offline
Old 12-18-2007, 05:50 PM   #8 (permalink)
fordnut350's Avatar
If you need the syn, you can get Royal Purple for 9.99 a quart at Pep Boys. It also states the friction modifier is in it and not required.
2001 F-350 CC LB 4X4 06 frontend 6.5" pro-comp lift with 35" BFG muds on 18x10 Mickey T's 4" MBRP SS exhaust Airraid intake Hypetech tuner
fordnut350 is offline
Old 12-19-2007, 01:27 AM   #9 (permalink)
blageurt's Avatar
You only need synthetic if you don't want to change it often AND if you carry heavy loads (like me)or tow alot. Synthetic gear oil performs better under high heat /load conditions. If you are contaminated with water IE foamy emulsion, I would change it asap. I also have a 3:55 but it is a 70 FF. I have always used 80W90 dino because I change it often , like every 30000 kms. The only way to see if seals are leaking is to remove the drums. That in mind have all new brake parts ready so you only do it once like Forest Gump , you never know what you're gonna get.
Good luck.
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , HD cooler , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " ,Not installed yet DP flashed PCM (60 Tow )Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 01-01-2008, 02:25 PM   #10 (permalink)
In the Haynes I'm looking at right now........it states that the '99 model 60 uses 80W-90 QL lube. Same model 60 for '00 uses 75W-140 GL synthetic.
Would this make a difference if you have an early '99 vs. Late '99??
Also if you wanted to go with synthetic for the early '99, would you use an 80W-90 synthetic or 75W-140 synthetic?
99 7.3L PS E-350XLSD with Ambulatory roof.
(((XM))) Satellite Radio
4" turbo back Diamond Eye exhaust (portadiesel)
Pair of K&N High flow filters
HPX Hose from D.I. (blew out.....pulled it and plugged now)
In-tank and prepump mods (homemade version)
203* thermostat (dieselsite)
Tru-Cool 4739 MAX Transmission cooler (dieselsite)
Boost Relief Valve (dieselsite)
Pillar mount Di-Pricol gauge set
Sonax/tricumulator (Black Cloud)
Jody flashed econo tune PCM (DP-Tuner)
Van specific regulated fuel return (ITP)
70k miles driven annually...mostly pulling 8 1/2 foot tall 7x14 enclosed trailer
Cruise on at 61mph and 1736rpm's I don't stop 'till she needs more go juice!
stroked_van is offline
Old 01-01-2008, 04:17 PM   #11 (permalink)
Ford and others say you can go 100,000 miles with 75W-140 syn. It is clearly worth spending a few extra dollars for the added protection. If I was north of the border I might go with a 75W-90 syn.
1994 E-350 RB 5.8gas 4X4Quigley cargo 4.09 arb-locker f/r 35x12.5-16.5 or 285/75-16.,,, 1997 E-350 EB 5.4gas 4X4Quigley Sportsmobile camper 4.10 arb front, L/S rear 285/75-16/front 33X12.5-16.5/rear ><>J
toalpi is offline
Old 01-01-2008, 07:20 PM   #12 (permalink)
I will definitely go synthetic if possible. It doesn't bother me to spend the extra money. I just want to make sure of getting the correct weight and doing the job properly. [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img]
Old 01-02-2008, 08:26 PM   #13 (permalink)
clev's Avatar
My Photos: (14)
Can/will someone comment on the "Slik-50" brand of gear lube?
'85 E-150 351w, factory order rcvd Oct. '84: Balanced/blue-printed, HYPEREUTECTIC pistons, matching edelbrock performer pkg: cam, lifters, intake, carb, & elec fuel pump. MSD pkg: MSD 6, billet distributor, timing control, & 8.8 wires; AirLift air bags, Deraler tubed trannie pan, FloMaster Exhaust w/duramax ceramic headers, new paint.
'99 E-350 HiTop Companion Van Conversion SD 7.3, factory order rcvd Dec. '98: SuperChip, twin K&N air filters, 203* mod, Deraler tubed trannie pan, B&M trannie cooler, AirLift air bags, Bilsteins, 4" DiamondEye turbo back exhaust.
clev is offline
Old 01-04-2008, 11:08 AM   #14 (permalink)
I think i have a bearing starting to go. noisey under deacceleration. I put in the cheap standard gear lube. The rearend driveline specialist in my area said ford had trouble with syn & went back to the standard stuff. I'm gonna have them rebuild & put in a limited slip at the same time. I'll probably go with the standard stuff again w/additive.
bork is offline
Old 01-04-2008, 11:42 PM   #15 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: bork</div><div class="ubbcode-body"> The rearend driveline specialist in my area said ford had trouble with syn & went back to the standard stuff.</div></div> What trouble ,when trouble, and when changed? Not buying any of what he said.
toalpi is offline
