My glow plugs are not working and I want to check the Relay but I can not find it. It shows a picture of one in my Haynes book but I don't see it anywhere. Where did they hide it? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Forgot Best part - - 1995 E350 Van
I have been woundering the same thing... Mine is from the year 2000.
Now there is a relay on the passenger fender... the one battery has it mostly covered... but I do not know if that is the relay for the starter or the glow plugs.
The van is back..........(song of elton john... the B.... is back....)
But boy does it need that program.......
That relay on the passenger side is the starter relay, the GP and IAH relays are behind the fuel filter along the passenger side valve cover. To get to them I had on my 01 remove the resonator box and go in from the doghouse side. On mine IIRC the IAH is the forward relay and the GP is the rear relay. You might need to remove the Alt or A/C comp. can't remember which is on the passenger side along with moving the main engine connector out of the way to get to the IAH relay.
On the 1995 it should only have one relay, the GP relay and I'm fairly sure that on is also somewhere along the passenger side valve cover area.
Larry, keeper of the <font color="red"> New revised </font><font color="blue">"little secrets" </font> CLICK HERE [img]/ubbthreads/images/graemlins/smile.gif[/img]
__________________ <font color="green">MY PICTURES - Look around ... lots of good stuff </font>
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font> [img]/ubbthreads/images/graemlins/smile.gif[/img], BTS w/Schaeffer's ATF[img]/ubbthreads/images/graemlins/biggrin.gif[/img] , ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10µ Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets" [img]/ubbthreads/images/graemlins/smile.gif[/img], & a 1981 26' Prowler TT(26Y)
Thanks for the info. I found what I believe is a relay behind the battery next to the headlite on the drivers side? Can you identify this item? Thanks
Technically that is one of two starter relays. Ford, in their infinite ?wisdom? retained their original relay, and used it as a trigger for the starter mounted relay on the gear reduction starters.
